[PATCH] score: Indroduce cancel job scheduler operation
Wed Aug 3 13:43:36 UTC 2016
Do not use a deadline value of zero to indicate a job cancellation.  Use
a dedicated scheduler operation for this.
 cpukit/rtems/src/ratemoncancel.c                   |  2 +-
 cpukit/score/include/rtems/score/scheduler.h       | 17 ++++++++
 cpukit/score/include/rtems/score/schedulercbs.h    |  1 +
 cpukit/score/include/rtems/score/scheduleredf.h    |  8 +++-
 cpukit/score/include/rtems/score/schedulerimpl.h   | 14 +++++++
 .../score/include/rtems/score/schedulerpriority.h  |  1 +
 .../rtems/score/schedulerpriorityaffinitysmp.h     |  1 +
 .../include/rtems/score/schedulerprioritysmp.h     |  1 +
 cpukit/score/include/rtems/score/schedulersimple.h |  1 +
 .../score/include/rtems/score/schedulersimplesmp.h |  1 +
 .../score/include/rtems/score/schedulerstrongapa.h |  1 +
 cpukit/score/src/schedulerdefaultreleasejob.c      |  9 +++++
 cpukit/score/src/scheduleredfreleasejob.c          | 46 ++++++++++++++++++----
 13 files changed, 94 insertions(+), 9 deletions(-)
diff --git a/cpukit/rtems/src/ratemoncancel.c b/cpukit/rtems/src/ratemoncancel.c
index af6b1ec..41ba488 100644
--- a/cpukit/rtems/src/ratemoncancel.c
+++ b/cpukit/rtems/src/ratemoncancel.c
@@ -38,7 +38,7 @@ void _Rate_monotonic_Cancel(
   cpu_self = _Thread_Dispatch_disable_critical( lock_context );
   _Rate_monotonic_Release( owner, lock_context );
-  _Scheduler_Release_job( owner, 0 );
+  _Scheduler_Cancel_job( owner );
   _Thread_Dispatch_enable( cpu_self );
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index c20e68c..20615a2 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -141,6 +141,12 @@ typedef struct {
     uint64_t
+  /** @see _Scheduler_Cancel_job() */
+  void ( *cancel_job ) (
+    const Scheduler_Control *,
+    Thread_Control *
   /** @see _Scheduler_Tick() */
   void ( *tick )( const Scheduler_Control *, Thread_Control * );
@@ -376,6 +382,17 @@ void _Scheduler_default_Release_job(
+ * @brief Does nothing.
+ * @param[in] scheduler Unused.
+ * @param[in] the_thread Unused.
+void _Scheduler_default_Cancel_job(
+  const Scheduler_Control *scheduler,
+  Thread_Control          *the_thread
  * @brief Performs tick operations depending on the CPU budget algorithm for
  * each executing thread.
diff --git a/cpukit/score/include/rtems/score/schedulercbs.h b/cpukit/score/include/rtems/score/schedulercbs.h
index a46314c..bfad633 100644
--- a/cpukit/score/include/rtems/score/schedulercbs.h
+++ b/cpukit/score/include/rtems/score/schedulercbs.h
@@ -61,6 +61,7 @@ extern "C" {
     _Scheduler_CBS_Node_initialize,  /* node initialize entry point */ \
     _Scheduler_default_Node_destroy, /* node destroy entry point */ \
     _Scheduler_CBS_Release_job,      /* new period of task */ \
+    _Scheduler_EDF_Cancel_job,       /* cancel period of task */ \
     _Scheduler_default_Tick,         /* tick entry point */ \
     _Scheduler_default_Start_idle    /* start idle entry point */ \
     SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
index de06344..5d9b435 100644
--- a/cpukit/score/include/rtems/score/scheduleredf.h
+++ b/cpukit/score/include/rtems/score/scheduleredf.h
     _Scheduler_EDF_Node_initialize,  /* node initialize entry point */ \
     _Scheduler_EDF_Release_job,      /* new period of task */ \
@@ -227,12 +228,17 @@ Scheduler_Void_or_thread _Scheduler_EDF_Yield(
  *             the job was cancelled or deleted, thus a running task
  *             has to be suspended.
-void _Scheduler_EDF_Release_job (
+void _Scheduler_EDF_Release_job(
   Thread_Control          *the_thread,
   uint64_t                 deadline
+void _Scheduler_EDF_Cancel_job(
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index dd7fa28..23b73f0 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -499,6 +499,20 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Release_job(
+ * @brief Cancels a job of a thread with respect to the scheduler.
+ * @param[in] the_thread The thread.
+RTEMS_INLINE_ROUTINE void _Scheduler_Cancel_job(
+  const Scheduler_Control *scheduler = _Scheduler_Get( the_thread );
+  ( *scheduler->Operations.cancel_job )( scheduler, the_thread );
  * @brief Scheduler method invoked at each clock tick.
