[PATCH] fix-warning: fix it to fit c90.
DU HUANPENG
opentkernel at 163.com
Wed Apr 27 04:13:31 UTC 2016
cpukit/score/cpu/arm/cpu.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 944ca63..c9dc22e 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -135,8 +135,8 @@ void _CPU_ISR_Set_level( uint32_t level )
uint32_t _CPU_ISR_Get_level( void )
- ARM_SWITCH_REGISTERS;
uint32_t level;
+ ARM_SWITCH_REGISTERS;
__asm__ volatile (
ARM_SWITCH_TO_ARM
2.7.4
