[PATCH 1/3] i386/pc386: Add support for the gdb stub to use available console drivers.
Wed Apr 20 23:01:19 UTC 2016
On Wed, Apr 20, 2016 at 2:20 AM, Chris Johns <chrisj at rtems.org> wrote:
> Move the gdb stub from the i386 UART code to use the libchip drivers.
> Use any ports discovered during the probes.
> Add gdb control to the boot command line.
> Change the device naming to the full device path, not a partial path.
> For example /dev/com1.
>  c/src/lib/libbsp/i386/pc386/Makefile.am            |   5 +-
>  c/src/lib/libbsp/i386/pc386/README                 |  23 ++-
>  c/src/lib/libbsp/i386/pc386/configure.ac           |   6 +
>  c/src/lib/libbsp/i386/pc386/console/conscfg.c      |  88 ++++++----
>  .../libbsp/i386/pc386/console/console_control.c    |  39 +++--
>  .../lib/libbsp/i386/pc386/console/console_select.c | 106 +++--------
>  c/src/lib/libbsp/i386/pc386/console/gdb_select.c   | 169
>  c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c | 135 +++++++-------
>  c/src/lib/libbsp/i386/pc386/include/bsp.h          |   3 +-
>  c/src/lib/libbsp/i386/pc386/include/bspimpl.h      |  12 +-
>  c/src/lib/libbsp/i386/pc386/startup/bspstart.c     |  29 ++-
>  c/src/lib/libbsp/i386/pc386/startup/ldsegs.S       |   2 +-
>  c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO        | 134 +++++++-------
>  c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c | 195
>  c/src/lib/libbsp/i386/shared/comm/i386-stub.c      | 179
>  c/src/lib/libbsp/shared/console.c                  |  43 ++++-
>  c/src/lib/libbsp/shared/console_private.h          |  13 ++
>  17 files changed, 754 insertions(+), 427 deletions(-)
>  create mode 100644 c/src/lib/libbsp/i386/pc386/console/gdb_select.c
> diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am
> b/c/src/lib/libbsp/i386/pc386/Makefile.am
> index d9af7dd..22d4bf1 100644
> --- a/c/src/lib/libbsp/i386/pc386/Makefile.am
> +++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
> @@ -132,6 +132,7 @@ libbsp_a_SOURCES += console/printk_support.c
>  libbsp_a_SOURCES += console/exar17d15x.c
>  libbsp_a_SOURCES += console/rtd316.c
>  libbsp_a_SOURCES += console/uart_bus_pci.c
> +libbsp_a_SOURCES += console/gdb_select.c
>  # gdb
>  libbsp_a_SOURCES += ../../i386/shared/comm/i386-stub.c
> @@ -181,8 +182,8 @@ libbsp_a_SOURCES += ide/idecfg.c
>  endif
>  if HAS_SMP
> -libbsp_a_SOURCES += ../../i386/shared/smp/getcpuid.c
> -libbsp_a_SOURCES += ../../i386/shared/smp/smp-imps.c
> +libbsp_a_SOURCES += ../../i386/shared/smp/getcpuid.c
> +libbsp_a_SOURCES += ../../i386/shared/smp/smp-imps.c
>  project_lib_DATA += appstart.$(OBJEXT)
>  appcpustart.$(OBJEXT): start/start16.S
> diff --git a/c/src/lib/libbsp/i386/pc386/README
> b/c/src/lib/libbsp/i386/pc386/README
> index bfebf19..4ed8829 100644
> --- a/c/src/lib/libbsp/i386/pc386/README
> +++ b/c/src/lib/libbsp/i386/pc386/README
> @@ -7,7 +7,7 @@ a Pentium or above, the TSC register is used for timing
> calibration
>  purposes rather than relying entirely on the i8254.
>  Partial support is implemented for more modern PCs which do not have
> -a complete complement of legacy peripherals.
> +a complete complement of legacy peripherals.
>  Console/Printk Device Selection
> @@ -19,9 +19,9 @@ in the following order of priority:
>  + VGA and keyboard
>  + COM1 through COM4aaa
What is the aaa?
> -+ Any COM devices on the PCI bus
> ++ Any COM devices on the PCI bus including IO and memory mapped.
> -Beyond the dynamic probing for device presence, a combination of
> +Beyond the dynamic probing for device presence, a combination of
>  configure and boot time options are available. By default, all devices
>  are enabled. The configure time options are:
> @@ -45,7 +45,7 @@ specify the console and kernel debug IO device. The
> --printk
>  is then interpreted to specify the debug kernel IO device.
>  For example,
> ---console=com1 --printk=vgacons
> +--console=/dev/com1 --printk=/dev/vgacons
>  specifies that com1 is to be used for stdin, stdout, and stderr
>  while the VGA console is to be used for kernel debug IO.
> @@ -55,8 +55,21 @@ the RTEMS device /dev/com1.
>  The device name may be followed by a baud rate. The following
>  example illustrates this:
> ---console=com1,19200 --printk=vgacons
> +--console=/dev/com1,19200 --printk=/dev/vgacons
>  If the specified device is not present, then a suitable fallback
>  device is selected. The fallback order is based upon the probe
>  order listed earlier.
> +PCI UART devices are /dev/pcicom1 etc as they are probed and found.
> +GDB
> +GDB can be support using:
> + --gdb=/dev/com1,115200  : where the device and baudrate are selectable.
> + --gdb-break             : halt at a break point in the BSP and wait for
> GDB.
> + --gdb-remote-debug      : Output the GDB remote protocol data to printk
> +The GDB stub details and in shared/comm/GDB.HOWTO.
> diff --git a/c/src/lib/libbsp/i386/pc386/configure.ac
> b/c/src/lib/libbsp/i386/pc386/configure.ac
> index 17b7d02..d62a9b3 100644
> --- a/c/src/lib/libbsp/i386/pc386/configure.ac
> +++ b/c/src/lib/libbsp/i386/pc386/configure.ac
> @@ -142,6 +142,12 @@ RTEMS_BSPOPTS_HELP([BSP_HAS_SMP],
>  [Always defined when on a pc386 to enable the pc386 support for
>   determining the CPU core number in an SMP configuration.])
> +RTEMS_BSPOPTS_SET([BSP_GDB_STUB],[*],[1])
> +RTEMS_BSPOPTS_HELP([BSP_GDB_STUB],
> +[Defined by default. Enables use of the GDB stub for debugging via a
> + serial port.])
> +AM_CONDITIONAL(BSP_GDB_STUB, test "$BSP_GDB_STUB" = "1")
>  ## if this is an i386, does gas have good code16 support?
>  RTEMS_I386_GAS_CODE16
>  AM_CONDITIONAL(RTEMS_GAS_CODE16,[test "$RTEMS_GAS_CODE16" = "yes"])
> diff --git a/c/src/lib/libbsp/i386/pc386/console/conscfg.c
> b/c/src/lib/libbsp/i386/pc386/console/conscfg.c
> index 5b7ebc5..82d3cf9 100644
> --- a/c/src/lib/libbsp/i386/pc386/console/conscfg.c
> +++ b/c/src/lib/libbsp/i386/pc386/console/conscfg.c
> @@ -16,13 +16,14 @@
>  #include <bsp.h>
> +#include <bsp/bspimpl.h>
>  #include <libchip/serial.h>
>  #include <libchip/ns16550.h>
>  #if BSP_ENABLE_VGA
>  #include "vgacons.h"
>  #endif
>  #include <bsp/irq.h>
> -#include <rtems/pci.h>
> +#include "../../../shared/console_private.h"
>  #if BSP_ENABLE_VGA
>  #define VGA_CONSOLE_FUNCTIONS  &vgacons_fns
> @@ -43,7 +44,7 @@
>    #define COM3_BASE_IO  0x2F8
>    #define COM4_BASE_IO  0x2E8
> -  #define CLOCK_RATE     (115200 * 16)
> +  #define CLOCK_RATE    (115200 * 16)
>    static uint8_t com_get_register(uint32_t addr, uint8_t i)
> @@ -57,21 +58,26 @@
>      outport_byte( (addr + i), val );
> -  extern bool pc386_com1_com4_enabled(int);
>  #endif
>  #if (BSP_IS_EDISON == 1 )
>    extern const console_fns edison_fns;
>  #endif
> -console_tbl     Console_Configuration_Ports[] = {
> -#if (BSP_IS_EDISON == 1)
> + * Default to the PC VGA console if present and configured.
> +console_tbl Console_Configuration_Ports[] = {
> +#if BSP_ENABLE_VGA
> +   * If present the VGA console must always be minor 0.
> +   * See console_control.
