[PATCH 00/13] Replace mongoose with civetweb.
Fri Apr 22 00:36:51 UTC 2016
On 21/04/2016 18:49, Christian Mauderer wrote:
> This patch series replaces the mongoose webserver by its still MIT
> licensed fork civetweb.
> Please note that I try to get some (currently two) of the patches
> directly into civetweb too. But I think that it might need some time and
> adaption till they are accepted. So I thought that adding them to RTEMS
> would still make sense as a working interim solution.
Would we be better served by providing this as an external 3rd party
package via the RSB and we remove the code or add a configure disable?
The package could be used by both stacks.
We have plans to remove the existing stack from the source tree and to
make a separate package and I guess at that point in time all dependent
client networking code in the source tree will also need to be removed.
