[PATCH 15/29] libnetworking: Add IP_NAT option for get/setsockopt.
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Apr 25 15:06:49 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 cpukit/libnetworking/rtems/rtems_netinet_in.h | 8 ++++++++
 1 file changed, 8 insertions(+)
diff --git a/cpukit/libnetworking/rtems/rtems_netinet_in.h b/cpukit/libnetworking/rtems/rtems_netinet_in.h
index 477cd99..c2da532 100644
--- a/cpukit/libnetworking/rtems/rtems_netinet_in.h
+++ b/cpukit/libnetworking/rtems/rtems_netinet_in.h
@@ -50,6 +50,14 @@ extern	ip_nat_ctl_t *ip_nat_ctl_ptr;
 #define	IP_NAT_IN	0x00000001
 #define	IP_NAT_OUT	0x00000002
+ * Options for use with [gs]etsockopt at the IP level.
+ * The value is stored in an integer. Use negative numbers to avoid conflicts
+ * with BSD.
+#define IP_NAT			(-55)   /* set/get NAT opts */
 #ifdef __cplusplus
 #endif /* __cplusplus */
1.8.4.5
