build failed: cpukit/posix/src/conddefaultattributes.c
Joel Sherrill
joel at rtems.org
Sat Apr 23 13:04:35 UTC 2016
The tools have been updating pretty regularly. This means your tools are
old. Update the RSB and build me tools.
Between gcc and newlib activity, we have been bumping them every few weeks.
One at the first of March added new POSIX methods and condition variable
attributes.
--joel
On Apr 23, 2016 6:50 AM, "printk" <opentkernel at 163.com> wrote:
Hi, I followed this to build the bsp, arm920
be built to target the BOARD_SUPPORT_PACKAGE board.
mkdir build-rtems
cd build-rtems
../rtems-4.10.0/configure --target=<TARGET_CONFIGURATION> \
--disable-posix --disable-networking --disable-cxx \
--enable-rtemsbsp=<BOARD_SUPPORT_PACKAGE>\
--prefix=<INSTALL_POINT>
make all
make install
$ cd rtems
$ mkdir arm920
$ cd arm920
$ ../configure --target=arm-rtems4.12
$ make RTEMS_BSP="arm920"
it fails here:
arm-rtems4.12-gcc --pipe -DHAVE_CONFIG_H -I..
-I../../cpukit/../../../arm920/lib/include -mcpu=arm920 -O2 -g
-ffunction-sections -fdata-sections -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
src/libposix_a-conddefaultattributes.o -MD -MP -MF
src/.deps/libposix_a-conddefaultattributes.Tpo -c -o
src/libposix_a-conddefaultattributes.o `test -f
'src/conddefaultattributes.c' || echo
'../../../../../../c/src/../../cpukit/posix/'`src/conddefaultattributes.c
../../../../../../c/src/../../cpukit/posix/src/conddefaultattributes.c:31:3:
error: unknown field 'clock' specified in initializer
.clock = CLOCK_REALTIME,
I find this breaks many other bsps too, I comment this line out, then I can
compile all other arm bsps.(about 20hours, 20G :D)
did I do something wrong?
btw, there are many sources include this file
#include <sys/tree.h>
but i can not find this file by:
find -name tree.h
where is this file?
duhuanpeng
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160423/8f557080/attachment.html>
