[PATCH 17/19] score: __RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE__
Fri Apr 29 09:13:17 UTC 2016
Delete __RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE__ as a preparation to
restructure the CORE mutex variants and reduce the branch complexity.
 cpukit/configure.ac                              |   6 -
 cpukit/score/Makefile.am                         |   3 +-
 cpukit/score/include/rtems/score/coremuteximpl.h | 391 +++++++++--------------
 cpukit/score/src/coremutexseize.c                |  19 --
 cpukit/score/src/coremutexseizeintr.c            |  39 ---
 5 files changed, 159 insertions(+), 299 deletions(-)
 delete mode 100644 cpukit/score/src/coremutexseizeintr.c
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 4b9020c..054e60e 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -266,12 +266,6 @@ RTEMS_CPUOPT([__RTEMS_DO_NOT_INLINE_THREAD_ENABLE_DISPATCH__],
   [1],
   [disable inlining _Thread_Enable_dispatch])
-## This improves both the size and coverage analysis.
-RTEMS_CPUOPT([__RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE__],
-  [test x"${RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE}" = x"1"],
-  [1],
-  [disable inlining _Thread_Enable_dispatch])
 ## Deactivate ada bindings
 RTEMS_CPUOPT([__RTEMS_ADA__],
   [test x"${enable_ada}" = x"yes"],
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 566182f..c10f2fd 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -176,8 +176,7 @@ libscore_a_SOURCES += src/coremsg.c src/coremsgbroadcast.c \
 ## CORE_MUTEX_C_FILES
 libscore_a_SOURCES += src/coremutex.c \
-    src/coremutexseize.c src/coremutexsurrender.c \
-    src/coremutexseizeintr.c
+    src/coremutexseize.c src/coremutexsurrender.c
 ## CORE_PERCPU_C_FILES
 libscore_a_SOURCES += src/percpu.c
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index 69935b5..ef116ec 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -123,64 +123,6 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Release(
- *  @brief Attempt to receive a unit from the_mutex.
- *  This routine attempts to receive a unit from the_mutex.
- *  If a unit is available or if the wait flag is false, then the routine
- *  returns.  Otherwise, the calling task is blocked until a unit becomes
- *  available.
- *  @param[in,out] executing The currently executing thread.
- *  @param[in,out] the_mutex is the mutex to attempt to lock
- *  @param[in] lock_context is the interrupt level
- *  @retval This routine returns 0 if "trylock" can resolve whether or not
- *  the mutex is immediately obtained or there was an error attempting to
- *  get it.  It returns 1 to indicate that the caller cannot obtain
- *  the mutex and will have to block to do so.
- *  @note  For performance reasons, this routine is implemented as
- *         a macro that uses two support routines.
-RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body(
-  CORE_mutex_Control  *the_mutex,
-  Thread_Control      *executing,
-  ISR_lock_Context    *lock_context
-#if defined(__RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE__)
-   *  @brief Interrupt trylock CORE mutex seize.
-   *  When doing test coverage analysis or trying to minimize the code
-   *  space for RTEMS, it is often helpful to not inline this method
-   *  multiple times.  It is fairly large and has a high branch complexity
-   *  which makes it harder to get full binary test coverage.
-   *  @param[in] the_mutex will attempt to lock
-   *  @param[in] _executing points to the executing thread
-   *  @param[in] level_p is the interrupt level
-  int _CORE_mutex_Seize_interrupt_trylock(
-#else
-   *  The default is to favor speed and inlining this definitely saves
-   *  a few instructions.  This is very important for mutex performance.
-   *  @param[in] _mutex will attempt to lock
-   *  @param[in] _lock_context is the interrupt level
-  #define _CORE_mutex_Seize_interrupt_trylock( _mutex, _executing, _lock_context ) \
-     _CORE_mutex_Seize_interrupt_trylock_body( _mutex, _executing, _lock_context )
-#endif
  *  @brief Performs the blocking portion of a mutex obtain.
  *  This routine performs the blocking portion of a mutex obtain.
@@ -214,6 +156,163 @@ void _CORE_mutex_Seize_interrupt_blocking(
     && (_System_state_Get() >= SYSTEM_STATE_UP))
+ * @brief Is mutex locked.
+ * This routine returns true if the mutex specified is locked and false
+ * otherwise.
+ * @param[in] the_mutex is the mutex to check.
+ * @retval true The mutex is locked.
+ * @retval false The mutex is not locked.
+RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_locked(
+  const CORE_mutex_Control *the_mutex
+  return the_mutex->holder != NULL;
+ * @brief Does mutex use priority inheritance.
+ * This routine returns true if the mutex's wait discipline is
+ * INHERIT_PRIORITY and false otherwise.
+ * @param[in] the_attribute is the attribute set of the mutex.
+ * @retval true The mutex is using priority inheritance.
+ * @retval false The mutex is not using priority inheritance.
+RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_inherit_priority(
+  const CORE_mutex_Attributes *the_attribute
+  return the_attribute->discipline == CORE_MUTEX_DISCIPLINES_PRIORITY_INHERIT;
+ * @brief Does mutex use priority ceiling.
+ * PRIORITY_CEILING and false otherwise.
+ * @retval true The mutex is using priority ceiling.
+ * @retval false The mutex is not using priority ceiling.
+RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority_ceiling(
+  return the_attribute->discipline == CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING;
+ *  @brief Attempt to receive a unit from the_mutex.
+ *  This routine attempts to receive a unit from the_mutex.
+ *  If a unit is available or if the wait flag is false, then the routine
+ *  returns.  Otherwise, the calling task is blocked until a unit becomes
+ *  available.
+ *  @param[in,out] executing The currently executing thread.
+ *  @param[in,out] the_mutex is the mutex to attempt to lock
+ *  @param[in] lock_context is the interrupt level
+ *  @retval This routine returns 0 if "trylock" can resolve whether or not
+ *  the mutex is immediately obtained or there was an error attempting to
+ *  get it.  It returns 1 to indicate that the caller cannot obtain
+ *  the mutex and will have to block to do so.
+RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
+  CORE_mutex_Control  *the_mutex,
+  Thread_Control      *executing,
+  ISR_lock_Context    *lock_context
+  /* disabled when you get here */
+  executing->Wait.return_code = CORE_MUTEX_STATUS_SUCCESSFUL;
+  if ( !_CORE_mutex_Is_locked( the_mutex ) ) {
+    the_mutex->holder     = executing;
+    the_mutex->nest_count = 1;
+    if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
+         _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ){
+      executing->resource_count++;
+    if ( !_CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
+      _CORE_mutex_Release( the_mutex, lock_context );
+      return 0;
+    } /* else must be CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING
+       * we possibly bump the priority of the current holder -- which
+       * happens to be _Thread_Executing.
+      Priority_Control  ceiling;
+      Priority_Control  current;
+      ceiling = the_mutex->Attributes.priority_ceiling;
+      current = executing->current_priority;
+      if ( current == ceiling ) {
+        return 0;
+      if ( current > ceiling ) {
+        Per_CPU_Control *cpu_self;
+        cpu_self = _Thread_Dispatch_disable_critical( lock_context );
+        _Thread_Raise_priority( executing, ceiling );
+        _Thread_Dispatch_enable( cpu_self );
+        return 0;
+      /* if ( current < ceiling ) */ {
+        executing->Wait.return_code = CORE_MUTEX_STATUS_CEILING_VIOLATED;
+        the_mutex->holder = NULL;
+        the_mutex->nest_count = 0;     /* undo locking above */
+        executing->resource_count--;   /* undo locking above */
+        return 0;
+    return 0;
+   *  At this point, we know the mutex was not available.  If this thread
+   *  is the thread that has locked the mutex, let's see if we are allowed
+   *  to nest access.
+  if ( _Thread_Is_executing( the_mutex->holder ) ) {
+    switch ( the_mutex->Attributes.lock_nesting_behavior ) {
+      case CORE_MUTEX_NESTING_ACQUIRES:
+        the_mutex->nest_count++;
+        return 0;
+      #if defined(RTEMS_POSIX_API)
+        case CORE_MUTEX_NESTING_IS_ERROR:
+          executing->Wait.return_code = CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED;
+          return 0;
+      #endif
+      case CORE_MUTEX_NESTING_BLOCKS:
+        break;
+   *  The mutex is not available and the caller must deal with the possibility
+   *  of blocking.
+  return 1;
  *  @brief Attempt to obtain the mutex.
  *  This routine attempts to obtain the mutex.  If the mutex is available,
@@ -239,7 +338,7 @@ void _CORE_mutex_Seize_interrupt_blocking(
  *  * If the caller is willing to wait
  *      then they are blocked.
-RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(
+RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize(
   bool                 wait,
@@ -271,31 +370,6 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(
- *  This method is used to obtain a core mutex.
- *  @param[in] _the_mutex is the mutex to attempt to lock
- *  @param[in] _executing The currently executing thread.
- *  @param[in] _wait is true if the thread is willing to wait
- *  @param[in] _timeout is the maximum number of ticks to block
- *  @param[in] _lock_context is a temporary variable used to contain the ISR
- *         disable level cookie
-  void _CORE_mutex_Seize(
-    CORE_mutex_Control  *_the_mutex,
-    Thread_Control      *_executing,
-    bool                 _wait,
-    Watchdog_Interval    _timeout,
-    ISR_lock_Context    *_lock_context
-#else
-  #define _CORE_mutex_Seize( \
-      _the_mutex, _executing, _wait, _timeout, _lock_context ) \
-       _CORE_mutex_Seize_body( \
-#endif
 CORE_mutex_Status _CORE_mutex_Do_surrender(
 #if defined(RTEMS_MULTIPROCESSING)
@@ -360,24 +434,6 @@ Thread_Control *_CORE_mutex_Unsatisfied_nowait(
     lock_context \
- * @brief Is mutex locked.
