[PATCH] posix: nanosleep: adjust elapsed time calculation
Mon Aug 1 20:59:53 UTC 2016
Use clock_gettime before and after sleep to calculate
the time spent asleep, and the amount of time remaining.
updates #2732
 cpukit/posix/src/nanosleep.c | 61 ++++++++++++++++++++++----------------------
 1 file changed, 31 insertions(+), 30 deletions(-)
diff --git a/cpukit/posix/src/nanosleep.c b/cpukit/posix/src/nanosleep.c
index 05d559a..2a95d84 100644
--- a/cpukit/posix/src/nanosleep.c
+++ b/cpukit/posix/src/nanosleep.c
@@ -33,21 +33,19 @@ static Thread_queue_Control _Nanosleep_Pseudo_queue =
   THREAD_QUEUE_INITIALIZER( "Nanosleep" );
 static inline int nanosleep_helper(
+  clockid_t             clock_id,
   uint64_t              ticks,
-  Watchdog_Interval     relative_interval,
+  struct timespec      *timeout,
   struct timespec      *rmtp,
   Watchdog_Discipline   discipline
   Thread_Control  *executing;
-  Watchdog_Interval  start;
-  Watchdog_Interval  elapsed;
+  struct timespec stop;
+  int err = 0;
   executing = _Thread_Get_executing();
-  start = _Watchdog_Ticks_since_boot;
    *  Block for the desired amount of time
@@ -61,21 +59,12 @@ static inline int nanosleep_helper(
     1
-   * Calculate the time that passed while we were sleeping and how
-   * much remains from what we requested.
-  elapsed = _Watchdog_Ticks_since_boot - start;
-  if ( elapsed >= relative_interval )
-    relative_interval = 0;
-  else
-    relative_interval -= elapsed;
+  clock_gettime( clock_id, &stop );
    * If the user wants the time remaining, do the conversion.
-  if ( rmtp ) {
-    _Timespec_From_ticks( relative_interval, rmtp );
+  if ( rmtp != NULL ) {
+    _Timespec_Subtract( &stop, &timeout, rmtp );
@@ -85,7 +74,7 @@ static inline int nanosleep_helper(
      *  If there is time remaining, then we were interrupted by a signal.
-    if ( relative_interval )
+    if ( _Timespec_Greater_than( &stop, &timeout) )
       return EINTR;
   #endif
@@ -152,7 +141,12 @@ int nanosleep(
     return -1;
   _Timespec_Add_to( &now, rqtp );
   ticks = _Watchdog_Ticks_from_timespec( &now );
-  err = nanosleep_helper(ticks, relative_interval, rmtp, WATCHDOG_ABSOLUTE );
+  err = nanosleep_helper( CLOCK_REALTIME,
+      ticks,
+      &now,
+      rmtp,
+      WATCHDOG_ABSOLUTE
   if ( err != 0 ) {
     rtems_set_errno_and_return_minus_one( err );
@@ -170,10 +164,9 @@ int clock_nanosleep(
   int err = 0;
-  struct timespec now;
+  struct timespec timeout;
   uint64_t ticks;
   Watchdog_Interval relative_interval;
-  struct timespec relative_ts;
   TOD_Absolute_timeout_conversion_results status;
   if ( !_Timespec_Is_valid( rqtp ) )
@@ -190,25 +183,33 @@ int clock_nanosleep(
     if ( status == TOD_ABSOLUTE_TIMEOUT_IS_NOW )
       return nanosleep_yield( NULL );
     rmtp = NULL; /* Do not touch rmtp when using absolute time */
+    timeout = 0;
   } else {
+    /* prepare to convert relative ticks to absolute timeout */
+    err = clock_gettime( clock_id, &timeout );
+    if ( err != 0 )
+      return EINVAL;
     relative_interval = _Timespec_To_ticks( rqtp );
   if ( relative_interval == 0 )
     return nanosleep_yield( rmtp );
+  _Timespec_Add_to( &timeout, rqtp );
   if ( clock_id == CLOCK_REALTIME ) {
-    /* convert relative ticks to absolute timeout */
-    err = clock_gettime( CLOCK_REALTIME, &now );
-    if ( err != 0 )
-      return EINVAL;
-    _Timespec_Add_to( &now, rqtp );
-    ticks = _Watchdog_Ticks_from_timespec( &now );
-    err = nanosleep_helper( ticks, relative_interval, rmtp, WATCHDOG_ABSOLUTE );
+    ticks = _Watchdog_Ticks_from_timespec( &timeout );
+        clock_id,
+        ticks,
+        &timeout,
+        rmtp,
+        WATCHDOG_ABSOLUTE
   } else if ( clock_id == CLOCK_MONOTONIC ) {
     /* use the WATCHDOG_RELATIVE to ignore changes in wall time */
+        clock_id,
         relative_interval,
-        relative_interval,
+        &timeout,
         rmtp,
         WATCHDOG_RELATIVE
1.9.1