> -    "/dev/com1",                           /* sDeviceName */
> -    -1,                                    /* deviceType */
> -    &edison_fns,                           /* pDeviceFns */
> -    NULL,                                  /* deviceProbe */
> +    "/dev/vgacons",                        /* sDeviceName */
> +    VGA_CONSOLE,                           /* deviceType */
> +    VGA_CONSOLE_FUNCTIONS,                 /* pDeviceFns */
> +    vgacons_probe,                         /* deviceProbe */
>      NULL,                                  /* pDeviceFlow */
>      16,                                    /* ulMargin */
>      8,                                     /* ulHysteresis */
> @@ -83,16 +89,22 @@ console_tbl     Console_Configuration_Ports[] = {
>      NULL,                                  /* setRegister */
>      NULL,/* unused */                      /* getData */
>      NULL,/* unused */                      /* setData */
> -    0X0,                                   /* ulClock */
> -    0x0                                     /* ulIntVector -- base for
> port */
> +    0x0,                                   /* ulClock */
> +    0x0                                    /* ulIntVector -- base for
> port */
>  #endif
> -#if BSP_ENABLE_VGA
> +unsigned long Console_Configuration_Count =
> +    (sizeof(Console_Configuration_Ports)/sizeof(console_tbl));
> +static console_tbl Legacy_Ports[] = {
> +#if (BSP_IS_EDISON == 1)
> -    "/dev/vgacons",                        /* sDeviceName */
> -    VGA_CONSOLE,                           /* deviceType */
> -    VGA_CONSOLE_FUNCTIONS,                 /* pDeviceFns */
> -    vgacons_probe,                         /* deviceProbe */
> +    "/dev/com1",                           /* sDeviceName */
> +    -1,                                    /* deviceType */
> +    &edison_fns,                           /* pDeviceFns */
> +    NULL,                                  /* deviceProbe */
>      16,                                    /* ulMargin */
> @@ -104,8 +116,8 @@ console_tbl     Console_Configuration_Ports[] = {
> port */
> port */
>  #endif
>  #if BSP_ENABLE_COM1_COM4
> @@ -113,7 +125,7 @@ console_tbl     Console_Configuration_Ports[] = {
>      SERIAL_NS16550,                        /* deviceType */
>      COM_CONSOLE_FUNCTIONS,                 /* pDeviceFns */
> -    pc386_com1_com4_enabled,               /* deviceProbe */
>      16,                                    /* ulMargin */
> @@ -132,7 +144,7 @@ console_tbl     Console_Configuration_Ports[] = {
>      "/dev/com2",                           /* sDeviceName */
>      16,                                    /* ulMargin */
> @@ -147,12 +159,11 @@ console_tbl     Console_Configuration_Ports[] = {
>      CLOCK_RATE,                            /* ulClock */
>      BSP_UART_COM2_IRQ                      /* ulIntVector -- base for
> port */
>      "/dev/com3",                           /* sDeviceName */
>      16,                                    /* ulMargin */
> @@ -167,12 +178,11 @@ console_tbl     Console_Configuration_Ports[] = {
>      BSP_UART_COM3_IRQ                      /* ulIntVector -- base for
> port */
>      "/dev/com4",                           /* sDeviceName */
>      16,                                    /* ulMargin */
> @@ -188,12 +198,26 @@ console_tbl     Console_Configuration_Ports[] = {
>      BSP_UART_COM4_IRQ                      /* ulIntVector -- base for
> port */
>  #endif
> - *  Define a variable that contains the number of statically configured
> - *  console devices.
> -unsigned long  Console_Configuration_Count = \
> -    (sizeof(Console_Configuration_Ports)/sizeof(console_tbl));
> +#define Legacy_Port_Count \
> +    (sizeof(Legacy_Ports)/sizeof(console_tbl))
> +void legacy_uart_probe(void)
> +#if BSP_ENABLE_COM1_COM4
> +  const char *opt;
> +   * Check the command line to see if com1-com4 are disabled.
> +  opt = bsp_cmdline_arg("--disable-com1-com4");
> +  if ( opt ) {
> +    printk( "COM1-COM4: disabled\n" );
> +  } else {
> +    if (Legacy_Port_Count) {
> +      printk("Legacy UART Ports: COM1-COM4\n");
> +      console_register_devices( Legacy_Ports, Legacy_Port_Count );
> +#endif
> diff --git a/c/src/lib/libbsp/i386/pc386/console/console_control.c
> b/c/src/lib/libbsp/i386/pc386/console/console_control.c
> index a0b9220..3a454d9 100644
> --- a/c/src/lib/libbsp/i386/pc386/console/console_control.c
> +++ b/c/src/lib/libbsp/i386/pc386/console/console_control.c
> @@ -1,5 +1,5 @@
> - *  This file is an extension of the generic console driver
> + *  This file is an extension of the generic console driver
>   *  shell used by all console drivers using libchip, it contains
>   *  the console_control routine,  This bsp needs its own version
>   *  of this method to handle the keyboard and mouse as a single
> @@ -44,27 +44,28 @@ rtems_device_driver console_control(
>  #if BSP_ENABLE_VGA
> -  rtems_libio_ioctl_args_t *args = arg;
> +  if (minor == 0) {
> +    rtems_libio_ioctl_args_t *args = arg;
> -  switch (args->command) {
> -    default:
> -      if( vt_ioctl( args->command, (unsigned long)args->buffer ) != 0 )
> -        return rtems_termios_ioctl (arg);
> -      break;
> +    switch (args->command) {
> +      default:
> +        if( vt_ioctl( args->command, (unsigned long)args->buffer ) != 0 )
> +          return rtems_termios_ioctl (arg);
> +        break;
> -    case MW_UID_REGISTER_DEVICE:
> -      printk( "SerialMouse: reg=%s\n", args->buffer );
> -      register_kbd_msg_queue( args->buffer, 0 );
> -      break;
> +      case MW_UID_REGISTER_DEVICE:
> +        printk( "SerialMouse: reg=%s\n", args->buffer );
> +        register_kbd_msg_queue( args->buffer, 0 );
> +        break;
> -    case MW_UID_UNREGISTER_DEVICE:
> -      unregister_kbd_msg_queue( 0 );
> -      break;
> +      case MW_UID_UNREGISTER_DEVICE:
> +        unregister_kbd_msg_queue( 0 );
> +        break;
> +    args->ioctl_return = 0;
> +    return RTEMS_SUCCESSFUL;
> -  args->ioctl_return = 0;
> -  return RTEMS_SUCCESSFUL;
> -#else
>  #endif
> diff --git a/c/src/lib/libbsp/i386/pc386/console/console_select.c
> b/c/src/lib/libbsp/i386/pc386/console/console_select.c
> index 6a91a96..f7e6bbc 100644
> --- a/c/src/lib/libbsp/i386/pc386/console/console_select.c
> +++ b/c/src/lib/libbsp/i386/pc386/console/console_select.c
> @@ -3,7 +3,7 @@
>   * @ingroup Console
> - * @brief pc397 console select
> + * @brief pc386 console select
>   * This file contains a routine to select the console based upon a number
>   * of criteria.
> @@ -33,24 +33,6 @@
>    #include <crt.h>
>  #endif
> -#include <bsp/bspimpl.h>
> - * Forward prototype
> -extern bool pc386_com1_com4_enabled(int);
> - * This method is used to determine if COM1-COM4 are enabled based upon
> - * boot command line arguments.
> -static bool are_com1_com4_enabled;
> -bool pc386_com1_com4_enabled(int minor)
> -  return are_com1_com4_enabled;
>   * Method to return true if the device associated with the
>   * minor number probs available.
> @@ -97,48 +79,6 @@ static rtems_device_minor_number
> bsp_First_Available_Device( void )
>    rtems_fatal_error_occurred(RTEMS_IO_ERROR);
> -static bool bsp_find_console_entry(
> -  const char                *match,
> -  size_t                     length,
> -  rtems_device_minor_number *match_minor
> -  rtems_device_minor_number  minor;
> -  const char                *name;
> -  for (minor=0; minor < Console_Port_Count ; minor++) {
> -    console_tbl  *cptr = Console_Port_Tbl[minor];
> -     * Console table entries include /dev/ prefix, device names passed
> -     * in on command line do not.
> -    name = cptr->sDeviceName  + sizeof("/dev");
> -    if ( !strncmp( name, match, length ) ) {
> -      *match_minor = minor;
> -      return true;
> -  return false;
> -static void parse_com1_com4_enable(void)
> -  static const char *opt;
> -   * Check the command line to see if com1-com4 are disabled.
