Internal time representations
Sebastian Huber
Mon Aug 1 05:26:35 UTC 2016
On 28/07/16 16:53, Gedare Bloom wrote:
> Hi Sebastian,
> The problem that I encountered was that there are two different
> representations used for the watchdogs, the 34+30 compact timespec,
> a.k.a. "watchdog ticks", used for absolute, and the 64-bit "score
> ticks" used for relative. Since both of these are called ticks
> internally, I had a bit of confusion on what to use, and which
> interfaces for converting time formats into something each watchdog
> uses as a timeout. Pavel suggested that switching to a single format
> would help reduce confusion, and may help with variable clock ticks.
I still think that the time formats for the watchdogs are the right
ones. Maybe we should rename
_Watchdog_Ticks_from_seconds() -> _Watchdog_Expiration_time_from_seconds()
_Watchdog_Ticks_from_timespec() -> _Watchdog_Expiration_time_from_timespec()
We already have a Watchdog_Control:
/** @brief This field is the expiration time point. */
uint64_t expire;
> Perhaps the FreeBSD time counters are a sufficient representation to
> handle setting up variable ticks. Confusion might also be less if we
> don't use the same terminology "ticks" for the two different formats.
> Relative are actual "ticks" based on the configured RTEMS clock, while
> absolute are ns time-based.
> Gedare
> On Thu, Jul 28, 2016 at 2:23 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> I am not sure which problem you want to address. For the watchdogs we use
>> currently a 64-bit integer key for relative and absolute timeouts. For the
>> watchdog it is important that
>> * the key comparison operations are fast,
>> * the conversion from common time formats to the key are fast, and
>> * there is no integer overflow within a reasonable time frame.
>> This is all satisfied currently. It is NOT important to convert this key
>> into a common time format, since there is no use case for this.
>> For timekeeping we use the FreeBSD time counters (provider for
>> CLOCK_REALTIME and CLOCK_MONOTONIC). They use struct bintime (aka
>> Timestamp_Control) for time representation. It allows fast conversion
>> to/from common time formats. Addition is also fast. In addition there is a
>> sbintime_t available which can be used for some problem domains as an
>> optimization.
>> For NTP and PPS we just have to port the code from FreeBSD. It is very well
>> integrated into the FreeBSD time counters.
>> On 27/07/16 23:29, Pavel Pisa wrote:
>>> Hello Gedare,
>>> thanks much for the great summary of the discussion.
>>> On Wednesday 27 of July 2016 18:30:02 Gedare Bloom wrote:
>>>> After an IRC chat this morning with Pavel, we've decided to query
>>>> everyone about thoughts on unifying the internal score representations
>>>> for time into a single format. This discussion comes from the work
>>>> I've done with nanosleep, which now uses both the relative and
>>>> absolute watchdogs that have two different representations of
>>>> time--relative uses the score "ticks", and absolute uses a 64-bit
>>>> compacted version of timespec with seconds in the upper 32-bits and ns
>>>> in the lower 32. The proposed format is a count of nanoseconds in
>>>> 64-bits, or ns64.
>>> minor correction, copact time works in 34+30 bit format so it
>>> has no 2038 problem (final year is about 2514 for unsigned
>>> and 2242 for signed representation)
>>> https://git.rtems.org/rtems/tree/cpukit/score/include/rtems/score/watchdogimpl.h#n295
>>> On the other hand, conversion of the timespec seconds to this format
>>> requires some shifts and masking. Conversion of 32-bit + 32-bit timespec
>>> to linear ns64 requires one 32*32->64 bit multiply and 64-bit addition.
>>> This has higher cost but on the modern CPUs it is not so big difference.
>>> It simplifies computation of differences, adding of relative time
>>> to actual time etc. It can be significant overhead for 16-architectures
>>> (bare h8, even h8s) and blocker for 8-bit ones (AVR). But they are
>>> not so common today.
>>> Conversion to timespec is significant problem.
>>> If the 34+30 bit compact timespec advantage of the faster conversion
>>> prevails for PER_CPU_WATCHDOG_ABSOLUTE then I would vote to change
>>> PER_CPU_WATCHDOG_RELATIVE to the same format.
>>> This simplifies clock_nanosleep logic and generally makes
>>> code more readable and lowers space for mistakes.
>>> If we consider 64-bit linear format then we should think about
>>> conversion to 64+32 bit timespec to overcome 2038 year problem.
>>> This makes multiplication 64*32->64 which is more complex.
>>> The most of the upper 32-bits would be discarded in ns64 format.
>>> But time wrap is around 2554, so no problem. For copacted
>>> timspec based format id 64-bit second field conversion easier,
>>> two LSB bits from upper 32-bit part are moved to MSB bits of
>>> compacted timespec.
>>> On the other hand, conversion of generic time source (which needs scaling)
>>> to the compacted timespec is disaster. So I think that linear
>>> 64-bit (ns64) format is better at the end.
>>> But discussion and counter examples are welcome.
>>> The cost of conversion from ns64 to timespec is high.
>>> May it be we can find some optimization but it is problem.
>>> So at this time I suggest ns64 only for timers which fire
>>> and user provided time, there is no requirement to read
>>> expire value back by user in common POSIX APIs (at least
>>> I hope).
>>>> Advantages of the ns64 is that conversion of user time formats
>>>> (timespec, timeval, etc) to 64-bit nanoseconds is relatively
>>>> efficient, and the internal time representations can be compared with
>>>> easy logic. The ns64 allows for higher precision event triggers than
>>>> score ticks. Furthermore, converting multiple time sources into ns64
>>>> is simpler to maintain consistent notion of time than score "ticks".
>>>> Thus, we anticipate the ns64 would make it easier to introduce
>>>> variable length ticks (a.k.a. tickless/no_hz) and to synchronize time
>>>> across SMP chips where each core has its own time source.
>>>> Some disadvantages are
>>>> 1) conversion back to user time is costly
>>>> 2) clock "tick" may add multiple nanoseconds to the ns64 counter
>>>> 3) no one has budget to implement it now :)
>>>> I wanted to stimulate some discussion about the topic to see if there
>>>> was any great objection to this kind of change, and what other inputs
>>>> others may have.
>>> Best wishes,
>>> Pavel
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
