Provide POSIX network header for all normal Newlib targets?
Sebastian Huber
Thu Apr 21 10:12:12 UTC 2016
Hello,
with the recent type changes for <sys/types.h> etc. we are now able to
build the FreeBSD 9.3 network stack on RTEMS. We directly use
* <machine/endian.h>,
* <sys/_stdint.h>,
* <sys/time.h>,
* <sys/_timespec.h>,
* <sys/_timeval.h>,
* <sys/_types.h>, and
* <sys/types.h>
from Newlib with mostly unmodified FreeBSD header and source files.
Cygwin and Linux provide currently their own set of network header files
in Newlib. RTEMS has its own sets outside of Newlib. Since the Linux
port is a bit special I don't consider it here. I think for the other
Newlib targets it may be beneficial to provide at least the POSIX
* <arpa/inet.h>,
* <netdb.h>,
* <net/if.h>,
* <netinet/in.h>,
* <netinet/tcp.h>,
* <syslog.h>,
* <sys/socket.h>,
* <sys/uio.h>, and
* <sys/un.h>
in Newlib. It has the advantage that Newlib users get a consistent set
of POSIX network header files with compatibility to FreeBSD. Since there
are a lot of software packages available for Cygwin it would be quite
nice for the smaller embedded systems targets to share header files with
Cygwin.
My approach would be to import the latest network header files from
FreeBSD. Then remove all #ifdef _KERNEL parts and use an #include
<machine/XZY.h> to provide machine-specific stuff for each header file,
e.g. <machine/socket.h>, <machine/in.h>. Keep the #ifndef _KERNEL parts
for FreeBSD compatibility.
I only roughly looked at the Cygwin network headers, but it would be a
bit of work to import the latest network headers from FreeBSD and use
them in Cygwin, e.g. deal with __INSIDE_CYGWIN_NET__.
How do you think about this?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
