[PATCH] posix: Avoid Giant lock for condition variables
Mon Apr 25 06:19:52 UTC 2016
Update #2555.
 cpukit/posix/include/rtems/posix/cond.h          |   3 +-
 cpukit/posix/include/rtems/posix/condimpl.h      |  52 +++++--
 cpukit/posix/include/rtems/posix/muteximpl.h     |  10 ++
 cpukit/posix/src/conddestroy.c                   |  55 +++----
 cpukit/posix/src/condget.c                       |  62 ++++----
 cpukit/posix/src/condinit.c                      |  12 +-
 cpukit/posix/src/condsignalsupp.c                |  60 ++++----
 cpukit/posix/src/condwaitsupp.c                  | 187 ++++++++++++-----------
 cpukit/score/include/rtems/score/coremuteximpl.h |   8 +
 9 files changed, 239 insertions(+), 210 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/cond.h b/cpukit/posix/include/rtems/posix/cond.h
index 1839279..4fa7de7 100644
--- a/cpukit/posix/include/rtems/posix/cond.h
+++ b/cpukit/posix/include/rtems/posix/cond.h
@@ -43,8 +43,7 @@ extern "C" {
 typedef struct {
    Objects_Control       Object;
    Thread_queue_Control  Wait_queue;
-   int                   process_shared;
-   pthread_mutex_t       Mutex;
+   pthread_mutex_t       mutex;
 }  POSIX_Condition_variables_Control;
 #ifdef __cplusplus
diff --git a/cpukit/posix/include/rtems/posix/condimpl.h b/cpukit/posix/include/rtems/posix/condimpl.h
index b079a43..b178869 100644
--- a/cpukit/posix/include/rtems/posix/condimpl.h
+++ b/cpukit/posix/include/rtems/posix/condimpl.h
@@ -20,7 +20,8 @@
 #include <rtems/posix/cond.h>
-#include <rtems/score/watchdog.h>
+#include <errno.h>
 #ifdef __cplusplus
 extern "C" {
@@ -45,6 +46,37 @@ extern Objects_Information _POSIX_Condition_variables_Information;
 extern const pthread_condattr_t _POSIX_Condition_variables_Default_attributes;
+RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Initialize(
+  POSIX_Condition_variables_Control *the_cond
+  _Thread_queue_Initialize( &the_cond->Wait_queue );
+  the_cond->mutex = POSIX_CONDITION_VARIABLES_NO_MUTEX;
+RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Destroy(
+  _Thread_queue_Destroy( &the_cond->Wait_queue );
+RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Acquire_critical(
+  POSIX_Condition_variables_Control *the_cond,
+  ISR_lock_Context                  *lock_context
+  _Thread_queue_Acquire_critical( &the_cond->Wait_queue, lock_context );
+RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Release(
+  _Thread_queue_Release( &the_cond->Wait_queue, lock_context );
  *  @brief POSIX Condition Variable Allocate
@@ -68,27 +100,15 @@ RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Free (
   POSIX_Condition_variables_Control *the_condition_variable
-  _Thread_queue_Destroy( &the_condition_variable->Wait_queue );
   _Objects_Free(
     &_POSIX_Condition_variables_Information,
     &the_condition_variable->Object
- *  @brief POSIX Condition Variable Get
- *  This function maps condition variable IDs to condition variable control
- *  blocks.  If ID corresponds to a local condition variable, then it returns
- *  the_condition variable control pointer which maps to ID and location
- *  is set to OBJECTS_LOCAL.  if the condition variable ID is global and
- *  resides on a remote node, then location is set to OBJECTS_REMOTE,
- *  and the_condition variable is undefined.  Otherwise, location is set
- *  to OBJECTS_ERROR and the_condition variable is undefined.
