GSoC 2016: Low Level Peripherals & SD Card Support for Raspberry Pi
Thu Apr 28 01:10:30 UTC 2016
On Wed, Apr 27, 2016 at 8:50 PM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Chris: The Model B V1.2 should work fine.
> I think I have one of each model Raspberry Pi, so I could test just about
> any Pi code.
> I just got my development environment up to date and tested the single core
> Pi ( A+ ) and Pi Zero. I verified 4.11 and 4.12 work.
> I also updated my RKI image ( github.com/alanc98/rki ). The waf build works
> again, and it works with 4.11 and 4.12 ( Sparc/sis as well ). I'm finally
> starting to understand rtems_waf..pretty cool.
> Now I have started a branch of that project to integrate and test I2C and
> SPI drivers. I'm working on I2C drivers for the Raspberry Pi sense hat
> first. https://www.raspberrypi.org/products/sense-hat/
> I would like to port RTIMULib2 to RTEMS to work with these devices.
> https://github.com/richards-tech/RTIMULib2
> The license might look OK too.
I read the license as acceptable, looks like straight MIT license.
Gedare
