[PATCH 1/2] Move kernel dependent parts of <sys/time.h>
    Sebastian Huber
    Fri Apr  8 06:39:41 UTC 2016
On 07/04/16 17:56, Joel Sherrill wrote:
> Does this address the warning in the RTEMS main_date.c command that
> popped up with the newlib guard changes?
No, this patch solves a completely different problem. The strptime() is
declared in <time.h> via
#if __XSI_VISIBLE
char      *_EXFUN(strptime,     (const char *__restrict,
                  struct tm *__restrict));
#endif
which uses
#if (_XOPEN_SOURCE - 0) >= 700
#define    __XSI_VISIBLE        700
#elif (_XOPEN_SOURCE - 0) >= 600
#define    __XSI_VISIBLE        600
#elif (_XOPEN_SOURCE - 0) >= 500
#define    __XSI_VISIBLE        500
#elif defined(_XOPEN_SOURCE) && defined(_XOPEN_SOURCE_EXTENDED)
#define    __XSI_VISIBLE        4
#define    __XSI_VISIBLE        1
#else
#define    __XSI_VISIBLE        0
#endif
I guess we need an
#define _XOPEN_SOURCE
#include <time.h>
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