> -  opt = bsp_cmdline_arg("--disable-com1-com4");
> -  if ( opt ) {
> -    printk( "Disable COM1-COM4 per boot argument\n" );
> -    are_com1_com4_enabled = false;
> -  } else {
> -    are_com1_com4_enabled = true;
>  static bool parse_printk_or_console(
>    const char                *param,
>    rtems_device_minor_number *minor_out
> @@ -150,6 +90,7 @@ static bool parse_printk_or_console(
>    size_t                     length;
>    size_t                     index;
> +  console_tbl               *conscfg;
>     * Check the command line for the type of mode the console is.
> @@ -198,16 +139,14 @@ static bool parse_printk_or_console(
>    length = &opt[index] - option;
> -  if ( !bsp_find_console_entry( option, length, &minor ) ) {
> +  conscfg = console_find_console_entry( option, length, &minor );
> +  if ( conscfg == NULL ) {
>      return false;
>    *minor_out = minor;
>    if (comma) {
> -    console_tbl *conscfg = &Console_Configuration_Ports[minor];
>      option = comma + 1;
>      if (strncmp (option, "115200", sizeof ("115200") - 1) == 0)
>        conscfg->pDeviceParams = (void *)115200;
>      else if (strncmp (option, "57600", sizeof ("57600") - 1) == 0)
> @@ -241,39 +180,34 @@ static inline const char *get_name(
>  void pc386_parse_console_arguments(void)
> -   * The console device driver must have its data structures initialized
> -   * before we can iterate the table of devices for names.
> -  console_initialize_data();
> -   * Determine if COM1-COM4 were disabled.
> -  parse_com1_com4_enable();
> +  rtems_device_minor_number minor;
> +  rtems_device_minor_number minor_console = 0;
> +  rtems_device_minor_number minor_printk = 0;
>     * Assume that if only --console is specified, that printk() should
>     * follow that selection by default.
>    if ( parse_printk_or_console( "--console=", &minor ) ) {
> -    Console_Port_Minor = minor;
> -    BSPPrintkPort = minor;
> +    minor_console = minor;
> +    minor_printk = minor;
>     * But if explicitly specified, attempt to honor it.
>    if ( parse_printk_or_console( "--printk=",  &minor ) ) {
> -#if 0
> -  printk( "Console device: %s\n", get_name(Console_Port_Minor) );
> -  printk( "printk device:  %s\n", get_name(BSPPrintkPort) );
> -#endif
> +  printk( "Console: %s printk: %s\n",
> +          get_name(minor_console),get_name(minor_printk) );
> +   * Any output after this can cause problems until termios is
> initialised.
> +  Console_Port_Minor = minor_console;
> +  BSPPrintkPort = minor_printk;
> @@ -283,6 +217,10 @@ void pc386_parse_console_arguments(void)
>  void bsp_console_select(void)
>    #ifdef RTEMS_RUNTIME_CONSOLE_SELECT
> +     * WARNING: This code is really needed any more and should be removed.
> +     *          references to COM1 and COM2 like they are wrong.
>      if ( BSP_runtime_console_select )
>        BSP_runtime_console_select(&BSPPrintkPort, &Console_Port_Minor);
> diff --git a/c/src/lib/libbsp/i386/pc386/console/gdb_select.c
> b/c/src/lib/libbsp/i386/pc386/console/gdb_select.c
> new file mode 100644
> index 0000000..8e64658
> --- /dev/null
> +++ b/c/src/lib/libbsp/i386/pc386/console/gdb_select.c
> @@ -0,0 +1,169 @@
> + * @file
> + * @ingroup GDB
> + * @brief pc386 gdb select
> + * This file contains a routine to enable and select the UART the gdb stub
> + * connects too. Currently limited to COM1 and COM2. See
> + * shared/comm/i386-stub-glue.c file.
> + *  COPYRIGHT (c) 2016.
> + *  Chris Johns <chrisj at rtems.org>
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#include <stdlib.h>
> +#include <bsp.h>
> +#include <rtems/libio.h>
> +#include <rtems/console.h>
> +#include <rtems/termiostypes.h>
> +#include <libchip/serial.h>
> +#include <libchip/ns16550.h>
> + * Used in the stub to print output.
> +int remote_debug;
> + * Defined in the stub, used here.
> +void set_debug_traps(void);
> + * Added here to get a valid baudrate. Needs to go once we
> + * move to the standard UART driver.
> +int BSPBaseBaud;
> +static bool gdb_port_probe(int minor)
> +  /* Return false as GDB has claimed the port */
> +  return false;
> +void pc386_parse_gdb_arguments(void)
> +  static const char *opt;
> +  opt = bsp_cmdline_arg("--gdb=");
> +  if ( opt ) {
> +    const char                *option;
> +    const char                *comma;
> +    size_t                     length;
> +    size_t                     index;
> +    uint32_t                   baudrate = 115200;
> +    bool                       halt = false;
> +    console_tbl               *port;
> +     * Fine the length, there can be more command line visible.
> +    length = 0;
> +    while ((opt[length] != ' ') && (opt[length] != '\0')) {
> +      ++length;
> +      if (length > NAME_MAX) {
> +        printk("invalid option (--gdb): too long\n");
> +        return;
> +     * Only match up to a comma or NULL
> +    index = 0;
> +    while ((opt[index] != '=') && (index < length)) {
> +      ++index;
> +    if (opt[index] != '=') {
> +      printk("invalid option (--gdb): no equals\n");
> +      return;
> +    ++index;
> +    option = &opt[index];
> +    while ((opt[index] != ',') && (index < length)) {
> +      ++index;
> +    if (opt[index] == ',')
> +      comma = &opt[index];
> +    else
> +      comma = NULL;
> +    length = &opt[index] - option;
> +    port = console_find_console_entry( option, length, &minor );
> +    if ( port == NULL ) {
> +      printk("invalid option (--gdb): port not found\n");
> +      return;
> +    if (comma) {
> +      option = comma + 1;
> +      baudrate = strtoul(option, 0, 10);
> +      switch (baudrate) {
> +        case 115200:
> +        case 57600:
> +        case 38400:
> +        case 19200:
> +        case 9600:
> +        case 4800:
> +          port->pDeviceParams = (void*) baudrate;
> +          BSPBaseBaud = baudrate; /* REMOVE ME */
> +          break;
> +        default:
> +          printk("invalid option (--gdb): bad baudrate\n");
> +          return;
Is there anyway the code parsing this option can be shared with that
for the com ports?
> +     * Provide a probe that fails so the device is not part of termios.
> All
> +     * functions are polling.
