[PATCH 02/10] score: Avoid Giant lock for CORE mtx/sem
Thu Apr 21 07:20:06 UTC 2016
Avoid Giant lock for CORE mutex and semaphore flush and delete
operations.
Update #2555.
 cpukit/posix/include/rtems/posix/semaphoreimpl.h | 26 +-------
 cpukit/posix/src/semaphoredeletesupp.c           | 22 +++----
 cpukit/posix/src/semclose.c                      | 22 +++----
 cpukit/posix/src/semdestroy.c                    | 27 ++++----
 cpukit/posix/src/semunlink.c                     |  9 ++-
 cpukit/rtems/src/semdelete.c                     | 83 ++++++++++++++++--------
 cpukit/rtems/src/semflush.c                      | 25 +++++--
 cpukit/score/include/rtems/score/coremuteximpl.h | 26 +++-----
 cpukit/score/include/rtems/score/coresemimpl.h   | 46 +++++++------
 cpukit/score/include/rtems/score/mrspimpl.h      | 41 +++++++++---
 10 files changed, 186 insertions(+), 141 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
index 41bfdad..d726761 100644
--- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
+++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
@@ -22,8 +22,7 @@
 #include <rtems/posix/semaphore.h>
 #include <rtems/posix/posixapi.h>
 #include <rtems/score/coresemimpl.h>
-#include <errno.h>
+#include <rtems/seterr.h>
 #ifdef __cplusplus
 extern "C" {
@@ -61,26 +60,6 @@ RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Free (
   _Objects_Free( &_POSIX_Semaphore_Information, &the_semaphore->Object );
- *  @brief POSIX Semaphore Get
- *  This function maps semaphore IDs to semaphore control blocks.
- *  If ID corresponds to a local semaphore, then it returns
- *  the_semaphore control pointer which maps to ID and location
- *  is set to OBJECTS_LOCAL.  if the semaphore ID is global and
- *  resides on a remote node, then location is set to OBJECTS_REMOTE,
- *  and the_semaphore is undefined.  Otherwise, location is set
- *  to OBJECTS_ERROR and the_semaphore is undefined.
-RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Get (
-  sem_t             *id,
-  Objects_Locations *location
-  return (POSIX_Semaphore_Control *)
-    _Objects_Get( &_POSIX_Semaphore_Information, (Objects_Id)*id, location );
 _POSIX_Semaphore_Get_interrupt_disable(
   sem_t             *id,
@@ -116,7 +95,8 @@ int _POSIX_Semaphore_Create_support(
  * This routine supports the sem_close and sem_unlink routines.
 void _POSIX_Semaphore_Delete(
-  POSIX_Semaphore_Control *the_semaphore
+  POSIX_Semaphore_Control *the_semaphore,
+  ISR_lock_Context        *lock_context
diff --git a/cpukit/posix/src/semaphoredeletesupp.c b/cpukit/posix/src/semaphoredeletesupp.c
index 43946746..7c23bb8 100644
--- a/cpukit/posix/src/semaphoredeletesupp.c
+++ b/cpukit/posix/src/semaphoredeletesupp.c
@@ -18,25 +18,23 @@
 #include "config.h"
 #endif
-#include <stdarg.h>
-#include <errno.h>
-#include <fcntl.h>
-#include <pthread.h>
-#include <semaphore.h>
-#include <limits.h>
-#include <rtems/system.h>
 #include <rtems/posix/semaphoreimpl.h>
-#include <rtems/seterr.h>
   if ( !the_semaphore->linked && !the_semaphore->open_count ) {
     _Objects_Close( &_POSIX_Semaphore_Information, &the_semaphore->Object );
-    _CORE_semaphore_Destroy( &the_semaphore->Semaphore, NULL, 0 );
+    _CORE_semaphore_Destroy(
+      &the_semaphore->Semaphore,
+      NULL,
+      0,
+      lock_context
     _POSIX_Semaphore_Free( the_semaphore );
+  } else {
+    _CORE_semaphore_Release( &the_semaphore->Semaphore, lock_context );
diff --git a/cpukit/posix/src/semclose.c b/cpukit/posix/src/semclose.c
index f134dc4..1468c7f 100644
--- a/cpukit/posix/src/semclose.c
+++ b/cpukit/posix/src/semclose.c
@@ -18,17 +18,9 @@
 #include "config.h"
 #endif
