[PATCH] score: Add dummy Strong APA scheduler
Fri Apr 29 10:12:01 UTC 2016
Start with a copy of the Priority SMP scheduler implementation.
Update #2510.
 cpukit/sapi/include/confdefs.h                     |  29 ++
 cpukit/sapi/include/rtems/scheduler.h              |  20 ++
 cpukit/score/Makefile.am                           |   2 +
 .../score/include/rtems/score/schedulerstrongapa.h | 145 ++++++++
 cpukit/score/preinstall.am                         |   4 +
 cpukit/score/src/schedulerstrongapa.c              | 396 +++++++++++++++++++++
 testsuites/smptests/Makefile.am                    |   1 +
 testsuites/smptests/configure.ac                   |   1 +
 testsuites/smptests/smpstrongapa01/Makefile.am     |  19 +
 testsuites/smptests/smpstrongapa01/init.c          |  54 +++
 .../smptests/smpstrongapa01/smpstrongapa01.doc     |  11 +
 .../smptests/smpstrongapa01/smpstrongapa01.scn     |   2 +
 12 files changed, 684 insertions(+)
 create mode 100644 cpukit/score/include/rtems/score/schedulerstrongapa.h
 create mode 100644 cpukit/score/src/schedulerstrongapa.c
 create mode 100644 testsuites/smptests/smpstrongapa01/Makefile.am
 create mode 100644 testsuites/smptests/smpstrongapa01/init.c
 create mode 100644 testsuites/smptests/smpstrongapa01/smpstrongapa01.doc
 create mode 100644 testsuites/smptests/smpstrongapa01/smpstrongapa01.scn
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 006cdbd..ceed2a4 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -771,6 +771,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  *  - CONFIGURE_SCHEDULER_PRIORITY_SMP - Deterministic Priority SMP Scheduler
  *  - CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP - Deterministic
  *    Priority SMP Affinity Scheduler
+ *  - CONFIGURE_SCHEDULER_STRONG_APA - Strong APA Scheduler
  *  - CONFIGURE_SCHEDULER_SIMPLE - Light-weight Priority Scheduler
  *  - CONFIGURE_SCHEDULER_SIMPLE_SMP - Simple SMP Priority Scheduler
  *  - CONFIGURE_SCHEDULER_EDF - EDF Scheduler
@@ -795,6 +796,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     !defined(CONFIGURE_SCHEDULER_PRIORITY) && \
     !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \
     !defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) && \
+    !defined(CONFIGURE_SCHEDULER_STRONG_APA) && \
     !defined(CONFIGURE_SCHEDULER_SIMPLE) && \
     !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) && \
     !defined(CONFIGURE_SCHEDULER_EDF) && \
@@ -890,6 +892,30 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
 #endif
+ * If the Strong APA Scheduler is selected, then configure for
+ * it.
+#if defined(CONFIGURE_SCHEDULER_STRONG_APA)
+  #if !defined(CONFIGURE_SCHEDULER_NAME)
+    /** Configure the name of the scheduler instance */
+    #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'A', 'P', 'A')
+  #endif
+  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
+    /** Configure the context needed by the scheduler instance */
+    #define CONFIGURE_SCHEDULER_CONTEXT \
+      RTEMS_SCHEDULER_CONTEXT_STRONG_APA( \
+        dflt, \
+        CONFIGURE_MAXIMUM_PRIORITY + 1 \
+    /** Configure the controls for this scheduler instance */
+    #define CONFIGURE_SCHEDULER_CONTROLS \
+      RTEMS_SCHEDULER_CONTROL_STRONG_APA(dflt, CONFIGURE_SCHEDULER_NAME)
+  #endif
+#endif
  * If the Simple Priority Scheduler is selected, then configure for it.
