[rtems-libbsd commit] Add root bus support functions
Wed Apr 27 05:53:18 UTC 2016
On 27/04/16 04:27, Chris Johns wrote:
> How and why would you use these functions?
  * @brief Attach the root bus.
  * @retval 0 Successful operation.
  * @retval errno Otherwise.
int rtems_bsd_bus_root_attach(void);
  * @brief Suspend the root bus.
int rtems_bsd_bus_root_suspend(void);
  * @brief Resume the root bus.
int rtems_bsd_bus_root_resume(void);
  * @brief Detach the root bus.
int rtems_bsd_bus_root_detach(void);
Suspend and resume can be used to go into a power saving state. Detach
to shutdown the system and do a warm reset.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