-#include <errno.h>
-#include <fcntl.h>
 int sem_close(
   sem_t *sem
@@ -36,15 +28,23 @@ int sem_close(
   POSIX_Semaphore_Control          *the_semaphore;
   Objects_Locations                 location;
+  ISR_lock_Context                  lock_context;
   _Objects_Allocator_lock();
-  the_semaphore = _POSIX_Semaphore_Get( sem, &location );
+  the_semaphore = _POSIX_Semaphore_Get_interrupt_disable(
+    sem,
+    &location,
+    &lock_context
   switch ( location ) {
     case OBJECTS_LOCAL:
+      _CORE_semaphore_Acquire_critical(
+        &lock_context
       the_semaphore->open_count -= 1;
-      _POSIX_Semaphore_Delete( the_semaphore );
-      _Objects_Put( &the_semaphore->Object );
+      _POSIX_Semaphore_Delete( the_semaphore, &lock_context );
       _Objects_Allocator_unlock();
       return 0;
diff --git a/cpukit/posix/src/semdestroy.c b/cpukit/posix/src/semdestroy.c
index 896dece..7511699 100644
--- a/cpukit/posix/src/semdestroy.c
+++ b/cpukit/posix/src/semdestroy.c
@@ -18,17 +18,9 @@
 #include "config.h"
 #endif
-#include <errno.h>
-#include <fcntl.h>
 int sem_destroy(
   sem_t *sem
@@ -36,21 +28,30 @@ int sem_destroy(
+    sem,
+    &location,
+    &lock_context
     case OBJECTS_LOCAL:
+        &lock_context
        *  Undefined operation on a named semaphore. Release the object
        *  and fall to the EINVAL return at the bottom.
-      if ( the_semaphore->named == true ) {
+      if ( the_semaphore->named ) {
+        _CORE_semaphore_Release( &the_semaphore->Semaphore, &lock_context );
       } else {
         return 0;
diff --git a/cpukit/posix/src/semunlink.c b/cpukit/posix/src/semunlink.c
index b840618..665aa73 100644
--- a/cpukit/posix/src/semunlink.c
+++ b/cpukit/posix/src/semunlink.c
@@ -21,7 +21,6 @@
 int sem_unlink(
   const char *name
@@ -29,6 +28,7 @@ int sem_unlink(
   Objects_Get_by_name_error  error;
@@ -38,9 +38,12 @@ int sem_unlink(
     rtems_set_errno_and_return_minus_one( _POSIX_Get_by_name_error( error ) );
-  the_semaphore->linked = false;
   _POSIX_Semaphore_Namespace_remove( the_semaphore );
+  _ISR_lock_ISR_disable( &lock_context );
+  _CORE_semaphore_Acquire_critical( &the_semaphore->Semaphore, &lock_context );
+  the_semaphore->linked = false;
   return 0;
diff --git a/cpukit/rtems/src/semdelete.c b/cpukit/rtems/src/semdelete.c
index 48a9055..eebe88a 100644
--- a/cpukit/rtems/src/semdelete.c
+++ b/cpukit/rtems/src/semdelete.c
@@ -37,11 +37,16 @@ rtems_status_code rtems_semaphore_delete(
   rtems_attribute             attribute_set;
-  the_semaphore = _Semaphore_Get( id, &location );
+  the_semaphore = _Semaphore_Get_interrupt_disable(
+    id,
+    &location,
+    &lock_context
     case OBJECTS_LOCAL:
@@ -50,43 +55,50 @@ rtems_status_code rtems_semaphore_delete(
       if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
         MRSP_Status mrsp_status;
+        _MRSP_Acquire_critical(
+          &the_semaphore->Core_control.mrsp,
+          &lock_context
         mrsp_status = _MRSP_Can_destroy( &the_semaphore->Core_control.mrsp );
         if ( mrsp_status != MRSP_SUCCESSFUL ) {
+          _MRSP_Release(
+            &lock_context
           return _Semaphore_Translate_MRSP_status_code( mrsp_status );
       } else
 #endif
-      if (
-        !_Attributes_Is_counting_semaphore( attribute_set )
-          && _CORE_mutex_Is_locked( &the_semaphore->Core_control.mutex )
-          && !_Attributes_Is_simple_binary_semaphore( attribute_set )
-        _Objects_Allocator_unlock();
-        return RTEMS_RESOURCE_IN_USE;
-      _Objects_Close( &_Semaphore_Information, &the_semaphore->Object );
-#if defined(RTEMS_MULTIPROCESSING)
