[PATCH 2/3] i386/pc386: Add IO and memory support to PCI UART devices.
Joel Sherrill
joel at rtems.org
Wed Apr 20 23:57:05 UTC 2016
On Wed, Apr 20, 2016 at 6:47 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 21/04/2016 8:57 AM, Joel Sherrill wrote:
> > + * IO Register Access Routines
> > +static uint8_t pci_ns16550_io_get_register(uint32_t addr, uint8_t i)
> > + uint8_t val = rtems_inb(addr + i);
> > + if (UART_PCI_IO)
> > + printk( "RD(%p -> 0x%02x) ", addr + i, val );
> > + return val;
> > +static void pci_ns16550_io_set_register(uint32_t addr, uint8_t i,
> > uint8_t val)
> > + if (UART_PCI_IO)
> > + printk( "WR(%p <- 0x%02x) ", addr + i, val );
> > + rtems_outb(addr + i, val);
> > Is it possible to use the same com access ports that are used for
> com1-com4?
> > Or at least move to shared ones?
> It could be done if want.
Just pointing out common code possibilities.
> > They are in conscfg.c. It would be good if we could eliminate some code
> > during this. :)
> I have not looked at the differences between the old driver and the new
> one Sebastian created. We need to move to that driver for SMP support.
> Maybe this all gets cleaned up then?
> Sure. There is definitely SMP work on the x86. Add this to the list
along with TLS, etc.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160420/96f54cea/attachment.html>