-POSIX_Condition_variables_Control *_POSIX_Condition_variables_Get (
-  pthread_cond_t    *cond,
-  Objects_Locations *location
+POSIX_Condition_variables_Control *_POSIX_Condition_variables_Get(
+  pthread_cond_t   *cond,
diff --git a/cpukit/posix/include/rtems/posix/muteximpl.h b/cpukit/posix/include/rtems/posix/muteximpl.h
index fb30d58..6d21e96 100644
--- a/cpukit/posix/include/rtems/posix/muteximpl.h
+++ b/cpukit/posix/include/rtems/posix/muteximpl.h
@@ -131,6 +131,16 @@ POSIX_Mutex_Control *_POSIX_Mutex_Get_interrupt_disable(
+RTEMS_INLINE_ROUTINE POSIX_Mutex_Control *_POSIX_Mutex_Get_no_protection(
+  const pthread_mutex_t *mutex
+  return (POSIX_Mutex_Control *) _Objects_Get_no_protection(
+    (Objects_Id) *mutex,
+    &_POSIX_Mutex_Information
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/posix/src/conddestroy.c b/cpukit/posix/src/conddestroy.c
index c6696f5..d47c6b2 100644
--- a/cpukit/posix/src/conddestroy.c
+++ b/cpukit/posix/src/conddestroy.c
@@ -18,13 +18,7 @@
 #include "config.h"
 #endif
-#include <pthread.h>
-#include <errno.h>
-#include <rtems/system.h>
 #include <rtems/posix/condimpl.h>
-#include <rtems/posix/muteximpl.h>
  *  11.4.2 Initializing and Destroying a Condition Variable,
@@ -35,42 +29,31 @@ int pthread_cond_destroy(
   POSIX_Condition_variables_Control *the_cond;
-  Objects_Locations                  location;
+  ISR_lock_Context                   lock_context;
   _Objects_Allocator_lock();
-  the_cond = _POSIX_Condition_variables_Get( cond, &location );
-  switch ( location ) {
-    case OBJECTS_LOCAL:
+  the_cond = _POSIX_Condition_variables_Get( cond, &lock_context );
-      if (
-        _Thread_queue_First(
-          &the_cond->Wait_queue,
-          POSIX_CONDITION_VARIABLES_TQ_OPERATIONS
-        _Objects_Put( &the_cond->Object );
-        _Objects_Allocator_unlock();
-        return EBUSY;
+  if ( the_cond == NULL ) {
+    _Objects_Allocator_unlock();
+    return EINVAL;
-      _Objects_Close(
-        &_POSIX_Condition_variables_Information,
-        &the_cond->Object
-      _POSIX_Condition_variables_Free( the_cond );
-      return 0;
+  _POSIX_Condition_variables_Acquire_critical( the_cond, &lock_context );
-#if defined(RTEMS_MULTIPROCESSING)
-    case OBJECTS_REMOTE:
-#endif
-    case OBJECTS_ERROR:
-      break;
+  if ( !_Thread_queue_Is_empty( &the_cond->Wait_queue.Queue ) ) {
+    _POSIX_Condition_variables_Release( the_cond, &lock_context );
+    return EBUSY;
+  _Objects_Close(
+    &_POSIX_Condition_variables_Information,
+    &the_cond->Object
+  _POSIX_Condition_variables_Destroy( the_cond );
+  _POSIX_Condition_variables_Free( the_cond );
-  return EINVAL;
+  return 0;
diff --git a/cpukit/posix/src/condget.c b/cpukit/posix/src/condget.c
index 6ebba73..e3cf59c 100644
--- a/cpukit/posix/src/condget.c
+++ b/cpukit/posix/src/condget.c
@@ -11,45 +11,49 @@
 #include "config.h"
 #endif
-#include <errno.h>
+static bool _POSIX_Condition_variables_Check_id_and_auto_init(
-  int status;
-  if ( !cond ) {
-    *location = OBJECTS_ERROR;
-    return (POSIX_Condition_variables_Control *) 0;
+  if ( cond == NULL ) {
+    return false;
   if ( *cond == PTHREAD_COND_INITIALIZER ) {
-     *  Do an "auto-create" here.
