[PATCH 01/10] posix: Avoid Giant lock in sem_getvalue()
Sebastian Huber
Thu Apr 21 07:20:05 UTC 2016
Update #2555.
cpukit/posix/src/semgetvalue.c | 13 +++++++++++--
1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/cpukit/posix/src/semgetvalue.c b/cpukit/posix/src/semgetvalue.c
index ed49c09..f895266 100644
--- a/cpukit/posix/src/semgetvalue.c
+++ b/cpukit/posix/src/semgetvalue.c
@@ -37,13 +37,22 @@ int sem_getvalue(
POSIX_Semaphore_Control *the_semaphore;
Objects_Locations location;
+ ISR_lock_Context lock_context;
- the_semaphore = _POSIX_Semaphore_Get( sem, &location );
+ the_semaphore = _POSIX_Semaphore_Get_interrupt_disable(
+ sem,
+ &location,
+ &lock_context
switch ( location ) {
case OBJECTS_LOCAL:
+ * Assume a relaxed atomic load of the value on SMP configurations.
+ * Thus, there is no need to acquire a lock.
*sval = _CORE_semaphore_Get_count( &the_semaphore->Semaphore );
- _Objects_Put( &the_semaphore->Object );
+ _ISR_lock_ISR_enable( &lock_context );
return 0;
#if defined(RTEMS_MULTIPROCESSING)
1.8.4.5
