build failed: cpukit/posix/src/conddefaultattributes.c
Joel Sherrill
joel at rtems.org
Sat Apr 23 15:08:31 UTC 2016
On Apr 23, 2016 9:43 AM, "printk" <opentkernel at 163.com> wrote:
> On Sat, Apr 23, 2016 at 08:04:35AM -0500, Joel Sherrill wrote:
> > The tools have been updating pretty regularly. This means your tools are
> > old. Update the RSB and build me tools.
> sorry, i forgot to attach my gcc version, it was built some days ago:
> rtems at book64:~$ arm-rtems4.12-gcc --version
> arm-rtems4.12-gcc (GCC) 6.0.0 20160124 (RTEMS 4.12, RSB
662c2e73028a8a8ac293d295a04629312f4f6e5a-modified, Newlib 2.3.0.20160104)
> Copyright (C) 2016 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Yes. I add this change in February and bumped the tools then. I didn't add
code which used it until late March or April.
> rtems at book64:~$ arm-rtems4.12-gcc -v
> Using built-in specs.
> COLLECT_GCC=arm-rtems4.12-gcc
COLLECT_LTO_WRAPPER=/home/du/dev/rtems/4.12/libexec/gcc/arm-rtems4.12/6.0.0/lto-wrapper
> Target: arm-rtems4.12
> Configured with: ../gcc-6-20160124/configure
--prefix=/home/du/dev/rtems/4.12 --bindir=/home/du/dev/rtems/4.12/bin
--exec_prefix=/home/du/dev/rtems/4.12
--includedir=/home/du/dev/rtems/4.12/include
--libdir=/home/du/dev/rtems/4.12/lib
--libexecdir=/home/du/dev/rtems/4.12/libexec
--mandir=/home/du/dev/rtems/4.12/share/man
--infodir=/home/du/dev/rtems/4.12/share/info
--datadir=/home/du/dev/rtems/4.12/share --build=x86_64-linux-gnu
--host=x86_64-linux-gnu --target=arm-rtems4.12 --disable-libstdcxx-pch
--with-gnu-as --with-gnu-ld --verbose --with-newlib --with-system-zlib
--disable-nls --without-included-gettext --disable-win32-registry
--enable-version-specific-runtime-libs --disable-lto
--enable-newlib-io-c99-formats --enable-newlib-iconv
--enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,win_1253,win_1254,win_1255,win_1256,win_1257,win_1258
--enable-threads --disable-plugin --enable-libgomp --enable-languages=c,c++
> Thread model: rtems
> gcc version 6.0.0 20160124 (RTEMS 4.12, RSB
(GCC)
> rtems at book64:~$
> it is this toolchain too old?
> > Between gcc and newlib activity, we have been bumping them every few
weeks.
> > One at the first of March added new POSIX methods and condition variable
> > attributes.
> I will build a new one and try again. :D, it will take anther day to
built it again.
> > --joel
> thanks very much!
> > On Apr 23, 2016 6:50 AM, "printk" <opentkernel at 163.com> wrote:
> > Hi, I followed this to build the bsp, arm920
> > be built to target the BOARD_SUPPORT_PACKAGE board.
> > mkdir build-rtems
> > cd build-rtems
> > ../rtems-4.10.0/configure --target=<TARGET_CONFIGURATION> \
> > --disable-posix --disable-networking --disable-cxx \
> > --enable-rtemsbsp=<BOARD_SUPPORT_PACKAGE>\
> > --prefix=<INSTALL_POINT>
> > make all
> > make install
> > $ cd rtems
> > $ mkdir arm920
> > $ cd arm920
> > $ ../configure --target=arm-rtems4.12
> > $ make RTEMS_BSP="arm920"
> > it fails here:
> > arm-rtems4.12-gcc --pipe -DHAVE_CONFIG_H -I..
> > -I../../cpukit/../../../arm920/lib/include -mcpu=arm920 -O2 -g
> > -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes
> > -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
> > src/libposix_a-conddefaultattributes.o -MD -MP -MF
> > src/.deps/libposix_a-conddefaultattributes.Tpo -c -o
> > src/libposix_a-conddefaultattributes.o `test -f
> > 'src/conddefaultattributes.c' || echo
'../../../../../../c/src/../../cpukit/posix/'`src/conddefaultattributes.c
../../../../../../c/src/../../cpukit/posix/src/conddefaultattributes.c:31:3:
> > error: unknown field 'clock' specified in initializer
> > .clock = CLOCK_REALTIME,
> > I find this breaks many other bsps too, I comment this line out, then I
can
> > compile all other arm bsps.(about 20hours, 20G :D)
> > did I do something wrong?
> > btw, there are many sources include this file
> > #include <sys/tree.h>
> > but i can not find this file by:
> > find -name tree.h
> > where is this file?
> > duhuanpeng
> > devel mailing list
> > devel at rtems.org
> duhuanpeng.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160423/4ae64056/attachment-0001.html>