-    status = pthread_cond_init( cond, 0 );
-    if ( status ) {
+    int eno;
+    _Once_Lock();
+    if ( *cond == PTHREAD_COND_INITIALIZER ) {
+      eno = pthread_cond_init( cond, NULL );
+    } else {
+      eno = 0;
+    _Once_Unlock();
+    if ( eno != 0 ) {
+      return false;
-   *  Now call Objects_Get()
-  return (POSIX_Condition_variables_Control *)_Objects_Get(
+  return true;
+  if ( !_POSIX_Condition_variables_Check_id_and_auto_init( cond ) ) {
+    return NULL;
+  return (POSIX_Condition_variables_Control *) _Objects_Get_local(
     (Objects_Id) *cond,
-    location
+    lock_context
diff --git a/cpukit/posix/src/condinit.c b/cpukit/posix/src/condinit.c
index f4aeae6..dde400f 100644
--- a/cpukit/posix/src/condinit.c
+++ b/cpukit/posix/src/condinit.c
@@ -18,13 +18,7 @@
 #include "config.h"
 #endif
-#include <errno.h>
@@ -57,11 +51,7 @@ int pthread_cond_init(
     return ENOMEM;
-  the_cond->process_shared  = the_attr->process_shared;
-  the_cond->Mutex = POSIX_CONDITION_VARIABLES_NO_MUTEX;
-  _Thread_queue_Initialize( &the_cond->Wait_queue );
+  _POSIX_Condition_variables_Initialize( the_cond );
   _Objects_Open_u32(
diff --git a/cpukit/posix/src/condsignalsupp.c b/cpukit/posix/src/condsignalsupp.c
index 9c67ddc..c625b3a 100644
--- a/cpukit/posix/src/condsignalsupp.c
+++ b/cpukit/posix/src/condsignalsupp.c
@@ -18,13 +18,7 @@
 #include "config.h"
 #endif
-#include <errno.h>
  *  _POSIX_Condition_variables_Signal_support
@@ -38,35 +32,39 @@ int _POSIX_Condition_variables_Signal_support(
   bool                       is_broadcast
-  POSIX_Condition_variables_Control          *the_cond;
-  Thread_Control                             *the_thread;
+  Thread_Control *the_thread;
+  do {
+    POSIX_Condition_variables_Control *the_cond;
-      do {
-        the_thread = _Thread_queue_Dequeue(
-          POSIX_CONDITION_VARIABLES_TQ_OPERATIONS,
-          NULL,
-          0
-        if ( !the_thread )
-      } while ( is_broadcast && the_thread );
+      return EINVAL;
-      return 0;
-#endif
-      break;
+    the_thread = _Thread_queue_First_locked(
+      &the_cond->Wait_queue,
+      POSIX_CONDITION_VARIABLES_TQ_OPERATIONS
+    if ( the_thread != NULL ) {
+      _Thread_queue_Extract_critical(
+        &the_cond->Wait_queue.Queue,
+        POSIX_CONDITION_VARIABLES_TQ_OPERATIONS,
+        the_thread,
+        NULL,
+        0,
+        &lock_context
+    } else {
+  } while ( is_broadcast && the_thread != NULL );
-  return EINVAL;
+  return 0;
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index c907f16..aa320e8 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -18,15 +18,11 @@
 #include "config.h"
 #endif
-#include <errno.h>
-#include <rtems/score/statesimpl.h>
-#include <rtems/score/threadimpl.h>
+#include <rtems/score/assert.h>
+#include <rtems/score/statesimpl.h>
+#include <rtems/score/threadimpl.h>
 THREAD_WAIT_QUEUE_OBJECT_ASSERT(
   POSIX_Condition_variables_Control,
@@ -41,88 +37,109 @@ int _POSIX_Condition_variables_Wait_support(
+  POSIX_Mutex_Control               *the_mutex;
   int                                status;
   int                                mutex_status;
+  CORE_mutex_Status                  core_mutex_status;
+  Per_CPU_Control                   *cpu_self;
   Thread_Control                    *executing;
-      if ( the_cond->Mutex && ( the_cond->Mutex != *mutex ) ) {
-        return EINVAL;
-      mutex_status = pthread_mutex_unlock( mutex );
-       *  Historically, we ignored the return code since the behavior
-       *  is undefined by POSIX. But GNU/Linux returns EPERM in this
-       *  case, so we follow their lead.