 #if defined(CONFIGURE_SCHEDULER_SIMPLE)
@@ -3264,6 +3290,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       #ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
         Scheduler_priority_affinity_SMP_Node Priority_affinity_SMP;
       #endif
+      #ifdef CONFIGURE_SCHEDULER_STRONG_APA
+        Scheduler_strong_APA_Node Strong_APA;
+      #endif
       #ifdef CONFIGURE_SCHEDULER_USER_PER_THREAD
         CONFIGURE_SCHEDULER_USER_PER_THREAD User;
       #endif
diff --git a/cpukit/sapi/include/rtems/scheduler.h b/cpukit/sapi/include/rtems/scheduler.h
index a1afa66..39dff90 100644
--- a/cpukit/sapi/include/rtems/scheduler.h
+++ b/cpukit/sapi/include/rtems/scheduler.h
@@ -151,6 +151,26 @@
 #endif
+#ifdef CONFIGURE_SCHEDULER_STRONG_APA
+  #include <rtems/score/schedulerstrongapa.h>
+  #define RTEMS_SCHEDULER_CONTEXT_STRONG_APA_NAME( name ) \
+    RTEMS_SCHEDULER_CONTEXT_NAME( strong_APA_ ## name )
+  #define RTEMS_SCHEDULER_CONTEXT_STRONG_APA( name, prio_count ) \
+    static struct { \
+      Scheduler_strong_APA_Context Base; \
+      Chain_Control                Ready[ ( prio_count ) ]; \
+    } RTEMS_SCHEDULER_CONTEXT_STRONG_APA_NAME( name )
+  #define RTEMS_SCHEDULER_CONTROL_STRONG_APA( name, obj_name ) \
+      &RTEMS_SCHEDULER_CONTEXT_STRONG_APA_NAME( name ).Base.Base.Base, \
+      SCHEDULER_STRONG_APA_ENTRY_POINTS, \
+      ( obj_name ) \
+#endif
 #ifdef CONFIGURE_SCHEDULER_SIMPLE
   #include <rtems/score/schedulersimple.h>
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index c10f2fd..a5e1ed0 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -128,6 +128,7 @@ if HAS_SMP
 include_rtems_score_HEADERS += include/rtems/score/schedulerprioritysmpimpl.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerpriorityaffinitysmp.h
 include_rtems_score_HEADERS += include/rtems/score/schedulersimplesmp.h
+include_rtems_score_HEADERS += include/rtems/score/schedulerstrongapa.h
 endif
 ## src
@@ -148,6 +149,7 @@ libscore_a_SOURCES += src/schedulerchangeroot.c
 libscore_a_SOURCES += src/schedulerpriorityaffinitysmp.c
 libscore_a_SOURCES += src/schedulerprioritysmp.c
 libscore_a_SOURCES += src/schedulersimplesmp.c
+libscore_a_SOURCES += src/schedulerstrongapa.c
 libscore_a_SOURCES += src/schedulersmpdebug.c
 libscore_a_SOURCES += src/smp.c
 libscore_a_SOURCES += src/smplock.c
diff --git a/cpukit/score/include/rtems/score/schedulerstrongapa.h b/cpukit/score/include/rtems/score/schedulerstrongapa.h
new file mode 100644
index 0000000..5222cd0
--- /dev/null
+++ b/cpukit/score/include/rtems/score/schedulerstrongapa.h
@@ -0,0 +1,145 @@
+ * @file
+ * @ingroup ScoreSchedulerStrongAPA
+ * @brief Strong APA Scheduler API
+ * Copyright (c) 2013, 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
+#define _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
+#include <rtems/score/scheduler.h>
+#include <rtems/score/schedulerpriority.h>
+#include <rtems/score/schedulersmp.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup ScoreSchedulerStrongAPA Strong APA Scheduler
+ * @ingroup ScoreSchedulerSMP
+ * This is an implementation of the global fixed priority scheduler (G-FP).  It
+ * uses one ready chain per priority to ensure constant time insert operations.
+ * The scheduled chain uses linear insert operations and has at most processor
+ * count entries.  Since the processor and priority count are constants all
+ * scheduler operations complete in a bounded execution time.
