[PATCH 00/13] Replace mongoose with civetweb.
Thu Apr 21 20:45:42 UTC 2016
Is the plan eventually to be able to use the upstream civetweb? or to
track it with our own copy?
On Thu, Apr 21, 2016 at 4:49 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> This patch series replaces the mongoose webserver by its still MIT
> licensed fork civetweb.
> Please note that I try to get some (currently two) of the patches
> directly into civetweb too. But I think that it might need some time and
> adaption till they are accepted. So I thought that adding them to RTEMS
> would still make sense as a working interim solution.
> devel mailing list
> devel at rtems.org