> +    port->deviceProbe = gdb_port_probe;
> +    port->pDeviceFns = &ns16550_fns_polled;
> +    opt = bsp_cmdline_arg("--gdb-remote-debug");
> +    if ( opt ) {
> +      remote_debug = 1;
> +    opt = bsp_cmdline_arg("--gdb-break");
> +    if ( opt ) {
> +      halt = true;
> +    printk("GDB stub: enable %s%s%s\n",
> +           port->sDeviceName,
> +           remote_debug ? ", remote-debug" : "",
> +           halt ? ", halting" : "");
> +    i386_stub_glue_init(minor);
> +    set_debug_traps();
> +    i386_stub_glue_init_breakin();
> +    if ( halt ) {
> +      printk("GDB stub: waiting for remote connection..\n");
> +      breakpoint();
> diff --git a/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
> b/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
> index 36afb73..60d35e8 100644
> --- a/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
> +++ b/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
> @@ -314,85 +314,88 @@ void pci_uart_probe(void)
>          &fun
>        if ( status == PCIB_ERR_SUCCESS ) {
> +       uint8_t  irq;
> +       uint32_t base;
>          boards++;
>          conf[instance].found = true;
>          conf[instance].clock =  pci_ns8250_ids[i].rclk;
>          conf[instance].ports = 1;
>          total_ports += conf[instance].ports;
> -        break;
> -    if ( status != PCIB_ERR_SUCCESS )
> -      continue;
> -    uint8_t  irq;
> -    uint32_t base;
> +       pci_read_config_byte( bus, dev, fun, PCI_INTERRUPT_LINE, &irq );
> +       pci_read_config_dword( bus, dev, fun, PCI_BASE_ADDRESS_0, &base );
> -    pci_read_config_byte( bus, dev, fun, PCI_INTERRUPT_LINE, &irq );
> -    pci_read_config_dword( bus, dev, fun, PCI_BASE_ADDRESS_0, &base );
> +       conf[instance].irq  = irq;
> +       conf[instance].base = base;
> -    conf[instance].irq  = irq;
> -    conf[instance].base = base;
> -    printk(
> -      "Found %s #%d at 0x%08x IRQ %d with %d clock\n",
> -      pci_ns8250_ids[i].desc,
> -      instance,
> -      conf[instance].base,
> -      conf[instance].irq,
> -      conf[instance].clock
> +        printk(
> +          "Found %s #%d at 0x%08x IRQ %d with %d clock\n",
> +         pci_ns8250_ids[i].desc,
> +         instance,
> +         conf[instance].base,
> +         conf[instance].irq,
> +         conf[instance].clock
>     *  Now allocate array of device structures and fill them in
> -  int device_instance;
> -  ports = calloc( total_ports, sizeof( console_tbl ) );
> -  port_p = ports;
> -  device_instance = 1;
> -  for ( b=0 ; b<MAX_BOARDS ; b++ ) {
> -    if ( conf[b].found == false )
> -      continue;
> -    char name[32];
> -    sprintf( name, "/dev/pcicom%d", device_instance++ );
> -    port_p->sDeviceName   = strdup( name );
> -    port_p->deviceType    = SERIAL_NS16550;
> -    if ( conf[b].irq <= 15 ) {
> -      port_p->pDeviceFns    = &ns16550_fns;
> -    } else {
> -      printk(
> -        "%s IRQ=%d >= 16 requires APIC support, using polling\n",
> -        name,
> -        conf[b].irq <= 15
> -      port_p->pDeviceFns    = &ns16550_fns_polled;
> -    port_p->deviceProbe   = NULL;
> -    port_p->pDeviceFlow   = NULL;
> -    port_p->ulMargin      = 16;
> -    port_p->ulHysteresis  = 8;
> -    port_p->pDeviceParams = (void *) 9600;
> -    port_p->ulCtrlPort1   = conf[b].base;
> -    port_p->ulCtrlPort2   = 0;                   /* NA */
> -    port_p->ulDataPort    = 0;                   /* NA */
> -    port_p->getRegister   = pci_ns16550_get_register;
> -    port_p->setRegister   = pci_ns16550_set_register;
> -    port_p->getData       = NULL;                /* NA */
> -    port_p->setData       = NULL;                /* NA */
> -    port_p->ulClock       = conf[b].clock;
> -    port_p->ulIntVector   = conf[b].irq;
> -    port_p++;
> -  }    /* end boards */
> +  if (boards) {
> +    int device_instance;
> +    ports = calloc( total_ports, sizeof( console_tbl ) );
> +    if (ports != NULL) {
> +      port_p = ports;
> +      device_instance = 1;
> +      for (b = 0; b < MAX_BOARDS; b++) {
> +       char name[32];
> +       if ( conf[b].found == false )
> +         continue;
> +       sprintf( name, "/dev/pcicom%d", device_instance++ );
> +       port_p->sDeviceName   = strdup( name );
> +       port_p->deviceType    = SERIAL_NS16550;
> +       if ( conf[b].irq <= 15 ) {
> +         port_p->pDeviceFns    = &ns16550_fns;
> +       } else {
> +         printk(
> +            "%s IRQ=%d >= 16 requires APIC support, using polling\n",
> +           name,
> +           conf[b].irq
> +         port_p->pDeviceFns    = &ns16550_fns_polled;
> -   *  Register the devices
> -  if ( boards )
> -    console_register_devices( ports, total_ports );
> +       port_p->deviceProbe   = NULL;
> +       port_p->pDeviceFlow   = NULL;
> +       port_p->ulMargin      = 16;
> +       port_p->ulHysteresis  = 8;
> +       port_p->pDeviceParams = (void *) 9600;
> +       port_p->ulCtrlPort1   = conf[b].base;
> +       port_p->ulCtrlPort2   = 0;                   /* NA */
> +       port_p->ulDataPort    = 0;                   /* NA */
> +       port_p->getRegister   = pci_ns16550_get_register;
> +       port_p->setRegister   = pci_ns16550_set_register;
> +       port_p->getData       = NULL;                /* NA */
> +       port_p->setData       = NULL;                /* NA */
> +       port_p->ulClock       = conf[b].clock;
> +       port_p->ulIntVector   = conf[b].irq;
> +       port_p++;
> +      }    /* end boards */
> +       *  Register the devices
> +      console_register_devices( ports, total_ports );
> +       *  Do not free the ports memory, the console hold this memory
> for-ever.
>  #endif
> diff --git a/c/src/lib/libbsp/i386/pc386/include/bsp.h
> b/c/src/lib/libbsp/i386/pc386/include/bsp.h
> index 34516f0..cdfbce6 100644
> --- a/c/src/lib/libbsp/i386/pc386/include/bsp.h
> +++ b/c/src/lib/libbsp/i386/pc386/include/bsp.h
> @@ -197,7 +197,7 @@ void rtems_irq_mngt_init(void);          /* from
> 'irq_init.c' */
>     void *clock_driver_sim_idle_body(uintptr_t);
>     #define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
>     * hack to kill some time. Hopefully hitting a hardware register is
> slower
>     * than an empty loop.
> @@ -255,6 +255,7 @@ void bsp_ide_cmdline_init(void);
>  void init_remote_gdb( void );
>  void i386_stub_glue_init(int uart);
>  void i386_stub_glue_init_breakin(void);
> +int i386_stub_glue_uart(void);
>  void breakpoint(void);
>  #define BSP_MAXIMUM_DEVICES 6
> diff --git a/c/src/lib/libbsp/i386/pc386/include/bspimpl.h
> b/c/src/lib/libbsp/i386/pc386/include/bspimpl.h
> index 6503e0a..314fb91 100644
> --- a/c/src/lib/libbsp/i386/pc386/include/bspimpl.h
> +++ b/c/src/lib/libbsp/i386/pc386/include/bspimpl.h
> @@ -1,7 +1,7 @@
>   * @file
> - * BSP specific helpers
> + * BSP specific helpers
> @@ -30,6 +30,16 @@ const pci_config_access_functions
> *pci_io_initialize(void);
>  void pc386_parse_console_arguments(void);
> + * Helper to parse boot command line arguments related to gdb
> +void pc386_parse_gdb_arguments(void);
> + * Dynamically probe for Legacy UARTS
> +void legacy_uart_probe(void);
>   * Dynamically probe for PCI UARTS
>  void pci_uart_probe(void);
> diff --git a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
> b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
> index 41f858b..0559fbe 100644
> --- a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
> +++ b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
> @@ -10,6 +10,9 @@
>   * It was subsequently adapted as part of the pc386 BSP by developers from
>   * the NavIST Group in 1997.
> + * Copyright (c) 2016.
>   * COPYRIGHT (c) 1989-2008, 2016.
>   * On-Line Applications Research Corporation (OAR).
> @@ -107,16 +110,29 @@ static void bsp_start_default( void )
>    bsp_pci_initialize_helper();
> -   * Probe for UARTs on PCI. One of these may end up as the console.
> +   * Probe for legacy UARTs.
> +  legacy_uart_probe();
> +   * Probe for UARTs on PCI.
>    pci_uart_probe();
> -   * Figure out where printk() and console IO is to be directed.
> -   * Do this after the PCI bus is initialized so we have a chance
> -   * for those devices to be added to the set in the console driver.
> -   * In general, Do it as early as possible so printk() has a chance
> -   * to work early on devices found via PCI probe.
> +   * Parse the GDB arguments and flag a serial port as not valid. This
> stops
> +   * the console from claming the port.
> +#if BSP_GDB_STUB
> +  pc386_parse_gdb_arguments();
> +#endif
> +   * Figure out where printk() and console IO is to be directed.  Do this
> after
> +   * the legacy and PCI bus probes so we have a chance for those devices
> to be
> +   * added to the set in the console driver.  In general, do it as early
> as
> +   * possible so printk() has a chance to work early on devices found via
> PCI
> +   * probe.
>    pc386_parse_console_arguments();
> @@ -127,7 +143,6 @@ static void bsp_start_default( void )
>  #if BSP_ENABLE_IDE
>    bsp_ide_cmdline_init();
>  #endif
>  } /* bsp_start_default */
> diff --git a/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
> b/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
> index 82ff982..ea41874 100644
> --- a/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
> +++ b/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
> @@ -110,7 +110,6 @@ next_step:
>         movw ax, fs
>         movw ax, gs
> -#if (BSP_IS_EDISON == 0)
>  | Now we have to reprogram the interrupts :-(. We put them right after
>  | the intel-reserved hardware interrupts, at int 0x20-0x2F. There they
> @@ -121,6 +120,7 @@ next_step:
>  | it isn't fun.