+ * The the_thread preempt mode will be ignored.
+ * @brief Scheduler context specialization for Strong APA
+ * schedulers.
+typedef struct {
+  Scheduler_SMP_Context    Base;
+  Priority_bit_map_Control Bit_map;
+  Chain_Control            Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
+} Scheduler_strong_APA_Context;
+ * @brief Scheduler node specialization for Strong APA
+ * schedulers.
+typedef struct {
+   * @brief SMP scheduler node.
+  Scheduler_SMP_Node Base;
+   * @brief The associated ready queue of this node.
+  Scheduler_priority_Ready_queue Ready_queue;
+} Scheduler_strong_APA_Node;
+ * @brief Entry points for the Strong APA Scheduler.
+#define SCHEDULER_STRONG_APA_ENTRY_POINTS \
+    _Scheduler_strong_APA_Initialize, \
+    _Scheduler_default_Schedule, \
+    _Scheduler_strong_APA_Yield, \
+    _Scheduler_strong_APA_Block, \
+    _Scheduler_strong_APA_Unblock, \
+    _Scheduler_strong_APA_Change_priority, \
+    _Scheduler_strong_APA_Ask_for_help, \
+    _Scheduler_strong_APA_Node_initialize, \
+    _Scheduler_default_Node_destroy, \
+    _Scheduler_strong_APA_Update_priority, \
+    _Scheduler_priority_Priority_compare, \
+    _Scheduler_default_Release_job, \
+    _Scheduler_default_Tick, \
+    _Scheduler_SMP_Start_idle \
+    SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
+void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler );
+void _Scheduler_strong_APA_Node_initialize(
+  const Scheduler_Control *scheduler,
+  Thread_Control          *the_thread
+void _Scheduler_strong_APA_Block(
+Thread_Control *_Scheduler_strong_APA_Unblock(
+Thread_Control *_Scheduler_strong_APA_Change_priority(
+  Thread_Control          *the_thread,
+  Priority_Control         new_priority,
+  bool                     prepend_it
+Thread_Control *_Scheduler_strong_APA_Ask_for_help(
+  Thread_Control          *needs_help,
+  Thread_Control          *offers_help
+void _Scheduler_strong_APA_Update_priority(
+Thread_Control *_Scheduler_strong_APA_Yield(
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_SCHEDULERSTRONGAPA_H */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 3a70bfa..348185a 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -446,4 +446,8 @@ PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulerpriorityaffinitysmp.
 $(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h: include/rtems/score/schedulersimplesmp.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h
+$(PROJECT_INCLUDE)/rtems/score/schedulerstrongapa.h: include/rtems/score/schedulerstrongapa.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulerstrongapa.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulerstrongapa.h
 endif
diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
index 0000000..09efde9
--- /dev/null
+++ b/cpukit/score/src/schedulerstrongapa.c
@@ -0,0 +1,396 @@
+ * @file
+ * @brief Strong APA Scheduler Implementation
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/score/schedulerstrongapa.h>
+#include <rtems/score/schedulerpriorityimpl.h>
+#include <rtems/score/schedulersmpimpl.h>
+static Scheduler_strong_APA_Context *_Scheduler_strong_APA_Get_self(
+  Scheduler_Context *context
+  return (Scheduler_strong_APA_Context *) context;
+static Scheduler_strong_APA_Node *
+_Scheduler_strong_APA_Node_downcast( Scheduler_Node *node )
+  return (Scheduler_strong_APA_Node *) node;
+static void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
+  Scheduler_Context *context,