-      if ( _Attributes_Is_global( attribute_set ) ) {
-        _Objects_MP_Close( &_Semaphore_Information, the_semaphore->Object.id );
+      if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
+        _CORE_mutex_Acquire_critical(
+          &the_semaphore->Core_control.mutex,
+          &lock_context
-        _Semaphore_MP_Send_process_packet(
-          SEMAPHORE_MP_ANNOUNCE_DELETE,
-          the_semaphore->Object.id,
-          0,                         /* Not used */
-          0                          /* Not used */
+        if (
+          _CORE_mutex_Is_locked( &the_semaphore->Core_control.mutex )
+            && !_Attributes_Is_simple_binary_semaphore( attribute_set )
+          _CORE_mutex_Release(
+            &lock_context
+          _Objects_Allocator_unlock();
+          return RTEMS_RESOURCE_IN_USE;
+      } else {
+          &the_semaphore->Core_control.semaphore,
+          &lock_context
-#endif
+      _Objects_Close( &_Semaphore_Information, &the_semaphore->Object );
 #if defined(RTEMS_SMP)
-        _MRSP_Destroy( &the_semaphore->Core_control.mrsp );
+        _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &lock_context );
       } else
 #endif
@@ -94,18 +106,33 @@ rtems_status_code rtems_semaphore_delete(
           _CORE_mutex_Was_deleted,
           _Semaphore_MP_Send_object_was_deleted,
-          id
+          id,
+          &lock_context
         _CORE_mutex_Destroy( &the_semaphore->Core_control.mutex );
       } else {
-          id
+          id,
+          &lock_context
+#if defined(RTEMS_MULTIPROCESSING)
+      if ( _Attributes_Is_global( attribute_set ) ) {
+        _Objects_MP_Close( &_Semaphore_Information, id );
+        _Semaphore_MP_Send_process_packet(
+          SEMAPHORE_MP_ANNOUNCE_DELETE,
+          id,
+          0,                         /* Not used */
+          0                          /* Not used */
+#endif
       return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/semflush.c b/cpukit/rtems/src/semflush.c
index 01c5c0d..13dcf22 100644
--- a/cpukit/rtems/src/semflush.c
+++ b/cpukit/rtems/src/semflush.c
@@ -37,39 +37,52 @@ rtems_status_code rtems_semaphore_flush(
+    id,
+    &location,
+    &lock_context
     case OBJECTS_LOCAL:
       attribute_set = the_semaphore->attribute_set;
+        _ISR_lock_ISR_enable( &lock_context );
         return RTEMS_NOT_DEFINED;
       } else
 #endif
+          &lock_context
         _CORE_mutex_Flush(
           _CORE_mutex_Unsatisfied_nowait,
-          id
+          id,
+          &lock_context
       } else {
+          &lock_context
         _CORE_semaphore_Flush(
-          id
+          id,
+          &lock_context
     case OBJECTS_REMOTE:
-      _Thread_Dispatch();
       return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
 #endif
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index 73331a5..49404ce 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -355,23 +355,17 @@ Thread_Control *_CORE_mutex_Unsatisfied_nowait(
   the_mutex, \
   filter, \
   mp_callout, \
-  mp_id \
+  mp_id, \
+  lock_context \
-  do { \
-    ISR_lock_Context _core_mutex_flush_lock_context; \
-    _Thread_queue_Acquire( \
-      &( the_mutex )->Wait_queue, \
-      &_core_mutex_flush_lock_context \
-    _Thread_queue_Flush_critical( \
-      &( the_mutex )->Wait_queue.Queue, \
-      ( the_mutex )->operations, \
-      filter, \
-      mp_callout, \
-      mp_id, \
-  } while ( 0 )
+  _Thread_queue_Flush_critical( \
+    &( the_mutex )->Wait_queue.Queue, \
+    ( the_mutex )->operations, \
+    filter, \
+    mp_callout, \
+    mp_id, \
+    lock_context \
  * @brief Is mutex locked.
diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
index fd01f93..bc17406 100644
--- a/cpukit/score/include/rtems/score/coresemimpl.h
+++ b/cpukit/score/include/rtems/score/coresemimpl.h
@@ -86,6 +86,22 @@ void _CORE_semaphore_Initialize(
   uint32_t                    initial_value
+RTEMS_INLINE_ROUTINE void _CORE_semaphore_Acquire_critical(
+  CORE_semaphore_Control *the_semaphore,
+  _Thread_queue_Acquire_critical( &the_semaphore->Wait_queue, lock_context );
+RTEMS_INLINE_ROUTINE void _CORE_semaphore_Release(
+  _Thread_queue_Release( &the_semaphore->Wait_queue, lock_context );
 Thread_Control *_CORE_semaphore_Was_deleted(
   Thread_Control     *the_thread,
   Thread_queue_Queue *queue,
@@ -101,21 +117,17 @@ Thread_Control *_CORE_semaphore_Unsatisfied_nowait(
 #define _CORE_semaphore_Destroy( \
   the_semaphore, \
   mp_callout, \
-  mp_id \
+  mp_id, \
+  lock_context \
   do { \
-    ISR_lock_Context _core_semaphore_destroy_lock_context; \
-      &( the_semaphore )->Wait_queue, \
-      &_core_semaphore_destroy_lock_context \
       &( the_semaphore )->Wait_queue.Queue, \
       ( the_semaphore )->operations, \
       _CORE_semaphore_Was_deleted, \
       mp_callout, \
       mp_id, \
+      lock_context \
     _Thread_queue_Destroy( &( the_semaphore )->Wait_queue ); \
   } while ( 0 )
@@ -134,7 +146,7 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
   status = CORE_SEMAPHORE_STATUS_SUCCESSFUL;
-  _Thread_queue_Acquire_critical( &the_semaphore->Wait_queue, lock_context );
+  _CORE_semaphore_Acquire_critical( the_semaphore, lock_context );
   the_thread = _Thread_queue_First_locked(
@@ -155,7 +167,7 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
     else
       status = CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED;
-    _Thread_queue_Release( &the_semaphore->Wait_queue, lock_context );
+    _CORE_semaphore_Release( the_semaphore, lock_context );
   return status;
@@ -208,21 +220,17 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
 #define _CORE_semaphore_Flush( \
   the_semaphore, \
   mp_callout, \
-  mp_id \
+  mp_id, \
+  lock_context \
   do { \
-    ISR_lock_Context _core_semaphore_flush_lock_context; \
-      &_core_semaphore_flush_lock_context \
       _CORE_semaphore_Unsatisfied_nowait, \
       mp_callout, \
       mp_id, \
+      lock_context \
   } while ( 0 )
@@ -268,15 +276,15 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize(
   /* disabled when you get here */
   executing->Wait.return_code = CORE_SEMAPHORE_STATUS_SUCCESSFUL;
   if ( the_semaphore->count != 0 ) {
     the_semaphore->count -= 1;
     return;
   if ( !wait ) {
     executing->Wait.return_code = CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT;
     return;
diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
index 1529b1a..1be3202 100644
