[PATCH] doc: source-builder.txt: Update installtion for ubuntu packages
punit vara punitvara at gmail.com
Mon Aug 1 19:02:18 UTC 2016
Usually when Newbie run that command I think automake will be updated
to 1.5 latest version. Do you it should be removed from there or there
should be a note to use automake1.2 ???
On Tue, Aug 2, 2016 at 12:15 AM, Gedare Bloom <gedare at rtems.org> wrote:
> committed, thanks.
> On Thu, Jul 28, 2016 at 4:05 PM, Punit Vara <punitvara at gmail.com> wrote:
>>         This patch fixes the most common python missing error for RTEMS
>>         tool chain build and RSB built is tested for ubuntu 16.04.1 LTS
>>  doc/source-builder.txt | 5 +++--
>>  1 file changed, 3 insertions(+), 2 deletions(-)
>> diff --git a/doc/source-builder.txt b/doc/source-builder.txt
>> index 43bcf77..8b0cd89 100644
>> --- a/doc/source-builder.txt
>> +++ b/doc/source-builder.txt
>> @@ -3098,11 +3098,12 @@ home directory as recommended and end up on the SD card.
>>  Ubuntu
>> -The latest testing was with Ubuntu 13.10 64bit. This section also includes Xubuntu. A
>> +The latest testing was with Ubuntu 16.04.1 LTS 64bit. This section also includes Xubuntu. A
>>  minimal installation was used and the following packages installed.
>> -$ sudo apt-get build-dep binutils gcc g++ gdb unzip git python2.7-dev
>> +$ sudo apt-get build-dep binutils gcc g++ gdb unzip git
>> +$ sudo apt-get install python2.7-dev
>>  FreeBSD
>> 2.7.4
