[PATCH 3/3] ibchip/ns16550: Minor optimisation.
Joel Sherrill
joel at rtems.org
Wed Apr 20 22:54:30 UTC 2016
These look good and almost all cosmetic. Apply.
On Wed, Apr 20, 2016 at 2:20 AM, Chris Johns <chrisj at rtems.org> wrote:
> c/src/libchip/serial/ns16550.c | 27 ++++++++++++++-------------
> 1 file changed, 14 insertions(+), 13 deletions(-)
> diff --git a/c/src/libchip/serial/ns16550.c
> b/c/src/libchip/serial/ns16550.c
> index 12d220c..6473028 100644
> --- a/c/src/libchip/serial/ns16550.c
> +++ b/c/src/libchip/serial/ns16550.c
> @@ -1,6 +1,6 @@
> * @file
> * This file contains the TTY driver for the National Semiconductor
> NS16550.
> * This part is widely cloned and second sourced. It is found in a
> number
> @@ -234,7 +234,7 @@ void ns16550_init(int minor)
> Console_Port_Data[minor].pDeviceContext=(void *)pns16550Context;
> pns16550Context->ucModemCtrl=SP_MODEM_IRQ;
> - pNS16550 = c->ulCtrlPort1;
> + pNS16550 = c->ulCtrlPort1;
> setReg = c->setRegister;
> getReg = c->getRegister;
> @@ -389,7 +389,7 @@ void ns16550_outch_polled(console_tbl *c, char out)
> void ns16550_write_polled(int minor, char out)
> console_tbl *c = Console_Port_Tbl [minor];
> ns16550_outch_polled( c, out );
> @@ -616,27 +616,28 @@ NS16550_STATIC void ns16550_process( int minor)
> NS16550Context *ctx = d->pDeviceContext;
> uint32_t port = c->ulCtrlPort1;
> getRegister_f get = c->getRegister;
> - int i = 0;
> + int i;
> char buf [SP_FIFO_SIZE];
> /* Iterate until no more interrupts are pending */
> do {
> /* Fetch received characters */
> - for (i = 0; i < SP_FIFO_SIZE; ++i) {
> - if ((get( port, NS16550_LINE_STATUS) & SP_LSR_RDY) != 0) {
> - buf [i] = (char) get(port, NS16550_RECEIVE_BUFFER);
> - } else {
> - break;
> + i = 0;
> + while ((get(port, NS16550_LINE_STATUS) & SP_LSR_RDY) != 0) {
> + buf[i++] = (char) get(port, NS16550_RECEIVE_BUFFER);
> + if (i == SP_FIFO_SIZE) {
> + /* Enqueue fetched characters */
> + rtems_termios_enqueue_raw_characters( d->termios_data, buf, i);
> + i = 0;
> - /* Enqueue fetched characters */
> - rtems_termios_enqueue_raw_characters( d->termios_data, buf, i);
> + if (i > 0)
> /* Check if we can dequeue transmitted characters */
> if (ctx->transmitFifoChars > 0
> && (get( port, NS16550_LINE_STATUS) & SP_LSR_THOLD) != 0) {
> /* Dequeue transmitted characters */
> rtems_termios_dequeue_characters(
> d->termios_data,
> @@ -869,6 +870,6 @@ int ns16550_inch_polled(
> int ns16550_inbyte_nonblocking_polled(int minor)
> return ns16550_inch_polled( c );
> 2.4.6
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160420/70aaae71/attachment.html>