- * This routine returns true if the mutex specified is locked and false
- * otherwise.
- * @param[in] the_mutex is the mutex to check.
- * @retval true The mutex is locked.
- * @retval false The mutex is not locked.
-RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_locked(
-  const CORE_mutex_Control *the_mutex
-  return the_mutex->holder != NULL;
 RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_owner(
   const CORE_mutex_Control *the_mutex,
   const Thread_Control     *the_thread
@@ -423,137 +479,6 @@ RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority(
   return the_attribute->discipline == CORE_MUTEX_DISCIPLINES_PRIORITY;
- * @brief Does mutex use priority inheritance.
- * This routine returns true if the mutex's wait discipline is
- * INHERIT_PRIORITY and false otherwise.
- * @param[in] the_attribute is the attribute set of the mutex.
- * @retval true The mutex is using priority inheritance.
- * @retval false The mutex is not using priority inheritance.
-RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_inherit_priority(
-  const CORE_mutex_Attributes *the_attribute
-  return the_attribute->discipline == CORE_MUTEX_DISCIPLINES_PRIORITY_INHERIT;
- * @brief Does mutex use priority ceiling.
- * PRIORITY_CEILING and false otherwise.
- * @retval true The mutex is using priority ceiling.
- * @retval false The mutex is not using priority ceiling.
-RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority_ceiling(
-  return the_attribute->discipline == CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING;
- *  Seize Mutex with Quick Success Path
- *  NOTE: There is no MACRO version of this routine.  A body is in
- *  coremutexseize.c that is duplicated from the .inl by hand.
- *  NOTE: The Doxygen for this routine is in the .h file.
-  /* disabled when you get here */
-  executing->Wait.return_code = CORE_MUTEX_STATUS_SUCCESSFUL;
-  if ( !_CORE_mutex_Is_locked( the_mutex ) ) {
-    the_mutex->holder     = executing;
-    the_mutex->nest_count = 1;
-    if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
-         _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ){
-      executing->resource_count++;
-    if ( !_CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
-      _CORE_mutex_Release( the_mutex, lock_context );
-      return 0;
-    } /* else must be CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING
-       * we possibly bump the priority of the current holder -- which
-       * happens to be _Thread_Executing.
-      Priority_Control  ceiling;
-      Priority_Control  current;
-      ceiling = the_mutex->Attributes.priority_ceiling;
-      current = executing->current_priority;
-      if ( current == ceiling ) {
-        return 0;
-      if ( current > ceiling ) {
-        Per_CPU_Control *cpu_self;
-        cpu_self = _Thread_Dispatch_disable_critical( lock_context );
-        _Thread_Raise_priority( executing, ceiling );
-        _Thread_Dispatch_enable( cpu_self );
-        return 0;
-      /* if ( current < ceiling ) */ {
-        executing->Wait.return_code = CORE_MUTEX_STATUS_CEILING_VIOLATED;
-        the_mutex->holder = NULL;
-        the_mutex->nest_count = 0;     /* undo locking above */
-        executing->resource_count--;   /* undo locking above */
-        return 0;
-    return 0;
-   *  At this point, we know the mutex was not available.  If this thread
-   *  is the thread that has locked the mutex, let's see if we are allowed
-   *  to nest access.
-  if ( _Thread_Is_executing( the_mutex->holder ) ) {
-    switch ( the_mutex->Attributes.lock_nesting_behavior ) {
-      case CORE_MUTEX_NESTING_ACQUIRES:
-        the_mutex->nest_count++;
-        return 0;
-      #if defined(RTEMS_POSIX_API)
-        case CORE_MUTEX_NESTING_IS_ERROR:
-          executing->Wait.return_code = CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED;
-          return 0;
-      #endif
-      case CORE_MUTEX_NESTING_BLOCKS:
-        break;
-   *  The mutex is not available and the caller must deal with the possibility
-   *  of blocking.
-  return 1;
 #ifdef __cplusplus
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index d76c977..168d697 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -24,25 +24,6 @@
-void _CORE_mutex_Seize(
-  bool                 _wait,
-  ISR_Level            _level
-    _the_mutex,
-    _executing,
-    _wait,
-    _timeout,
-    _level
-#endif
diff --git a/cpukit/score/src/coremutexseizeintr.c b/cpukit/score/src/coremutexseizeintr.c
deleted file mode 100644
index b02c092..0000000
--- a/cpukit/score/src/coremutexseizeintr.c
+++ /dev/null
@@ -1,39 +0,0 @@
- *  @file
- *  @brief Trylock CORE Mutex Seize Interrupt
- *  @ingroup ScoreMutex
- *  COPYRIGHT (c) 1989-2007.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/coremuteximpl.h>
-#include <rtems/score/thread.h>
-int _CORE_mutex_Seize_interrupt_trylock(
-  ISR_Level            level
-  return _CORE_mutex_Seize_interrupt_trylock_body(
-    the_mutex,
-    executing,
-    level
-#endif
1.8.4.5
