[PATCH 13/29] libnetworking: Add ip_fw_chk_t and ip_fw_ctl_t.
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Apr 25 15:06:47 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
Add the types and pointers for firewall.
 cpukit/libnetworking/netinet/ip_fw.c          | 1 +
 cpukit/libnetworking/netinet/ip_input.c       | 1 +
 cpukit/libnetworking/netinet/ip_output.c      | 1 +
 cpukit/libnetworking/netinet/raw_ip.c         | 1 +
 cpukit/libnetworking/rtems/rtems_netinet_in.h | 8 ++++++++
 5 files changed, 12 insertions(+)
diff --git a/cpukit/libnetworking/netinet/ip_fw.c b/cpukit/libnetworking/netinet/ip_fw.c
index 9063b39..ee62e47 100644
--- a/cpukit/libnetworking/netinet/ip_fw.c
+++ b/cpukit/libnetworking/netinet/ip_fw.c
@@ -38,6 +38,7 @@
 #include <rtems/rtems_net_if.h>
 #include <net/route.h>
 #include <netinet/in.h>
+#include <rtems/rtems_netinet_in.h>
 #include <netinet/in_systm.h>
 #include <netinet/ip.h>
 #include <netinet/ip_var.h>
diff --git a/cpukit/libnetworking/netinet/ip_input.c b/cpukit/libnetworking/netinet/ip_input.c
index 74cc2cb..65eaa07 100644
--- a/cpukit/libnetworking/netinet/ip_input.c
+++ b/cpukit/libnetworking/netinet/ip_input.c
@@ -60,6 +60,7 @@
 #include <net/netisr.h>
 #include <netinet/in_var.h>
diff --git a/cpukit/libnetworking/netinet/ip_output.c b/cpukit/libnetworking/netinet/ip_output.c
index db81ccb..304a349 100644
--- a/cpukit/libnetworking/netinet/ip_output.c
+++ b/cpukit/libnetworking/netinet/ip_output.c
@@ -51,6 +51,7 @@
 #include <netinet/in_pcb.h>
diff --git a/cpukit/libnetworking/netinet/raw_ip.c b/cpukit/libnetworking/netinet/raw_ip.c
index 746aed1..7647b8c 100644
--- a/cpukit/libnetworking/netinet/raw_ip.c
+++ b/cpukit/libnetworking/netinet/raw_ip.c
@@ -54,6 +54,7 @@
 #define _IP_VHL
diff --git a/cpukit/libnetworking/rtems/rtems_netinet_in.h b/cpukit/libnetworking/rtems/rtems_netinet_in.h
index 3c716df..3940d92 100644
--- a/cpukit/libnetworking/rtems/rtems_netinet_in.h
+++ b/cpukit/libnetworking/rtems/rtems_netinet_in.h
@@ -16,6 +16,7 @@
 #define RTEMS_NETINET_IN_H
+#include <netinet/in.h>
 #ifdef __cplusplus
 extern "C" {
@@ -34,6 +35,13 @@ extern "C" {
 int	 in_cksum(struct mbuf *, int);
+/* Firewall hooks */
+struct ip;
+typedef	int ip_fw_chk_t(struct ip**, int, struct ifnet*, int, struct mbuf**);
+typedef	int ip_fw_ctl_t(int, struct mbuf**);
+extern	ip_fw_chk_t *ip_fw_chk_ptr;
+extern	ip_fw_ctl_t *ip_fw_ctl_ptr;
 #ifdef __cplusplus
 #endif /* __cplusplus */
1.8.4.5