-      if ( mutex_status ) {
-        return EPERM;
-      if ( !already_timedout ) {
-        the_cond->Mutex = *mutex;
-        executing = _Thread_Executing;
-        executing->Wait.return_code = 0;
-        _Thread_queue_Enqueue(
-          executing,
-          STATES_WAITING_FOR_CONDITION_VARIABLE
-            | STATES_INTERRUPTIBLE_BY_SIGNAL,
-          timeout,
-          ETIMEDOUT
-         *  Switch ourself out because we blocked as a result of the
-         *  _Thread_queue_Enqueue.
-         *  If the thread is interrupted, while in the thread queue, by
-         *  a POSIX signal, then pthread_cond_wait returns spuriously,
-         *  according to the POSIX standard. It means that pthread_cond_wait
-         *  returns a success status, except for the fact that it was not
-         *  woken up a pthread_cond_signal or a pthread_cond_broadcast.
-        status = executing->Wait.return_code;
-        if ( status == EINTR )
-          status = 0;
-      } else {
-        status = ETIMEDOUT;
-       *  When we get here the dispatch disable level is 0.
-      mutex_status = pthread_mutex_lock( mutex );
-        return EINVAL;
-      return status;
-#endif
-      break;
+  if ( mutex == NULL ) {
+    return EINVAL;
+    return EINVAL;
+  if (
+    the_cond->mutex != POSIX_CONDITION_VARIABLES_NO_MUTEX
+      && the_cond->mutex != *mutex
+    return EINVAL;
+  the_cond->mutex = *mutex;
+  cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
+  executing = _Per_CPU_Get_executing( cpu_self );
+   *  Historically, we ignored the unlock status since the behavior
+   *  is undefined by POSIX. But GNU/Linux returns EPERM in this
+   *  case, so we follow their lead.
+  the_mutex = _POSIX_Mutex_Get_no_protection( mutex );
+  if (
+    the_mutex == NULL
+      || !_CORE_mutex_Is_owner( &the_mutex->Mutex, executing )
+    return EPERM;
+  if ( !already_timedout ) {
+    executing->Wait.return_code = 0;
+    _Thread_queue_Enqueue_critical(
+      executing,
+      STATES_WAITING_FOR_CONDITION_VARIABLE,
+      timeout,
+      ETIMEDOUT,
+      &lock_context
+  } else {
+    executing->Wait.return_code = ETIMEDOUT;
+  _ISR_lock_ISR_disable( &lock_context );
+  core_mutex_status = _CORE_mutex_Surrender(
+    &the_mutex->Mutex,
+    NULL,
+    0,
+    &lock_context
+  _Assert( core_mutex_status == CORE_MUTEX_STATUS_SUCCESSFUL );
+  (void) core_mutex_status;
+   *  Switch ourself out because we blocked as a result of the
+   *  _Thread_queue_Enqueue_critical().
+  _Thread_Dispatch_enable( cpu_self );
+  status = (int) executing->Wait.return_code;
+   *  If the thread is interrupted, while in the thread queue, by
+   *  a POSIX signal, then pthread_cond_wait returns spuriously,
+   *  according to the POSIX standard. It means that pthread_cond_wait
+   *  returns a success status, except for the fact that it was not
+   *  woken up a pthread_cond_signal() or a pthread_cond_broadcast().
+  if ( status == EINTR ) {
+    status = 0;
+   *  When we get here the dispatch disable level is 0.
+  mutex_status = pthread_mutex_lock( mutex );
+  if ( mutex_status != 0 ) {
+    return EINVAL;
-  return EINVAL;
+  return status;
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index 49404ce..4b144e8 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -385,6 +385,14 @@ RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_locked(
   return the_mutex->holder != NULL;
+RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_owner(
+  const CORE_mutex_Control *the_mutex,
+  const Thread_Control     *the_thread
+  return the_mutex->holder == the_thread;
  * @brief Does core mutex use FIFO blocking.
1.8.4.5