  * This method is invoked at each clock tick to allow the scheduler
diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
index 9501e3d..f3e805a 100644
--- a/cpukit/score/include/rtems/score/schedulerpriority.h
+++ b/cpukit/score/include/rtems/score/schedulerpriority.h
@@ -51,6 +51,7 @@ extern "C" {
     _Scheduler_priority_Node_initialize,  /* node initialize entry point */ \
     _Scheduler_default_Release_job,       /* new period of task */ \
+    _Scheduler_default_Cancel_job,        /* cancel period of task */ \
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
index 763523a..317411a 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
     _Scheduler_priority_affinity_SMP_Node_initialize, \
     _Scheduler_default_Node_destroy, \
     _Scheduler_default_Release_job, \
+    _Scheduler_default_Cancel_job, \
     _Scheduler_default_Tick, \
     _Scheduler_SMP_Start_idle, \
     _Scheduler_priority_affinity_SMP_Get_affinity, \
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
index 97370ac..6ae933f 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
@@ -90,6 +90,7 @@ typedef struct {
     _Scheduler_priority_SMP_Node_initialize, \
     _Scheduler_SMP_Start_idle \
diff --git a/cpukit/score/include/rtems/score/schedulersimple.h b/cpukit/score/include/rtems/score/schedulersimple.h
index 3fa4b33..2239379 100644
--- a/cpukit/score/include/rtems/score/schedulersimple.h
+++ b/cpukit/score/include/rtems/score/schedulersimple.h
     _Scheduler_default_Node_initialize,   /* node initialize entry point */ \
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index bbcdbdb..95176dc 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -73,6 +73,7 @@ typedef struct {
     _Scheduler_simple_SMP_Node_initialize, \
diff --git a/cpukit/score/include/rtems/score/schedulerstrongapa.h b/cpukit/score/include/rtems/score/schedulerstrongapa.h
index 8390c2d..2cc9183 100644
--- a/cpukit/score/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/score/include/rtems/score/schedulerstrongapa.h
     _Scheduler_strong_APA_Node_initialize, \
diff --git a/cpukit/score/src/schedulerdefaultreleasejob.c b/cpukit/score/src/schedulerdefaultreleasejob.c
index db4ab0e..439f6b2 100644
--- a/cpukit/score/src/schedulerdefaultreleasejob.c
+++ b/cpukit/score/src/schedulerdefaultreleasejob.c
@@ -31,3 +31,12 @@ void _Scheduler_default_Release_job(
   (void) the_thread;
   (void) deadline;
+  (void) scheduler;
+  (void) the_thread;
diff --git a/cpukit/score/src/scheduleredfreleasejob.c b/cpukit/score/src/scheduleredfreleasejob.c
index 76c08e0..f2ee75b 100644
--- a/cpukit/score/src/scheduleredfreleasejob.c
+++ b/cpukit/score/src/scheduleredfreleasejob.c
@@ -20,7 +20,7 @@
-static bool _Scheduler_EDF_Priority_filter(
+static bool _Scheduler_EDF_Release_job_filter(
   Priority_Control *new_priority_p,
   void             *arg
@@ -35,10 +35,6 @@ static bool _Scheduler_EDF_Priority_filter(
   current_priority = _Thread_Get_priority( the_thread );
   new_priority = *new_priority_p;
-  if ( new_priority == 0 ) {
-    new_priority = node->background_priority;
   node->current_priority = new_priority;
   the_thread->real_priority = new_priority;
@@ -54,9 +50,45 @@ void _Scheduler_EDF_Release_job(
   _Thread_Change_priority(
     the_thread,
-    (Priority_Control) deadline,
+    deadline,
+    NULL,
+    _Scheduler_EDF_Release_job_filter,
+    true
+static bool _Scheduler_EDF_Cancel_job_filter(
+  Thread_Control   *the_thread,
+  Priority_Control *new_priority_p,
+  void             *arg
+  Scheduler_EDF_Node *node;
+  Priority_Control    current_priority;
+  Priority_Control    new_priority;
+  node = _Scheduler_EDF_Thread_get_node( the_thread );
+  current_priority = _Thread_Get_priority( the_thread );
+  new_priority = node->background_priority;
+  node->current_priority = new_priority;
+  the_thread->real_priority = new_priority;
+  return _Thread_Priority_less_than( current_priority, new_priority )
+    || !_Thread_Owns_resources( the_thread );
+  _Thread_Change_priority(
+    the_thread,
+    0,
     NULL,
-    _Scheduler_EDF_Priority_filter,
+    _Scheduler_EDF_Cancel_job_filter,
     true
1.8.4.5