+  Scheduler_Node    *scheduled_to_ready
+  Scheduler_strong_APA_Context *self =
+    _Scheduler_strong_APA_Get_self( context );
+  Scheduler_strong_APA_Node *node =
+    _Scheduler_strong_APA_Node_downcast( scheduled_to_ready );
+  _Chain_Extract_unprotected( &node->Base.Base.Node );
+  _Scheduler_priority_Ready_queue_enqueue_first(
+    &node->Base.Base.Node,
+    &node->Ready_queue,
+    &self->Bit_map
+static void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
+  Scheduler_Node    *ready_to_scheduled
+    _Scheduler_strong_APA_Node_downcast( ready_to_scheduled );
+  _Scheduler_priority_Ready_queue_extract(
+    &self->Bit_map
+  _Chain_Insert_ordered_unprotected(
+    &self->Base.Scheduled,
+    _Scheduler_SMP_Insert_priority_fifo_order
+static void _Scheduler_strong_APA_Insert_ready_lifo(
+  Scheduler_Node    *the_thread
+    _Scheduler_strong_APA_Node_downcast( the_thread );
+  _Scheduler_priority_Ready_queue_enqueue(
+    &self->Bit_map
+static void _Scheduler_strong_APA_Insert_ready_fifo(
+    &self->Bit_map
+static void _Scheduler_strong_APA_Extract_from_ready(
+    &self->Bit_map
+static void _Scheduler_strong_APA_Do_update(
+  Scheduler_Node *node_to_update,
+    _Scheduler_strong_APA_Node_downcast( node_to_update );
+  _Scheduler_SMP_Node_update_priority( &node->Base, new_priority );
+  _Scheduler_priority_Ready_queue_update(
+    new_priority,
+    &self->Bit_map,
+    &self->Ready[ 0 ]
+_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
+  return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
+    _Scheduler_strong_APA_Get_context( scheduler );
+  _Scheduler_SMP_Initialize( &self->Base );
+  _Priority_bit_map_Initialize( &self->Bit_map );
+  _Scheduler_priority_Ready_queue_initialize( &self->Ready[ 0 ] );
+  Scheduler_SMP_Node *node = _Scheduler_SMP_Thread_get_own_node( the_thread );
+  _Scheduler_SMP_Node_initialize( node, the_thread );
+  Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+  Scheduler_Node *node = _Scheduler_Thread_get_node( the_thread );
+  _Scheduler_strong_APA_Do_update( context, node, new_priority );
+static Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
+  (void) node;
+  return (Scheduler_Node *) _Scheduler_priority_Ready_queue_first(
+    &self->Bit_map,
+    &self->Ready[ 0 ]
+  _Scheduler_SMP_Block(
+    context,
+    the_thread,
+    _Scheduler_strong_APA_Extract_from_ready,
+    _Scheduler_strong_APA_Get_highest_ready,
+    _Scheduler_strong_APA_Move_from_ready_to_scheduled,
+    _Scheduler_SMP_Allocate_processor_lazy
+static Thread_Control *_Scheduler_strong_APA_Enqueue_ordered(
+  Scheduler_Node       *node,
+  Chain_Node_order      order,
+  Scheduler_SMP_Insert  insert_ready,
+  Scheduler_SMP_Insert  insert_scheduled
+  return _Scheduler_SMP_Enqueue_ordered(
+    context,
+    node,
+    needs_help,
+    order,
+    insert_ready,
+    insert_scheduled,
+    _Scheduler_strong_APA_Move_from_scheduled_to_ready,
+    _Scheduler_SMP_Get_lowest_scheduled,
+static Thread_Control *_Scheduler_strong_APA_Enqueue_lifo(
+  return _Scheduler_strong_APA_Enqueue_ordered(
+    context,
+    node,
+    needs_help,
+    _Scheduler_SMP_Insert_priority_lifo_order,
+    _Scheduler_strong_APA_Insert_ready_lifo,
+    _Scheduler_SMP_Insert_scheduled_lifo
+static Thread_Control *_Scheduler_strong_APA_Enqueue_fifo(
+    context,
+    node,
+    needs_help,
+    _Scheduler_SMP_Insert_priority_fifo_order,
+    _Scheduler_strong_APA_Insert_ready_fifo,