> +#if (BSP_IS_EDISON == 0)
>         movb    $0x11, al               /* initialization sequence
>         outb    al, $0x20               /* send it to 8259A-1
>         call    SYM(pc386_delay)
> diff --git a/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO
> b/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO
> index c57f5a5..d5e0326 100644
> --- a/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO
> +++ b/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO
> @@ -1,30 +1,31 @@
> -1. Add GDB initilization to your target's code:
> +i386/pc386 GDB Stub
> -a) include file:
> +The i386 GDB stub has been updated to use the libchip drivers for the
> +NS16550. Make sure you have detect the device and you have added a console
> +entry. On the PC the legacy and PCI boards are supported.
> -#include <uart.h>
> +This GDB stub glue code is specific to the UART protocol defined in
> libbchip.
> -b) declare this variable:
> +The pc386 BSP has boot command line options to manage GDB support.
> -extern int BSPConsolePort;
> +a) Find the minor number of the console device:
> -c) To start-up GDB, run this:
> +  #include <console_private.h>
> - /* Init GDB glue  */
> +  rtems_device_minor_number minor = 0;
> -  if(BSPConsolePort != BSP_UART_COM2)
> -       * If com2 is not used as console use it for
> -       * debugging
> -      i386_stub_glue_init(BSP_UART_COM2);
> -  else
> -      /* Otherwise use com1 */
> -      i386_stub_glue_init(BSP_UART_COM1);
> +  if (console_find_console_entry("/dev/com1",
> +                                 strlen("/dev/com1") - 1, &minor) == NULL)
> +    error("driver not found\n");
> +Note, this call is part of the private console API and may change.
> +b) To start GDB stub, run this:
> +  #include <bsp.h>
> +  /* Init GDB glue  */
>    /* Init GDB stub itself */
>    set_debug_traps();
> @@ -39,54 +40,45 @@ c) To start-up GDB, run this:
>    /* Put breakpoint in */
>    breakpoint();
> -d) This is all you need to do for the target.
> -2. Edit cmds: specify path to current directory and device used for
> debugging
> -   example of cmds is attached below.  Make sure your paths are correct.
> -3. type 'make'
> -4. Boot o-pc386/<test>.exe on target computer, where <test> has the code
> from step 1. ( I modified and recompiled base_sp as the <test> )
> -5. run 'i396-rtems-gdb --nx --command=./cmds o-pc386/<test>.coff
> -=========================== example cmds ==============================
> -/usr1/rtems/work/rtems/cpukit/ada
> -/usr1/rtems/work/rtems/cpukit/libblock/src
> -/usr1/rtems/work/rtems/cpukit/libcsupport/src
> -/usr1/rtems/work/rtems/cpukit/libfs/src/dosfs
> -/usr1/rtems/work/rtems/cpukit/libfs/src/imfs
> -/usr1/rtems/work/rtems/cpukit/libmisc/capture
> -/usr1/rtems/work/rtems/cpukit/libmisc/cpuuse
> -/usr1/rtems/work/rtems/cpukit/libmisc/devnull
> -/usr1/rtems/work/rtems/cpukit/libmisc/dummy
> -/usr1/rtems/work/rtems/cpukit/libmisc/dumpbuf
> -/usr1/rtems/work/rtems/cpukit/libmisc/monitor
> -/usr1/rtems/work/rtems/cpukit/libmisc/mw-fb
> -/usr1/rtems/work/rtems/cpukit/libmisc/rtmonuse
> -/usr1/rtems/work/rtems/cpukit/libmisc/serdbg
> -/usr1/rtems/work/rtems/cpukit/libmisc/shell
> -/usr1/rtems/work/rtems/cpukit/libmisc/stackchk
> -/usr1/rtems/work/rtems/cpukit/libmisc/untar
> -/usr1/rtems/work/rtems/cpukit/libnetworking/arpa
> -/usr1/rtems/work/rtems/cpukit/libnetworking/kern
> -/usr1/rtems/work/rtems/cpukit/libnetworking/lib
> -/usr1/rtems/work/rtems/cpukit/libnetworking/libc
> -/usr1/rtems/work/rtems/cpukit/libnetworking/machine
> -/usr1/rtems/work/rtems/cpukit/libnetworking/net
> -/usr1/rtems/work/rtems/cpukit/libnetworking/netinet
> -/usr1/rtems/work/rtems/cpukit/libnetworking/nfs
> -/usr1/rtems/work/rtems/cpukit/libnetworking/rtems
> -/usr1/rtems/work/rtems/cpukit/libnetworking/sys
> -/usr1/rtems/work/rtems/cpukit/libnetworking/vm
> -/usr1/rtems/work/rtems/cpukit/librpc/src/rpc
> -/usr1/rtems/work/rtems/cpukit/librpc/src/xdr
> -/usr1/rtems/work/rtems/cpukit/posix/src
> -/usr1/rtems/work/rtems/cpukit/posix/inline/rtems/posix
> -/usr1/rtems/work/rtems/cpukit/rtems/inline/rtems/rtems
> -/usr1/rtems/work/rtems/cpukit/rtems/src
> -/usr1/rtems/work/rtems/cpukit/sapi/inline/rtems
> -/usr1/rtems/work/rtems/cpukit/sapi/src
> -/usr1/rtems/work/rtems/cpukit/score/cpu/i386
> -/usr1/rtems/work/rtems/cpukit/score/cpu/i386/rtems/score
> -/usr1/rtems/work/rtems/cpukit/score/src
> -/usr1/rtems/work/rtems/cpukit/score/inline/rtems/score
> -set remotebaud 38400
> -target remote /dev/ttyS1
> +c) To run use GDB:
> +  $ i386-rtems4.12-gdb hello.exe
> +  GNU gdb (GDB) 7.11
> +  Copyright (C) 2016 Free Software Foundation, Inc.
> +  License GPLv3+: GNU GPL version 3 or later <
> http://gnu.org/licenses/gpl.html>
> +  This is free software: you are free to change and redistribute it.
> +  There is NO WARRANTY, to the extent permitted by law.  Type "show
> copying"
> +  and "show warranty" for details.
> +  This GDB was configured as "--host=x86_64-freebsd10.1
> --target=i386-rtems4.12".
> +  Type "show configuration" for configuration details.
> +  For bug reporting instructions, please see:
> +  <http://www.gnu.org/software/gdb/bugs/>.
> +  Find the GDB manual and other documentation resources online at:
> +  <http://www.gnu.org/software/gdb/documentation/>.
> +  For help, type "help".
> +  Type "apropos word" to search for commands related to "word"...
> +  Reading symbols from hello.exe...done.
> +  (gdb) target remote /dev/cuaU5
> +  Remote debugging using /dev/cuaU5
> +  0x00103fda in breakpoint () at i386-stub.c:1004
> +  1004          BREAKPOINT ();
> +  (gdb) b Init
> +  Breakpoint 1 at 0x1001e0: file init.c, line 29.
> +  (gdb) c
> +  Continuing.
> +  Breakpoint 1, Init (ignored=1269800) at init.c:29
> +  29      {
> +  (gdb)
> +Pressing ^C works and if running the board should halt when GDB connects.
> +e) Use ser2net to provide reomve access over a network to a board.
> Install the
> +ser2net package and add a configuration for the port GDB connects to. For
> +example:
> + 0005:raw:0:/dev/cuaU5:115200
> +Start ser2net running then connect GDB using:
> + (gdb) target remote myhost:30005
> diff --git a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
> b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
> index 121eef1..25a153f 100644
> --- a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
> +++ b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
> @@ -1,23 +1,102 @@
>   * This software is Copyright (C) 1998 by T.sqware - all rights limited
>   * It is provided in to the public domain "as is", can be freely modified
>   * as far as this copyight notice is kept unchanged, but does not imply
>   * an endorsement by T.sqware of the product in which it is included.
> -#include <rtems/system.h>
> -#include <rtems/score/cpu.h>
>  #include <bsp.h>
> -#include <uart.h>
> -#include <assert.h>
>  int  putDebugChar(int ch);     /* write a single character      */
>  int  getDebugChar(void);       /* read and return a single char */
> +/* Check is any characters received are a ^C */
> +int i386_gdb_uart_ctrl_c_check(void);
> +/* Raw interrupt handler. */
> +void i386_gdb_uart_isr(void);
>  /* assign an exception handler */
>  void exceptionHandler(int, void (*handler)(void));
> +/* User supplied remote debug option. */
> +extern int remote_debug;
> +/* Current uart and port used by the gdb stub */
> +static int          uart_current;
> +static console_tbl* port_current;
> + * Interrupt service routine for all, it does it check whether ^C is
> received
> + * if yes it will flip TF bit before returning.
> + * Note: it should be installed as raw interrupt handler.
> + * Warning: I do not like the use of the global data, I am not
> + *          sure if this is SMP safe.
