Draft for moving network headers from RTEMS to newlib
Wed Apr 27 06:20:40 UTC 2016
On 27/04/2016 15:58, Sebastian Huber wrote:
> On 27/04/16 05:53, Chris Johns wrote:
>> On 26/04/2016 19:26, Sebastian Huber wrote:
>>> On 26/04/16 10:27, Chris Johns wrote:
>>>> On 26/04/2016 17:31, Sebastian Huber wrote:
>>>>> On 26/04/16 07:51, Chris Johns wrote:
>>>>>> On 26/04/2016 01:06, Christian Mauderer wrote:
>>>>> You are able to use the
>>>>> network header files during GCC build, which makes it easier to build
>>>>> the run-time libraries of Ada and Go.
>>>> Nice. Maybe limiting what is added to just building languages would be
>>>> a nice first starting point.
>>>>>> How do you get the flags for the compiler to build the package?
>>>>> See attached script which builds for example libpng for all multilibs.
>>>> Multilibs has not had a very successful history with RTEMS (outside of
>>>> gcc). They are not very user friendly and are a source of questions
>>>> and issues.
>>> I think multilibs are great for libraries which don't depend on BSP
>>> specifics.
>> I know ...
>> https://lists.rtems.org/pipermail/users/2012-February/024544.html
>> It is a useful idea and I like the work being done with the standards
>> based headers.
>> There is something inconsistent about this I am yet to put my finger
>> on. I suspect it is related to some libraries being multilib and some
>> libraries not being multilib. Consider an example app and lets assume
>> all packages are working perfectly ..
>> 1) GCC, newlib.  - Multilib,   /bd/rtems/4.11.0
>> 2) RTEMS         - Specific,   /bd/rtems/4.11.0/bsps
>> 3) NTP           - Multilib,   /bd/rtems/4.11.0/bsps
>> 4) Protobufs     - Multilib,   /bd/rtems/4.11.0/bsps
>> 5) Civetweb      - Multilib,   /bd/rtems/4.11.0/bsps
>> 6) NetSNMP       - Specific,   /bd/rtems/4.11.0/bsps
>> 7) Application   - Executable
>> I wonder what the application linker command line looks like?
>> Does gcc's multilib search extend beyond it's own install base?
> A multilib is a normal library which is available via the builtin search
> paths of GCC:
> LIBRARY_PATH=/opt/rtems-4.12/lib64/gcc/arm-rtems4.12/6.0.1/thumb/armv7-m/:/opt/rtems-4.12/lib64/gcc/arm-rtems4.12/6.0.1/../../../../arm-rtems4.12/lib/thumb/armv7-m/:/opt/rtems-4.12/lib64/gcc/arm-rtems4.12/6.0.1/:/opt/rtems-4.12/lib64/gcc/arm-rtems4.12/6.0.1/../../../../arm-rtems4.12/lib/
Does this mean all multilib libraries need the same prefix as gcc?
>> The NetSNMP package is put here as Specific because it uses a large
>> number of platform specific header files to access things like
>> interfaces and routing tables.
>> My point is, when a user considers 3rd party packages they have moved
>> to the specific requirements for a specific project and multilibs
>> verses per BSP builds mean little. The multilib view is nice when
>> viewed from the RTEMS developer perspective or someone providing a
>> service to clients where they bundle packages as prebuilt libraries,
>> but is it nice to users from the community? I do not know. If both
>> multilib and specific libraries can coexist I have no issue but this
>> needs to be shown.
>> Note, the layout is based on the Project Sandboxing documentation I
>> have in the Getting Started Guide
>> (https://ftp.rtems.org/pub/rtems/people/chrisj/docs/user/start/index.html#project-sandboxing).
>> This documentation would need to be updated (hint).
>>> What is the benefit of per BSP libpng for example?
>> What is built is tested, there is a 1:1 relationship here. The user is
>> able to see and understand what is built, where it is installed and
>> what they are linking too. Multilibing packages adds a layer of
>> indirection and with that extra complexity.
>> Multilibs in gcc is not very user friendly ....
>> $ i386-rtems4.11-gcc -print-multi-lib
>> m486;@mtune=i486
>> mpentium;@mtune=pentium
>> mpentiumpro;@mtune=pentiumpro
>> soft-float;@msoft-float
>> m486/soft-float;@mtune=i486 at msoft-float
> The output is just like the clang output.
I suspect clang was forced to follow gcc. :)
> What do you mean with not user friendly?
It is designed to be machine decoded. I suspect few on this list could
decode that output and understand it and this is the interface a user
gets if they want to use it.
> Its good enough to simply use it in the previously attached script.
I think RTEMS has to do much better than 'hey hack on my script'.
>> $ arm-rtems4.11-gcc -print-multi-lib
>> thumb;@mthumb
>> thumb/armv6-m;@mthumb at march=armv6-m
>> thumb/armv7-a;@mthumb at march=armv7-a
>> thumb/armv7-r;@mthumb at march=armv7-r
>> thumb/armv7-m;@mthumb at march=armv7-m
>> thumb/armv7-a/neon/hard;@mthumb at march=armv7-a at mfpu=neon at mfloat-abi=hard
>> thumb/armv7-r/vfpv3-d16/hard;@mthumb at march=armv7-r at mfpu=vfpv3-d16 at mfloat-abi=hard
>> thumb/armv7-m/fpv4-sp-d16/hard;@mthumb at march=armv7-m at mfpu=fpv4-sp-d16 at mfloat-abi=hard
>> eb/thumb/armv7-r;@mbig-endian at mthumb@march=armv7-r
>> eb/thumb/armv7-r/vfpv3-d16/hard;@mbig-endian at mthumb@march=armv7-r at mfpu=vfpv3-d16 at mfloat-abi=hard
>> I have no idea what this all means.
> One problem is that even you don't find the places where things are
> documented in RTEMS:
> https://docs.rtems.org/doc-current/share/rtems/html/cpu_supplement/Port-Specific-Information-Multilibs.html#Port-Specific-Information-Multilibs
Ah ok, yes I did not know this existed. Thank you.
> https://docs.rtems.org/doc-current/share/rtems/html/cpu_supplement/ARM-Specific-Information-Multilibs.html#ARM-Specific-Information-Multilibs
> However, not all architectures have this section or an up to date content.
Maybe this can be addressed in the new web site Amar is working on.
>> I am attempting to understand what effect this has on the RTEMS
>> project and our users. If you are able to build the existing 3rd party
>> packages in the RSB before and after the changes then I am happy. Some
>> may not build completely so if you can achieve the same level of build
>> that would be fine. I would also like to see some documentation about
>> multilibing and how users are able to use it and do this themselves.
>> Chris
> If you build the package against a particular BSP, then nothing will
> change,
Great.
> except that you see standard network headers even if the BSP is
> built without a network stack.
Does this mess with the dummy.c support and create weird linker errors?
I assume all externals in the headers moved over have to have symbols added.
> We should come to a conclusion if we want the standard network headers
> in Newlib or not.
There are 2 threads happening here. The benefit or impact of multibed
libraries and the move to newlib of standard headers. I am ok with the
header move. I am sure things will come up but I am also sure they can
be addressed. The impact of multilibed library can consider mute because
you have answer my central question which is both models for libraries
can be supported.
