[PATCH] classic networking: do not reference
Pavel Pisa ppisa4lists at pikron.com
Thu Aug 4 22:27:28 UTC 2016
Hello Joel,
On Thursday 04 of August 2016 23:53:16 Joel Sherrill wrote:
> This sounds and looks reasonable.
If you think, that it is OK, I can push that tomorrow
morning. I am not sure if isOn is really not used now/can be NULL.
Other option is to define these functions as NoOp
and return one (or zero?) always.
Have you some opinion there?
I have tried to test integrated networking to help
Saeed with dlopen and networking. I have tested
x86 as sidestep but I have not been too much sucesfull.
For
static struct rtems_bsdnet_ifconfig netdriver_config = {
	.name = (char *)BSP_NE2000_NETWORK_DRIVER_NAME,
	.attach = BSP_NE2000_NETWORK_DRIVER_ATTACH,
	.next = NULL,
	.ip_address = "192.168.3.66",
	.ip_netmask = "255.255.255.0",
	.hardware_address = ethernet_address,
	.ignore_broadcast = 0,
	.mtu = 0,
	.rbuf_count = 0,
	.xbuf_count = 0,
	.port = 0x300,
	.irno = 9,
	.bpar = 0,
	.drv_ctrl = NULL
struct rtems_bsdnet_config rtems_bsdnet_config = {
	.ifconfig = &netdriver_config,
/*	.bootp = rtems_bsdnet_do_bootp,*/
/*	.bootp = rtems_bsdnet_do_dhcp,*/
	.bootp = rtems_bsdnet_do_dhcp_failsafe,
	.network_task_priority = 0,		/* 100        */
	.mbuf_bytecount = 256 * 1024,		/* 64 kbytes  */
	.mbuf_cluster_bytecount = 256 * 1024,	/* 128 kbytes */
	.hostname = NULL,
	.domainname = NULL,
	.gateway = "192.168.3.1",
	.log_host = NULL,
	.name_server = { "NULL" },
	.ntp_server = { "NULL" },
	.sb_efficiency = 0,
	.udp_tx_buf_size = 0,			/* UDP TX: 9216 bytes */
	.udp_rx_buf_size = 0,			/* UDP RX: 40 * (1024 + sizeof(struct sockaddr_in)) */
	.tcp_tx_buf_size = 0,			/* TCP TX: 16 * 1024 bytes */
	.tcp_rx_buf_size = 0,			/* TCP TX: 16 * 1024 bytes */
and
qemu-system-x86_64 -enable-kvm -kernel $APP_BINARY \
      -vga cirrus \
      -net nic,vlan=0,macaddr=00:80:7F:22:61:77,model=ne2k_isa -net user,vlan=0 \
      -append "--console=/dev/com1" \
      -serial stdio \
I get address from internal QEMU DHCP server but TFTP does not
seem to work even that I use same QEMU setup with user (internal
UDP/TCP only) NAT successfully for other systems.
I would like to switch to PCI, so I have tested
int rtems_fxp_attach(struct rtems_bsdnet_ifconfig *config, int attaching);
	.name = "fxp1",
	.attach = rtems_fxp_attach,
      -vga cirrus \
      -net nic,vlan=0,model=i82557b -net user,vlan=0 \
      -serial stdio \
which finds card on PCI but the it does not work.
Is it possible that interrupts are not correctly
routed, registered?
Can be IRQ number obtained from
 bus_alloc_resource(dev, SYS_RES_IRQ, &rid, 0, ~0, 1,
		    RF_SHAREABLE | RF_ACTIVE);
used directly in
  BSP_install_rtems_irq_handler
or
  rtems_interrupt_handler_install
or some mapping is required?
Has nomebody tested some of these PCI drivers with QEMU?
Best wishes,
               Pavel
> The old stack needs to be moved into its own build tree.
> On Aug 4, 2016 5:43 PM, "Pavel Pisa" <ppisa4lists at pikron.com> wrote:
> > This change is required to build RTEMS with classic "--enable-networking"
> > and link applications/tests which reference RTEMS_BSP_NETWORK_DRIVER_
> > ATTACH.
> >  c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c | 10 +---------
> >  c/src/libchip/network/dec21140.c            |  7 +------
> >  c/src/libchip/network/elnk.c                | 12 +-----------
> >  c/src/libchip/network/if_dc.c               |  9 +--------
> >  c/src/libchip/network/if_fxp.c              |  7 +------
> >  5 files changed, 5 insertions(+), 40 deletions(-)
> >  Discussion: I have stumbled over problem to build some external tests
> >  for i386 because original integrated Ethernet drivers cannot be linked
> >  into application. Even that libbsd is a future goal it worth to correct
> >  this at least for testing. It seems that original i8259s concept
> >  handling is finally overcome by generic approach.
> >  I hope that field isOn is no longer referenced by any architecture
> >  or if referenced, that NULL is valid option.
> >  I am leaving for next week so I would not push this change probably.
> >  In the longer perspective, I think that even for these deprecated
> > drivers rtems_interrupt_handler_install generic concept could/should be
> > used. If it is agreed that it is right change then I can prepare patch
> > for that in future.
> >  But I think that correction of the builds in meantime worth
> >  to be pushed.