> +int i386_gdb_uart_isr_regsav[4] RTEMS_UNUSED;
> +__asm__ (".p2align 4");
> +__asm__ (".text");
> +__asm__ (".globl i386_gdb_uart_isr");
> +__asm__ ("i386_gdb_uart_isr:");
> +__asm__ ("    pusha");                                       /* Push all
> +__asm__ ("    call  i386_gdb_uart_ctrl_c_check");            /* Look for
> ^C */
> +__asm__ ("    movl  %eax, i386_gdb_uart_isr_regsav");        /* Save eax
> +__asm__ ("    popa");                                        /* Pop all */
> +__asm__ ("    xchgl %eax, i386_gdb_uart_isr_regsav");        /* Exchange
> eax */
> +__asm__ ("    cmpl  $0, %eax");                              /* 1 == ^C */
> +__asm__ ("    je    i386_gdb_uart_isr_1");                   /* branch if
> 0 */
> +__asm__ ("    movl  %ebx, i386_gdb_uart_isr_regsav + 4");    /* Save ebx
> +__asm__ ("    movl  %edx, i386_gdb_uart_isr_regsav + 8");    /* Save edx
> +__asm__ ("    popl  %ebx");                                  /* Pop eip */
> +__asm__ ("    popl  %edx");                                  /* Pop cs */
> +__asm__ ("    popl  %eax");                                  /* Pop flags
> +__asm__ ("    orl   $0x100, %eax");                          /* Modify it
> +__asm__ ("    pushl %eax");                                  /* Push it
> back */
> +__asm__ ("    pushl %edx");                                  /* Push cs */
> +__asm__ ("    pushl %ebx");                                  /* Push eip
> +__asm__ ("    movl  i386_gdb_uart_isr_regsav + 4, %ebx");    /* Restore
> ebx */
> +__asm__ ("    movl  i386_gdb_uart_isr_regsav + 8, %edx");    /* Restore
> edx */
> +__asm__ ("i386_gdb_uart_isr_1:");
> +__asm__ ("    movb  $0x20, %al");
> +__asm__ ("    outb  %al, $0x20");
> +__asm__ ("    movl  i386_gdb_uart_isr_regsav, %eax");        /* Restore
> eax */
> +__asm__ ("    iret");                                        /* Done */
> +static int gdb_hello_index;
> +static const char const* gdb_hello = "+";
> +  if (port_current) {
> +    int c = 0;
> +    while (c >= 0) {
> +      c = port_current->pDeviceFns->deviceRead(uart_current);
> +      if (c == 3) {
> +        gdb_hello_index = 0;
> +        return 1;
> +      } else if (gdb_hello[gdb_hello_index] == (char) c) {
> +        ++gdb_hello_index;
> +        if (gdb_hello[gdb_hello_index] == '\0') {
> +          return 1;
> +      } else {
> +  return 0;
>  static void
>  nop(const rtems_raw_irq_connect_data* notused)
> @@ -29,10 +108,12 @@ isOn(const rtems_raw_irq_connect_data* notused)
>    return 1;
> -void BSP_loop(int uart);
> -/* Current uart used by gdb stub */
> -static int uart_current = 0;
> +  if (port_current == NULL)
> +    return -1;
> +  return uart_current;
>   * Initialize glue code linking i386-stub with the rest of
> @@ -41,12 +122,19 @@ static int uart_current = 0;
>  void
> -  assert(uart == BSP_UART_COM1 || uart == BSP_UART_COM2);
> +  rtems_device_minor_number minor = (rtems_device_minor_number) uart;
> +  port_current = console_find_console_entry(NULL, 0, &minor);
> +  if (port_current == NULL) {
> +    printk("GDB: invalid minor number for UART\n");
> +    return;
>    uart_current = uart;
> -  /* BSP_uart_init(uart, 38400, CHR_8_BITS, 0, 0, 0);*/
> -  BSP_uart_init(uart, 115200, CHR_8_BITS, 0, 0, 0);
> +  /* Intialise the UART, assuming polled drivers */
> +  port_current->pDeviceFns->deviceInitialize(uart);
>  static void BSP_uart_on(const rtems_raw_irq_connect_data* used)
> @@ -72,76 +160,65 @@ void i386_stub_glue_init_breakin(void)
>    rtems_raw_irq_connect_data uart_raw_irq_data;
> -  assert(uart_current == BSP_UART_COM1 || uart_current == BSP_UART_COM2);
> +    printk("GDB: no port initialised\n");
> +    return;
> -  if(uart_current == BSP_UART_COM1)
> -      uart_raw_irq_data.idtIndex = BSP_UART_COM1_IRQ +
> BSP_IRQ_VECTOR_BASE;
> -  else
> -      uart_raw_irq_data.idtIndex = BSP_UART_COM2_IRQ +
> +  if ((port_current->ulIntVector == 0) || (port_current->ulIntVector >
> 16)) {
> +    printk("GDB: no UART interrupt support\n");
> +  else {
> +    uart_raw_irq_data.idtIndex = port_current->ulIntVector +
> -  if(!i386_get_current_idt_entry(&uart_raw_irq_data))
> -      printk("cannot get idt entry\n");
> +    if (!i386_get_current_idt_entry(&uart_raw_irq_data)) {
> +      printk("GBD: cannot get idt entry\n");
>        rtems_fatal_error_occurred(1);
> -  if(!i386_delete_idt_entry(&uart_raw_irq_data))
> -      printk("cannot delete idt entry\n");
> +    if (!i386_delete_idt_entry(&uart_raw_irq_data)) {
> +      printk("GDB: cannot delete idt entry\n");
> -  uart_raw_irq_data.on  = BSP_uart_on;
> -  uart_raw_irq_data.off = BSP_uart_off;
> -  uart_raw_irq_data.isOn= BSP_uart_isOn;
> +    uart_raw_irq_data.on  = BSP_uart_on;
> +    uart_raw_irq_data.off = BSP_uart_off;
> +    uart_raw_irq_data.isOn= BSP_uart_isOn;
> -  /* Install ISR  */
> -      uart_raw_irq_data.hdl = BSP_uart_dbgisr_com1;
> -  else
> -      uart_raw_irq_data.hdl = BSP_uart_dbgisr_com2;
> +    /* Install ISR  */
> +    uart_raw_irq_data.hdl = i386_gdb_uart_isr;
> -  if (!i386_set_idt_entry (&uart_raw_irq_data))
> -      printk("raw exception handler connection failed\n");
> +    if (!i386_set_idt_entry (&uart_raw_irq_data)) {
> +      printk("GDB: raw exception handler connection failed\n");
> -  /* Enable interrupts */
> -  BSP_uart_intr_ctrl(uart_current, BSP_UART_INTR_CTRL_GDB);
> -  return;
> +    /* Enable interrupts, this is a bit of a hack because we
> +     * have to know the device but there is no other call. */
> +    (*port_current->setRegister)(port_current->ulCtrlPort1, 1, 0x01);
>  int
> -  BSP_uart_polled_write(uart_current, ch);
> +  if (port_current != NULL) {
> +    port_current->pDeviceFns->deviceWritePolled(uart_current, ch);
>    return 1;
> -  int val;
> +  int c = -1;
> -  val = BSP_uart_polled_read(uart_current);
> +    while (c < 0)
> -  return val;
> +  return c;
>  void exceptionHandler(int vector, void (*handler)(void))
> @@ -152,13 +229,13 @@ void exceptionHandler(int vector, void
> (*handler)(void))
>    if(!i386_get_current_idt_entry(&excep_raw_irq_data))
> +      printk("GDB: cannot get idt entry\n");
>    if(!i386_delete_idt_entry(&excep_raw_irq_data))
> @@ -168,7 +245,7 @@ void exceptionHandler(int vector, void
> (*handler)(void))
>    excep_raw_irq_data.hdl = handler;
>    if (!i386_set_idt_entry (&excep_raw_irq_data)) {
>    return;
> diff --git a/c/src/lib/libbsp/i386/shared/comm/i386-stub.c
> b/c/src/lib/libbsp/i386/shared/comm/i386-stub.c
> index bc72396..b3630ee 100644
> --- a/c/src/lib/libbsp/i386/shared/comm/i386-stub.c
> +++ b/c/src/lib/libbsp/i386/shared/comm/i386-stub.c
> @@ -99,6 +99,8 @@
>  #include <string.h>
>  #include <stdbool.h>
> +#include <bsp.h>
>   * Prototypes we need to avoid warnings but not going into public space.
