RTEMS Bootstrap Error
    Olufowobi, Habeeb
    habeeb.olufowobi at bison.howard.edu
    Mon Apr 18 04:03:46 UTC 2016
Hi Chris,
Thanks so much for your response. That works and I have build successfully.
Regards,
Habeeb
On Sun, Apr 17, 2016 at 6:19 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 17/04/2016 14:13, Olufowobi, Habeeb wrote:
>> I am trying to build RTEMS for ARM with the recent toolchain but I have
>> been receiving the below error when I run ./bootstrap. I think there is
>> some error in the bootstrap file.
>> I have tried running the ./bootstrap script located in rtems, instead of
>> using sb-bootstrap but doesn't help.
> What did ./bootstrap give as an error?
> Any ideas on how I can fix this?
>> RTEMS Source Builder - RTEMS Bootstrap, 4.12 (6843e47ce339)
>>    1/139: autoreconf: configure.ac <http://configure.ac>
>>    2/139: autoreconf: cpukit/configure.ac <http://configure.ac>
>> Traceback (most recent call last):
>>    File
>> "/home/dipupo/development/rtems/rsb/source-builder/sb-bootstrap", line
>> 28, in <module>
>>      bootstrap.run(sys.argv)
>>    File
>> "/home/dipupo/development/rtems/rsb/source-builder/sb/bootstrap.py",
>> line 279, in run
>>      generate(topdir, opts.jobs <http://opts.jobs
>> >(opts.defaults['_ncpus']))
>>    File
>> line 188, in generate
>>      ac.post_process()
>>    File
>> line 158, in post_process
>>      self.command.reraise()
>>    File
>> line 119, in reraise
>>      raise self.result[0](self.result[1]).with_traceback(self.result[2])
>>    File "/home/dipupo/development/rtems/rsb/source-builder/sb/error.py",
>> line 36, in __init__
>>      self.set_output('error: ' + what)
> Can you try:
>       self.set_output('error: ' + str(what))
> and if that does not work:
>  self.set_output('error: ' + type(what))
> And let me know what the output it.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160418/eceeee9f/attachment-0002.html>