--- a/cpukit/score/include/rtems/score/mrspimpl.h
+++ b/cpukit/score/include/rtems/score/mrspimpl.h
@@ -53,6 +53,22 @@ RTEMS_INLINE_ROUTINE void _MRSP_Giant_release( ISR_lock_Context *lock_context )
   _ISR_lock_Release( &_Scheduler_Lock, lock_context );
+RTEMS_INLINE_ROUTINE void _MRSP_Acquire_critical(
+  MRSP_Control     *mrsp,
+  _ISR_lock_Acquire( &mrsp->Lock, lock_context );
+RTEMS_INLINE_ROUTINE void _MRSP_Release(
+  _ISR_lock_Release_and_ISR_enable( &mrsp->Lock, lock_context );
 RTEMS_INLINE_ROUTINE bool _MRSP_Restore_priority_filter(
   Thread_Control   *thread,
   Priority_Control *new_priority,
@@ -103,7 +119,7 @@ RTEMS_INLINE_ROUTINE void _MRSP_Claim_ownership(
   _Scheduler_Thread_change_help_state( new_owner, SCHEDULER_HELP_ACTIVE_OWNER );
   cpu_self = _Thread_Dispatch_disable_critical( lock_context );
-  _ISR_lock_Release_and_ISR_enable( &mrsp->Lock, lock_context );
+  _MRSP_Release( mrsp, lock_context );
   _Thread_Raise_priority( new_owner, ceiling_priority );
@@ -166,7 +182,8 @@ RTEMS_INLINE_ROUTINE void _MRSP_Timeout( Watchdog_Control *watchdog )
   Thread_Control *thread = rival->thread;
-  _ISR_lock_ISR_disable_and_acquire( &mrsp->Lock, &lock_context );
+  _MRSP_Acquire_critical( mrsp, &lock_context );
   if ( rival->status == MRSP_WAIT_FOR_OWNERSHIP ) {
     ISR_lock_Context giant_lock_context;
@@ -183,9 +200,9 @@ RTEMS_INLINE_ROUTINE void _MRSP_Timeout( Watchdog_Control *watchdog )
     rival->status = MRSP_TIMEOUT;
-    _ISR_lock_Release_and_ISR_enable( &mrsp->Lock, &lock_context );
+    _MRSP_Release( mrsp, &lock_context );
   } else {
@@ -227,7 +244,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
   _MRSP_Giant_release( &giant_lock_context );
   _Thread_Raise_priority( executing, ceiling_priority );
@@ -293,7 +310,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
     return MRSP_INVALID_PRIORITY;
-  _ISR_lock_Acquire( &mrsp->Lock, lock_context );
+  _MRSP_Acquire_critical( mrsp, lock_context );
   owner = _Resource_Get_owner( &mrsp->Resource );
   if ( owner == NULL ) {
@@ -318,7 +335,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
       lock_context
   } else {
     /* Not available, nested access or deadlock */
     status = MRSP_UNSATISFIED;
@@ -353,7 +370,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
   initial_priority = mrsp->initial_priority_of_owner;
   _MRSP_Giant_acquire( &giant_lock_context );
@@ -389,7 +406,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
   _MRSP_Restore_priority( executing, initial_priority );
@@ -407,8 +424,12 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Can_destroy( MRSP_Control *mrsp )
   return MRSP_SUCCESSFUL;
-RTEMS_INLINE_ROUTINE void _MRSP_Destroy( MRSP_Control *mrsp )
+RTEMS_INLINE_ROUTINE void _MRSP_Destroy(
   _ISR_lock_Destroy( &mrsp->Lock );
   _Workspace_Free( mrsp->ceiling_priorities );
1.8.4.5
