[PATCH 03/19] score: _CORE_message_queue_Close()
Fri Apr 29 09:13:03 UTC 2016
Move lock acquire to caller of _CORE_message_queue_Close() to allow
state checks during object close operations under lock protection.
Ensures deletion safety on uni-processor configuration.
 cpukit/posix/src/mqueuedeletesupp.c            |  6 +++++-
 cpukit/rtems/src/msgqdelete.c                  | 27 +++++++++++++-------------
 cpukit/score/include/rtems/score/coremsgimpl.h | 20 ++++++++++++-------
 cpukit/score/src/coremsgclose.c                | 10 ++++------
 4 files changed, 36 insertions(+), 27 deletions(-)
diff --git a/cpukit/posix/src/mqueuedeletesupp.c b/cpukit/posix/src/mqueuedeletesupp.c
index b852b04..5382dd4 100644
--- a/cpukit/posix/src/mqueuedeletesupp.c
+++ b/cpukit/posix/src/mqueuedeletesupp.c
@@ -41,6 +41,7 @@ void _POSIX_Message_queue_Delete(
   if ( !the_mq->linked && !the_mq->open_count ) {
       Objects_Control *the_object = &the_mq->Object;
+      ISR_lock_Context lock_context;
       #if defined(RTEMS_DEBUG)
@@ -55,12 +56,15 @@ void _POSIX_Message_queue_Delete(
       #endif
+      _CORE_message_queue_Acquire( &the_mq->Message_queue, &lock_context );
       _Objects_Close( &_POSIX_Message_queue_Information, the_object );
         NULL,        /* no MP support */
-        0
+        0,
+        &lock_context
     _POSIX_Message_queue_Free( the_mq );
diff --git a/cpukit/rtems/src/msgqdelete.c b/cpukit/rtems/src/msgqdelete.c
index 5adeab7..506c069 100644
--- a/cpukit/rtems/src/msgqdelete.c
+++ b/cpukit/rtems/src/msgqdelete.c
@@ -18,17 +18,8 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
-#include <rtems/score/chain.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/coremsgimpl.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/attrimpl.h>
 #include <rtems/rtems/messageimpl.h>
-#include <rtems/rtems/options.h>
-#include <rtems/rtems/support.h>
+#include <rtems/rtems/attrimpl.h>
 rtems_status_code rtems_message_queue_delete(
   rtems_id id
@@ -36,19 +27,30 @@ rtems_status_code rtems_message_queue_delete(
   Message_queue_Control          *the_message_queue;
   Objects_Locations               location;
   _Objects_Allocator_lock();
-  the_message_queue = _Message_queue_Get( id, &location );
+  the_message_queue = _Message_queue_Get_interrupt_disable(
+    id,
+    &location,
+    &lock_context
   switch ( location ) {
     case OBJECTS_LOCAL:
+      _CORE_message_queue_Acquire_critical(
+        &the_message_queue->message_queue,
+        &lock_context
       _Objects_Close( &_Message_queue_Information,
                       &the_message_queue->Object );
         _Message_queue_MP_Send_object_was_deleted,
-        id
+        id,
+        &lock_context
 #if defined(RTEMS_MULTIPROCESSING)
@@ -66,7 +68,6 @@ rtems_status_code rtems_message_queue_delete(
 #endif
-      _Objects_Put( &the_message_queue->Object );
       _Message_queue_Free( the_message_queue );
       _Objects_Allocator_unlock();
       return RTEMS_SUCCESSFUL;
diff --git a/cpukit/score/include/rtems/score/coremsgimpl.h b/cpukit/score/include/rtems/score/coremsgimpl.h
index 98d97dd..b9e4be4 100644
--- a/cpukit/score/include/rtems/score/coremsgimpl.h
+++ b/cpukit/score/include/rtems/score/coremsgimpl.h
@@ -129,12 +129,12 @@ bool _CORE_message_queue_Initialize(
 void _CORE_message_queue_Do_close(
-  CORE_message_queue_Control *the_message_queue
+  CORE_message_queue_Control *the_message_queue,
   Thread_queue_MP_callout     mp_callout,
-  Objects_Id                  mp_id
+  Objects_Id                  mp_id,
 #endif
+  ISR_lock_Context           *lock_context
@@ -151,26 +151,32 @@ void _CORE_message_queue_Do_close(
  *  @param[in] mp_callout is the routine to call for each thread
  *         that is extracted from the set of waiting threads
  *  @param[in] mp_id the object identifier of the message queue object
+ *  @param[in] lock_context The lock context of the
+ *    _CORE_message_queue_Acquire() or _CORE_message_queue_Acquire_critical().
   #define _CORE_message_queue_Close( \
     the_message_queue, \
     mp_callout, \
-    mp_id \
+    mp_id, \
+    lock_context \
     _CORE_message_queue_Do_close( \
       mp_callout, \
-      mp_id \
+      mp_id, \
+      lock_context \
 #else
     mp_callout, \
-    mp_id \
+    mp_id, \
+    lock_context \
-      the_message_queue \
+      the_message_queue, \
+      lock_context \
 #endif
diff --git a/cpukit/score/src/coremsgclose.c b/cpukit/score/src/coremsgclose.c
index 7184b11..5b53431 100644
--- a/cpukit/score/src/coremsgclose.c
+++ b/cpukit/score/src/coremsgclose.c
@@ -33,29 +33,27 @@ static Thread_Control *_CORE_message_queue_Was_deleted(
-  Objects_Id                  mp_id
+  Objects_Id                  mp_id,
 #endif
-  ISR_lock_Context lock_context;
    *  This will flush blocked threads whether they were blocked on
    *  a send or receive.
-  _CORE_message_queue_Acquire( the_message_queue, &lock_context );
   _Thread_queue_Flush_critical(
     &the_message_queue->Wait_queue.Queue,
     the_message_queue->operations,
     _CORE_message_queue_Was_deleted,
     mp_callout,
     mp_id,
-    &lock_context
+    lock_context
   (void) _Workspace_Free( the_message_queue->message_buffers );
1.8.4.5