+    _Scheduler_SMP_Insert_scheduled_fifo
+static Thread_Control *_Scheduler_strong_APA_Enqueue_scheduled_ordered(
+  return _Scheduler_SMP_Enqueue_scheduled_ordered(
+    context,
+    node,
+    order,
+    insert_ready,
+    insert_scheduled,
+static Thread_Control *_Scheduler_strong_APA_Enqueue_scheduled_lifo(
+  return _Scheduler_strong_APA_Enqueue_scheduled_ordered(
+    context,
+    node,
+static Thread_Control *_Scheduler_strong_APA_Enqueue_scheduled_fifo(
+    context,
+    node,
+  return _Scheduler_SMP_Unblock(
+    context,
+    the_thread,
+    _Scheduler_strong_APA_Enqueue_fifo
+  bool                     prepend_it
+  return _Scheduler_SMP_Change_priority(
+    context,
+    the_thread,
+    new_priority,
+    prepend_it,
+    _Scheduler_strong_APA_Do_update,
+    _Scheduler_strong_APA_Enqueue_fifo,
+    _Scheduler_strong_APA_Enqueue_lifo,
+    _Scheduler_strong_APA_Enqueue_scheduled_fifo,
+    _Scheduler_strong_APA_Enqueue_scheduled_lifo
+  Thread_Control          *offers_help,
+  return _Scheduler_SMP_Ask_for_help(
+    context,
+    offers_help,
+    needs_help,
+  return _Scheduler_SMP_Yield(
+    context,
+    the_thread,
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 610f313..8ab12dc 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -38,6 +38,7 @@ SUBDIRS += smpscheduler02
 SUBDIRS += smpscheduler03
 SUBDIRS += smpschedsem01
 SUBDIRS += smpsignal01
+SUBDIRS += smpstrongapa01
 SUBDIRS += smpswitchextension01
 SUBDIRS += smpthreadlife01
 SUBDIRS += smpunsupported01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index a89b796..3611e32 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -57,6 +57,7 @@ AM_CONDITIONAL(HAS_CPUSET,test x"${ac_cv_header_sys_cpuset_h}" = x"yes")
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+smpstrongapa01/Makefile
 smp01/Makefile
 smp02/Makefile
 smp03/Makefile
diff --git a/testsuites/smptests/smpstrongapa01/Makefile.am b/testsuites/smptests/smpstrongapa01/Makefile.am
index 0000000..b51c779
--- /dev/null
+++ b/testsuites/smptests/smpstrongapa01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpstrongapa01
+smpstrongapa01_SOURCES = init.c
+dist_rtems_tests_DATA = smpstrongapa01.scn smpstrongapa01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpstrongapa01_OBJECTS)
+LINK_LIBS = $(smpstrongapa01_LDLIBS)
+smpstrongapa01$(EXEEXT): $(smpstrongapa01_OBJECTS) $(smpstrongapa01_DEPENDENCIES)
+	@rm -f smpstrongapa01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index 0000000..5594d74
--- /dev/null
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -0,0 +1,54 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#include "tmacros.h"
+const char rtems_test_name[] = "SMPSTRONGAPA 1";
+static void test(void)
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 2
+#define CONFIGURE_SCHEDULER_STRONG_APA
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpstrongapa01/smpstrongapa01.doc b/testsuites/smptests/smpstrongapa01/smpstrongapa01.doc
index 0000000..9e93762
--- /dev/null
+++ b/testsuites/smptests/smpstrongapa01/smpstrongapa01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpstrongapa01
+directives:
+  TBD
+concepts:
+  TBD
diff --git a/testsuites/smptests/smpstrongapa01/smpstrongapa01.scn b/testsuites/smptests/smpstrongapa01/smpstrongapa01.scn
index 0000000..d6f5f54
--- /dev/null
+++ b/testsuites/smptests/smpstrongapa01/smpstrongapa01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SMPSTRONGAPA 1 ***
+*** END OF TEST SMPSTRONGAPA 1 ***
1.8.4.5
