I2C Driver testcase
punit vara punitvara at gmail.com
Mon Aug 1 06:37:29 UTC 2016
Thanks I am currently refering this one only :)
On Mon, Aug 1, 2016 at 10:14 AM, Sebastian Huber
> A good test device for an I2C bus driver is an EEPROM. See also
> https://git.rtems.org/rtems/tree/testsuites/libtests/i2c01/init.c#n414
> On 30/07/16 22:53, punit vara wrote:
>> Hi Sebastian !
>> You have suggested me following i2c drivers which follows /dev/i2c
>> framwork :
>> https://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/atsam/i2c/atsam_i2c_bus.c
>> https://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c
>> Can you please provide link to the test case application code for any
>> of above driver ?
>> Thanks,
>> Punit Vara