> > diff --git a/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> > b/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> > index 5a13b29..d757e27 100644
> > --- a/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> > +++ b/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> > @@ -428,14 +428,6 @@ ne_interrupt_off (const rtems_irq_connect_data *irq)
> >      outport_byte (sc->port + IMR, 0);
> > -/* Return whether NE2000 interrupts are on.  */
> > -static int
> > -ne_interrupt_is_on (const rtems_irq_connect_data *irq)
> > -  return BSP_irq_enabled_at_i8259s (irq->name);
> >  /* Initialize the NE2000 hardware.  */
> >  static void
> > @@ -526,7 +518,7 @@ ne_init_irq_handler(int irno)
> >    irq.handle = (rtems_irq_hdl) irno;
> >    irq.on = ne_interrupt_on;
> >    irq.off = ne_interrupt_off;
> > -  irq.isOn = ne_interrupt_is_on;
> > +  irq.isOn = NULL;
> >    if (!BSP_install_rtems_irq_handler (&irq))
> >      rtems_panic ("Can't attach NE interrupt handler for irq %d\n",
> > irno); diff --git a/c/src/libchip/network/dec21140.c
> > b/c/src/libchip/network/ dec21140.c
> > index aa6be29..3bfc91d 100644
> > --- a/c/src/libchip/network/dec21140.c
> > +++ b/c/src/libchip/network/dec21140.c
> > @@ -345,11 +345,6 @@ static void no_op(const rtems_irq_connect_data* irq)
> >     return;
> > -static int dec21140IsOn(const rtems_irq_connect_data* irq)
> >   * DEC21140 interrupt handler
> > @@ -539,7 +534,7 @@ dec21140Enet_initialize_hardware (struct
> > dec21140_softc *sc)
> >     sc->irqInfo.hdl  = (rtems_irq_hdl)dec21140Enet_
> > interrupt_handler_entry;
> >     sc->irqInfo.on   = no_op;
> >     sc->irqInfo.off  = no_op;
> > -   sc->irqInfo.isOn = dec21140IsOn;
> > +   sc->irqInfo.isOn = NULL;
> >  #ifdef DEC_DEBUG
> >     printk( "dec2114x: Installing IRQ %d\n", sc->irqInfo.name );
> > diff --git a/c/src/libchip/network/elnk.c b/c/src/libchip/network/elnk.c
> > index 06ece5b..1c63e35 100644
> > --- a/c/src/libchip/network/elnk.c
> > +++ b/c/src/libchip/network/elnk.c
> > @@ -1875,16 +1875,6 @@ static void no_op(const rtems_irq_connect_data*
> > irq)
> > -static int elnkIsOn(const rtems_irq_connect_data* irq)
> >  static void
> >  elnk_start_txchain( struct elnk_softc *sc, struct TXMD *chainhead )
> > @@ -2214,7 +2204,7 @@ elnk_initialize_hardware (struct elnk_softc *sc)
> >     sc->irqInfo.hdl  = (rtems_irq_hdl)elnk_interrupt_handler_entry;
> > -   sc->irqInfo.isOn = elnkIsOn;
> >     if( sc->irqInfo.name != 255 )
> > diff --git a/c/src/libchip/network/if_dc.c
> > b/c/src/libchip/network/if_dc.c index 1563be5..24f2fc1 100644
> > --- a/c/src/libchip/network/if_dc.c
> > +++ b/c/src/libchip/network/if_dc.c
> > @@ -1893,13 +1893,6 @@ nop(const rtems_irq_connect_data* unused)
> > -static int
> > -decISON(const rtems_irq_connect_data* irq)
> > -       return (BSP_irq_enabled_at_i8259s(irq->name));
> >   * Attach the interface. Allocate softc structures, do ifmedia
> >   * setup and ethernet/BPF attach.
> > @@ -2023,7 +2016,7 @@ rtems_dc_driver_attach(struct rtems_bsdnet_ifconfig
> >         sc->irqInfo.handle = (void *)sc; /* new parameter */
> >         sc->irqInfo.on = nop;
> >         sc->irqInfo.off = nop;
> > -       sc->irqInfo.isOn = decISON;
> >  #ifdef BSP_SHARED_HANDLER_SUPPORT
> >         rc = BSP_install_rtems_shared_irq_handler( &sc->irqInfo );
> > diff --git a/c/src/libchip/network/if_fxp.c b/c/src/libchip/network/if_
> > fxp.c
> > index ce59db1..35d7c07 100644
> > --- a/c/src/libchip/network/if_fxp.c
> > +++ b/c/src/libchip/network/if_fxp.c
> > @@ -431,11 +431,6 @@ static void nopOn(const rtems_irq_connect_data*
> > notUsed)
> > -static int fxpIsOn(const rtems_irq_connect_data* irq)
> >  int
> > @@ -1933,7 +1928,7 @@ rtems_task_wake_after(100);
> >                 sc->irqInfo.hdl = (rtems_irq_hdl)fxp_intr;
> >                 sc->irqInfo.on  = nopOn;
> >                 sc->irqInfo.off = nopOn;
> > -               sc->irqInfo.isOn = fxpIsOn;
> >                 rv = BSP_install_rtems_irq_handler (&sc->irqInfo);
> >                 if (rv != 1) {
> >                   rtems_panic ("Can't attach fxp interrupt handler for
> > irq %d\n",
> > 1.9.1
> > devel mailing list
> > devel at rtems.org