> @@ -150,11 +152,15 @@ enum regnames
>   * these should not be static cuz they can be used outside this module
> -int registers[NUMREGS];
> +int i386_gdb_registers[NUMREGS];
>  #define STACKSIZE 10000
> -int remcomStack[STACKSIZE / sizeof (int)];
> -static int *stackPtr = &remcomStack[STACKSIZE / sizeof (int) - 1];
> +int i386_gdb_remcomStack[STACKSIZE / sizeof (int)];
> +int *i386_gdb_stackPtr = &i386_gdb_remcomStack[STACKSIZE / sizeof (int) -
> 1];
> +static int gdb_connected;
>  /***************************  ASSEMBLY CODE MACROS
> @@ -168,25 +174,25 @@ extern void
>  __asm__ (".text");
>  __asm__ (".globl return_to_prog");
>  __asm__ ("return_to_prog:");
> -__asm__ ("        movw registers+44, %ss");
> -__asm__ ("        movl registers+16, %esp");
> -__asm__ ("        movl registers+4, %ecx");
> -__asm__ ("        movl registers+8, %edx");
> -__asm__ ("        movl registers+12, %ebx");
> -__asm__ ("        movl registers+20, %ebp");
> -__asm__ ("        movl registers+24, %esi");
> -__asm__ ("        movl registers+28, %edi");
> -__asm__ ("        movw registers+48, %ds");
> -__asm__ ("        movw registers+52, %es");
> -__asm__ ("        movw registers+56, %fs");
> -__asm__ ("        movw registers+60, %gs");
> -__asm__ ("        movl registers+36, %eax");
> +__asm__ ("        movw i386_gdb_registers+44, %ss");
> +__asm__ ("        movl i386_gdb_registers+16, %esp");
> +__asm__ ("        movl i386_gdb_registers+4, %ecx");
> +__asm__ ("        movl i386_gdb_registers+8, %edx");
> +__asm__ ("        movl i386_gdb_registers+12, %ebx");
> +__asm__ ("        movl i386_gdb_registers+20, %ebp");
> +__asm__ ("        movl i386_gdb_registers+24, %esi");
> +__asm__ ("        movl i386_gdb_registers+28, %edi");
> +__asm__ ("        movw i386_gdb_registers+48, %ds");
> +__asm__ ("        movw i386_gdb_registers+52, %es");
> +__asm__ ("        movw i386_gdb_registers+56, %fs");
> +__asm__ ("        movw i386_gdb_registers+60, %gs");
> +__asm__ ("        movl i386_gdb_registers+36, %eax");
>  __asm__ ("        pushl %eax");        /* saved eflags */
> -__asm__ ("        movl registers+40, %eax");
> +__asm__ ("        movl i386_gdb_registers+40, %eax");
>  __asm__ ("        pushl %eax");        /* saved cs */
> -__asm__ ("        movl registers+32, %eax");
> +__asm__ ("        movl i386_gdb_registers+32, %eax");
>  __asm__ ("        pushl %eax");        /* saved eip */
> -__asm__ ("        movl registers, %eax");
> +__asm__ ("        movl i386_gdb_registers, %eax");
>  /* use iret to restore pc and flags together so
>     that trace flag works right.  */
>  __asm__ ("        iret");
> @@ -202,37 +208,37 @@ int gdb_i386vector = -1;
>  /* GDB stores segment registers in 32-bit words (that's just the way
>     m-i386v.h is written).  So zero the appropriate areas in registers.  */
>  #define SAVE_REGISTERS1() \
> -  __asm__ ("movl %eax, registers");                                      \
> -  __asm__ ("movl %ecx, registers+4");
> -  __asm__ ("movl %edx, registers+8");
> -  __asm__ ("movl %ebx, registers+12");
> -  __asm__ ("movl %ebp, registers+20");
> -  __asm__ ("movl %esi, registers+24");
> -  __asm__ ("movl %edi, registers+28");
> -  __asm__ ("movw $0, %ax");
> -  __asm__ ("movw %ds, registers+48");
> -  __asm__ ("movw %ax, registers+50");
> -  __asm__ ("movw %es, registers+52");
> -  __asm__ ("movw %ax, registers+54");
> -  __asm__ ("movw %fs, registers+56");
> -  __asm__ ("movw %ax, registers+58");
> -  __asm__ ("movw %gs, registers+60");
> -  __asm__ ("movw %ax, registers+62");
> +  __asm__ ("movl %eax, i386_gdb_registers");                           \
> +  __asm__ ("movl %ecx, i386_gdb_registers+4");                         \
> +  __asm__ ("movl %edx, i386_gdb_registers+8");                         \
> +  __asm__ ("movl %ebx, i386_gdb_registers+12");
> +  __asm__ ("movl %ebp, i386_gdb_registers+20");
> +  __asm__ ("movl %esi, i386_gdb_registers+24");
> +  __asm__ ("movl %edi, i386_gdb_registers+28");
> +  __asm__ ("movw $0, %ax");                                            \
> +  __asm__ ("movw %ds, i386_gdb_registers+48");                         \
> +  __asm__ ("movw %ax, i386_gdb_registers+50");                         \
> +  __asm__ ("movw %es, i386_gdb_registers+52");                         \
> +  __asm__ ("movw %ax, i386_gdb_registers+54");                         \
> +  __asm__ ("movw %fs, i386_gdb_registers+56");                         \
> +  __asm__ ("movw %ax, i386_gdb_registers+58");                         \
> +  __asm__ ("movw %gs, i386_gdb_registers+60");                         \
> +  __asm__ ("movw %ax, i386_gdb_registers+62");
>  #define SAVE_ERRCODE() \
> -  __asm__ ("popl %ebx");                                  \
> +  __asm__ ("popl %ebx");                       \
>    __asm__ ("movl %ebx, gdb_i386errcode");
>  #define SAVE_REGISTERS2() \
> -  __asm__ ("popl %ebx"); /* old eip */
> -  __asm__ ("movl %ebx, registers+32");
> -  __asm__ ("popl %ebx");        /* old cs */
> -  __asm__ ("movl %ebx, registers+40");
> -  __asm__ ("movw %ax, registers+42");
> -  __asm__ ("popl %ebx");        /* old eflags */
> -  __asm__ ("movl %ebx, registers+36");
> -  /* Now that we've done the pops, we can save the stack pointer.");  */
> -  __asm__ ("movw %ss, registers+44");
> -  __asm__ ("movw %ax, registers+46");
> -  __asm__ ("movl %esp, registers+16");
> +  __asm__ ("popl %ebx"); /* old eip */                                 \
> +  __asm__ ("movl %ebx, i386_gdb_registers+32");
> +  __asm__ ("popl %ebx");        /* old cs */                           \
> +  __asm__ ("movl %ebx, i386_gdb_registers+40");
> +  __asm__ ("movw %ax, i386_gdb_registers+42");                         \
> +  __asm__ ("popl %ebx");        /* old eflags */                       \
> +  __asm__ ("movl %ebx, i386_gdb_registers+36");
> +  /* Now that we've done the pops, we can save the stack pointer.");  */ \
> +  __asm__ ("movw %ss, i386_gdb_registers+44");                         \
> +  __asm__ ("movw %ax, i386_gdb_registers+46");                         \
> +  __asm__ ("movl %esp, i386_gdb_registers+16");
>  /* See if mem_fault_routine is set, if so just IRET to that address.  */
>  #define CHECK_FAULT() \
> @@ -449,7 +455,7 @@ extern void remcomHandler (void);
>  __asm__ ("_remcomHandler:");
>  __asm__ ("           popl %eax");      /* pop off return address     */
>  __asm__ ("           popl %eax");      /* get the exception number   */
> -__asm__ ("             movl stackPtr, %esp");  /* move to remcom stack
> area  */
> +__asm__ ("             movl i386_gdb_stackPtr, %esp"); /* move to remcom
> stack area */
>  __asm__ ("             pushl %eax");   /* push exception onto stack  */
>  __asm__ ("             call  handle_exception");       /* this never
> returns */
> @@ -508,10 +514,15 @@ getpacket (char *buffer)
>           xmitcsum += hex (getDebugChar () & 0x7f);
>           if ((remote_debug) && (checksum != xmitcsum))
> -             fprintf (stderr, "bad checksum.  My count = 0x%x, sent=0x%x.
> buf=%s\n",
> -                      checksum, xmitcsum, buffer);
> +             printk ("bad checksum.  My count = 0x%x, sent=0x%x.
