Integration of libcoap into RTEMS-libbsd
Babacar Diop
bdiopxv at gmail.com
Tue Aug 2 15:53:08 UTC 2016
Dear Gedare,
Thank you for response. I forgot to precise that I have the networking
capabilities on my beaglebone black thanks to Ragunath's work.
Ok so basically, I thought about using the RSB to add the library into
RTEMS as a static library as it might help me to automatize
the work. Is it really necessary to build my own script or does the curernt
RSB can do the work with my custom configuration ?
Kind Regards
2016-08-02 16:38 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> On Tue, Aug 2, 2016 at 11:05 AM, Babacar Diop <bdiopxv at gmail.com> wrote:
> > Dear users,
> > I would like to know if it is possible to integrate the POSIX/C CoAP
> > implementation libcoap into RTEMS-libbsd.
> Should be possible to link it with an RTEMS built with libbsd using
> the POSIX interfaces in CoAP.
> > Do you think it is possible for now ? Do you have an idea on how to do
> this
> First you would need to build/install RTEMS with a networking stack
> and test that you have networking capabilities working out-of-the-box.
> Then you would have to figure out how to make the build system for
> CoAP compile and link against your built RTEMS, or write your own
> build scripts. Oh, and you should build it as a static library. Then
> it should be possible to compile/link an example using the installed
> RTEMS and linking to the static coap library.
> > Any help could be great !
> > Kind Regards
> > Babacar Diop
> > 24 years
> > Engineering student in Electronics and Computer Sciences of Embedded
> Systems
> > at Polytech' Paris-UPMC
> > 5th Year
> > devel mailing list
> > devel at rtems.org
Babacar Diop
23 ans
Élève ingénieur à Polytech' Paris-UPMC
Section Électronique, Informatique des Systèmes Embarqués
Année 5
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160802/118dfc58/attachment.html>
