libbsd: How to add an option for switching off IPv6 (or other BSD Kernel configurations)
Tue Aug 2 02:09:41 UTC 2016
On 02/08/2016 00:04, Christian Mauderer wrote:
> Hello,
> we have a special use case where we want to use the new network stack
> but without the IPv6 support. I could need some advice how this could be
> integrated into the waf build system. If we find a good solution, this
> could also be an example for other BSD Kernel options.
> I found multiple places where IPv6 is enabled in libbsd:
> If I remove the INET6 option out of the FreeBSD kernel configuration on
> a FreeBSD system, this has the effect, that the "opt_inet6.h" is
> generated as an empty file instead of with a single define "#define
> INET6 1". In the rtems-libbsd the configuration header is located at
> rtemsbsd/include/rtems/bsd/local/opt_inet6.h. It has a fixed content
> with the define set. This would be the first place where the support
> would have to be disabled.
> Beneath that, some user space tools have a special option to enable IPv6
> which is currently set in libbsd.py. One such example is tcpdump with a
> compiler flag '-DINET6' set. As far as I could tell, the kernel and
> every application that is included in libbsd currently uses the INET6
> macro. But I think this is more of a convention than a general rule.
What about 'dhcpcd/ipv6.c' in the dhcpcd module? I think the problem may
be a little more complicated and you may need to control the code being
built based on the selected configuration.
> So I think we would roughly need the following:
> If i configure libbsd using
>     waf configure --disable-ipv6
I would prefer something like --config="networking:ipv6=no,..;" so a
general interface can be added. I doubt this will be the last option
that needs to be added. This avoids growing a long list of
enable/disable options being used to add features. It also allows us to
implement a generic framework we can use use in different areas where
this may also need to happen, eg --config="usb:...;".
If you consider the interface as a list of 'name=value' pairs it can be
mapped to the INI format file which Python can read via the
ConfigParser. This means:
  [networking]
  ipv6=no
  [udb]
In time we could allow reading of these setting from a user defined
configuration file, eg --config='file:myconfig.ini'.
> the build system would either have to regenerate opt_inet6.h or use an
> alternative version of it. Further I would need the ability to set
> compiler flags in libbsd.py depending on this configure option.
You could provide -DRTEMS_LIBBSD_INET6=1 and that would conditionally
control '#define INET6 1' in 'opt_inet6.h'. I would prefer something
static to generating files.
> Are there any better ideas how to implement such an option?
There are 2 parts that need be to changed to make this work. This
assumes you will need to control the source being built.
The first is the module descriptions in libbsd.py and then the
generator. I suggest you look at the various module class methods used
to add source and consider adding a 'section' argument which defaults to
'default' (always True). This would lets you move code into specific
sections, for example:
     dhcpcd_defines='-D__FreeBSD__ -DTHERE_IS_NO_FORK ...'
     mod.addSourceFiles(
             'dhcpcd/ipv6.c',
             'dhcpcd/ipv6nd.c',
         mm.generator['source'](dhcpcd_defines),
         section = 'networking.ipv6_yes'
Note, this definition generates something that is evaluated when waf
runs so the 'section' populates a dict where the 'networking.ipv6_yes'
key is tested for True or False depending what the user specifies.
You could also change the class constructor so you have:
  mod = builder.Module('dhcpcd', section = 'networking.dhcp')
The dot notation would allow control of the sources at the module level
to finally get sorted out. The dhcpcd module becomes 'networking.dhcpcd'
which means build if networking and dhcpcd are True. You could work down
the dots checking at each point to make sure the module can be built.
Currently module level user control has been left hanging with commented
modules, eg '#mm.addModule(dev_usb_controller_add_on(mm)'. If the
section 'usb.dev_usb_controller_add_on' is False by default that module
is not built which is what we have now.
The second part is in the waf script (wscript) which handles the user
interface, ie parses
--config="networking:ipv6=no,pink-frames-only,chrismac-buf-frames=64". I
would add this code in a new Python module libbsd_opts.py and imported
into libbsd_waf.py (generated) and called in the 'options' function in
libbsd_waf.py. This would parse and populate a dict the generated module
code uses.
> I'm quite inexperienced on how to use waf, so I would need some guidance
> how this could be implemented. Are there any hints how I could start
> implementing such an option? Some examples or similar code?
There is nothing similar as the core of the functionality is in
freebsd-to-rtems.py and related code which has been an on going
development. Conditionally adding source can be seen in the generated
waf script where archs are being tested.
I hope this helps.