> buf=%s\n",
> +                     checksum, xmitcsum, buffer);
> +         if (remote_debug) {
> +           printk("GETP: $%s...%s\n", buffer,
> +                  checksum == xmitcsum ? "Ack" : "Nack");
>           if (checksum != xmitcsum)
>             putDebugChar ('-'); /* failed checksum */
>           else
> @@ -539,13 +550,16 @@ getpacket (char *buffer)
>  static void
>  putpacket (char *buffer)
> -  unsigned char checksum;
> -  int count;
> -  char ch;
>    /*  $<packet info>#<checksum>. */
> -  do
> +  while (true)
> +      unsigned char checksum;
> +      int count;
> +      char ch;
> +      if (remote_debug)
> +       printk("PUTP: $%s", buffer);
>        putDebugChar ('$');
>        checksum = 0;
>        count = 0;
> @@ -562,9 +576,18 @@ putpacket (char *buffer)
>        putDebugChar (hexchars[checksum >> 4]);
>        putDebugChar (hexchars[checksum % 16]);
> -  while ((getDebugChar () & 0x7f) != '+');
> +      if (remote_debug)
> +       printk("#%c%c...", hexchars[checksum >> 4], hexchars[checksum %
> 16]);
> +      ch = getDebugChar () & 0x7f;
> +      if (ch == '+') {
> +       if (remote_debug)
> +         printk("Ack\n");
> +       break;
> +      if (remote_debug)
> +       printk("Nack(%c)\n", ch);
>  char remcomInBuffer[BUFMAX];
> @@ -578,7 +601,7 @@ debug_error (
>    if (remote_debug)
> -    fprintf (stderr, format, parm);
> +    printk (format, parm);
>  /* Address of a routine to RTE to if we get a memory fault.  */
> @@ -764,10 +787,10 @@ handle_exception (int exceptionVector)
>    gdb_i386vector = exceptionVector;
>    if (remote_debug)
> -    printf ("vector=%d, sr=0x%x, pc=0x%x\n",
> +    printk ("GDB: EXECPTION: vector=%d, sr=0x%x, pc=0x%x\n",
>             exceptionVector,
> -           registers[PS],
> -           registers[PC]);
> +           i386_gdb_registers[PS],
> +           i386_gdb_registers[PC]);
>    /* Reply to host that an exception has occurred.  Always return the
>       PC, SP, and FP, since gdb always wants them.  */
> @@ -779,31 +802,33 @@ handle_exception (int exceptionVector)
>    *ptr++ = hexchars[ESP];
>    *ptr++ = ':';
> -  mem2hex ((char *) &registers[ESP], ptr, REGBYTES, 0);
> +  mem2hex ((char *) &i386_gdb_registers[ESP], ptr, REGBYTES, 0);
>    ptr += REGBYTES * 2;
>    *ptr++ = ';';
>    *ptr++ = hexchars[EBP];
>    *ptr++ = ':';
> -  mem2hex ((char *) &registers[EBP], ptr, REGBYTES, 0);
> +  mem2hex ((char *) &i386_gdb_registers[EBP], ptr, REGBYTES, 0);
>    *ptr++ = ';';
>    *ptr++ = hexchars[PC];
>    *ptr++ = ':';
> -  mem2hex ((char *) &registers[PC], ptr, REGBYTES, 0);
> +  mem2hex ((char *) &i386_gdb_registers[PC], ptr, REGBYTES, 0);
>    *ptr++ = ';';
>    *ptr = '\0';
> -  putpacket (remcomOutBuffer);
> +  if (gdb_connected)
> +    putpacket (remcomOutBuffer);
>    while (1 == 1)
>        error = 0;
>        remcomOutBuffer[0] = 0;
>        getpacket (remcomInBuffer);
> +      gdb_connected = 1;
>        switch (remcomInBuffer[0])
>         case '?':
> @@ -812,14 +837,14 @@ handle_exception (int exceptionVector)
>           remcomOutBuffer[2] = hexchars[sigval % 16];
>           remcomOutBuffer[3] = 0;
>           break;
> -       case 'd':
> +       case 'd': /* remove */
>           remote_debug = !(remote_debug);       /* toggle debug flag */
>           break;
>         case 'g':               /* return the value of the CPU registers */
> -         mem2hex ((char *) registers, remcomOutBuffer, NUMREGBYTES, 0);
> +         mem2hex ((char *) i386_gdb_registers, remcomOutBuffer,
> NUMREGBYTES, 0);
>           break;
>         case 'G':               /* set the value of the CPU registers -
> return OK */
> -         hex2mem (&remcomInBuffer[1], (char *) registers, NUMREGBYTES, 0);
> +         hex2mem (&remcomInBuffer[1], (char *) i386_gdb_registers,
> NUMREGBYTES, 0);
>           strcpy (remcomOutBuffer, "OK");
>           break;
> @@ -828,7 +853,7 @@ handle_exception (int exceptionVector)
>           if (hexToInt (&ptr, &reg)
>               && *ptr++ == '=')
> -             hex2mem (ptr, (char *) &registers[reg], REGBYTES, 0);
> +             hex2mem (ptr, (char *) &i386_gdb_registers[reg], REGBYTES,
> 0);
>           else
> @@ -902,29 +927,31 @@ handle_exception (int exceptionVector)
>           /* try to read optional parameter, pc unchanged if no parm */
>           ptr = &remcomInBuffer[1];
>           if (hexToInt (&ptr, &addr))
> -           registers[PC] = addr;
> +           i386_gdb_registers[PC] = addr;
>           /* clear the trace bit */
> -         registers[PS] &= 0xfffffeff;
> +         i386_gdb_registers[PS] &= 0xfffffeff;
>           /* set the trace bit if we're stepping */
>           if (remcomInBuffer[0] == 's')
> -           registers[PS] |= 0x100;
> +           i386_gdb_registers[PS] |= 0x100;
>           _returnFromException ();      /* this is a jump */
>           break;
>           /* Detach.  */
>         case 'D':
>           break;
>           /* kill the program */
>         case 'k':               /* do nothing */
> +         bsp_reset();
> +         continue;
> +       default:
>           break;
>         }                       /* switch */
> @@ -938,7 +965,7 @@ handle_exception (int exceptionVector)
>  void
>  set_debug_traps (void)
> -  stackPtr = &remcomStack[STACKSIZE / sizeof (int) - 1];
> +  i386_gdb_stackPtr = &i386_gdb_remcomStack[STACKSIZE / sizeof (int) - 1];
>    exceptionHandler (0, _catchException0);
>    exceptionHandler (1, _catchException1);
> diff --git a/c/src/lib/libbsp/shared/console.c
> b/c/src/lib/libbsp/shared/console.c
> index d226172..b4af1b3 100644
> --- a/c/src/lib/libbsp/shared/console.c
> +++ b/c/src/lib/libbsp/shared/console.c
> @@ -34,6 +34,45 @@ rtems_device_minor_number   Console_Port_Minor  = 0;
>  static bool                 console_initialized = false;
> + *  console_find_console_entry
> + *  This method is used to search the console entries for a
> + *  specific device entry.
> +console_tbl* console_find_console_entry(
> +  const char                *match,
> +  size_t                     length,
> +  rtems_device_minor_number *match_minor
> +   * The the match name is NULL get the minor number entry.
> +  if (match == NULL) {
> +    if (*match_minor < Console_Port_Count)
> +      return Console_Port_Tbl[*match_minor];
> +    return NULL;
> +  for (minor=0; minor < Console_Port_Count ; minor++) {
> +    console_tbl  *cptr = Console_Port_Tbl[minor];
> +     * Console table entries include /dev/ prefix, device names passed
> +     * in on command line do not.
> +    if ( !strncmp( cptr->sDeviceName, match, length ) ) {
> +      *match_minor = minor;
> +      return cptr;
> +  return NULL;
>   *  console_initialize_data
>   *  This method is used to initialize the table of pointers to the
> @@ -278,9 +317,7 @@ rtems_device_driver console_initialize(
>     * must still initialize pointers for Console_Port_Tbl and
>     * Console_Port_Data.
> -  if ( !Console_Port_Tbl ) {
> +  console_initialize_data();
>     *  console_initialize has been invoked so it is now too late to
> diff --git a/c/src/lib/libbsp/shared/console_private.h
> b/c/src/lib/libbsp/shared/console_private.h
> index 42a8ee9..3855e83 100644
> --- a/c/src/lib/libbsp/shared/console_private.h
> +++ b/c/src/lib/libbsp/shared/console_private.h
> @@ -41,6 +41,19 @@ int vt_ioctl(
> + *  @brief console_find_console_entry
> + *  specific device entry and return it. If match is NULL the
> + *  minor number provided is matched.
> +  size_t                     length,
>   *  @brief console_initialize_data
>   *  This must be called before dynamic registration of devices can occur.
> 2.4.6
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160420/9ee57f9f/attachment-0002.html>
