[PATCH] classic networking: do not reference
Joel Sherrill
joel at rtems.org
Fri Aug 5 01:00:33 UTC 2016
On Aug 4, 2016 6:27 PM, "Pavel Pisa" <ppisa4lists at pikron.com> wrote:
> Hello Joel,
> On Thursday 04 of August 2016 23:53:16 Joel Sherrill wrote:
> > This sounds and looks reasonable.
> If you think, that it is OK, I can push that tomorrow
> morning. I am not sure if isOn is really not used now/can be NULL.
> Other option is to define these functions as NoOp
> and return one (or zero?) always.
> Have you some opinion there?
I have no idea honestly but it needs to move to the newer interrupt model
so when we finally get APIC support, there isn't a larger change set.
Fwiw I would expect that the old stack is still testable with the old Intel
NIC driver and qemu for PC but the stack needs newer drivers for any
modern NIC.
> I have tried to test integrated networking to help
> Saeed with dlopen and networking. I have tested
> x86 as sidestep but I have not been too much sucesfull.
> For
> static struct rtems_bsdnet_ifconfig netdriver_config = {
> .name = (char *)BSP_NE2000_NETWORK_DRIVER_NAME,
> .attach = BSP_NE2000_NETWORK_DRIVER_ATTACH,
> .next = NULL,
> .ip_address = "192.168.3.66",
> .ip_netmask = "255.255.255.0",
> .hardware_address = ethernet_address,
> .ignore_broadcast = 0,
> .mtu = 0,
> .rbuf_count = 0,
> .xbuf_count = 0,
> .port = 0x300,
> .irno = 9,
> .bpar = 0,
> .drv_ctrl = NULL
> struct rtems_bsdnet_config rtems_bsdnet_config = {
> .ifconfig = &netdriver_config,
> /* .bootp = rtems_bsdnet_do_bootp,*/
> /* .bootp = rtems_bsdnet_do_dhcp,*/
> .bootp = rtems_bsdnet_do_dhcp_failsafe,
> .network_task_priority = 0, /* 100 */
> .mbuf_bytecount = 256 * 1024, /* 64 kbytes */
> .mbuf_cluster_bytecount = 256 * 1024, /* 128 kbytes */
> .hostname = NULL,
> .domainname = NULL,
> .gateway = "192.168.3.1",
> .log_host = NULL,
> .name_server = { "NULL" },
> .ntp_server = { "NULL" },
> .sb_efficiency = 0,
> .udp_tx_buf_size = 0, /* UDP TX: 9216 bytes */
> .udp_rx_buf_size = 0, /* UDP RX: 40 * (1024 +
sizeof(struct sockaddr_in)) */
> .tcp_tx_buf_size = 0, /* TCP TX: 16 * 1024
bytes */
> .tcp_rx_buf_size = 0, /* TCP TX: 16 * 1024
bytes */
> and
> qemu-system-x86_64 -enable-kvm -kernel $APP_BINARY \
> -vga cirrus \
> -net nic,vlan=0,macaddr=00:80:7F:22:61:77,model=ne2k_isa -net
user,vlan=0 \
> -append "--console=/dev/com1" \
> -serial stdio \
> I get address from internal QEMU DHCP server but TFTP does not
> seem to work even that I use same QEMU setup with user (internal
> UDP/TCP only) NAT successfully for other systems.
> I would like to switch to PCI, so I have tested
> int rtems_fxp_attach(struct rtems_bsdnet_ifconfig *config, int attaching);
> .name = "fxp1",
> .attach = rtems_fxp_attach,
> -vga cirrus \
> -net nic,vlan=0,model=i82557b -net user,vlan=0 \
> -serial stdio \
> which finds card on PCI but the it does not work.
> Is it possible that interrupts are not correctly
> routed, registered?
> Can be IRQ number obtained from
> bus_alloc_resource(dev, SYS_RES_IRQ, &rid, 0, ~0, 1,
> RF_SHAREABLE | RF_ACTIVE);
> used directly in
> BSP_install_rtems_irq_handler
> or
> rtems_interrupt_handler_install
> or some mapping is required?
> Has nomebody tested some of these PCI drivers with QEMU?
> Best wishes,
> Pavel
> > The old stack needs to be moved into its own build tree.
> > On Aug 4, 2016 5:43 PM, "Pavel Pisa" <ppisa4lists at pikron.com> wrote:
> > > This change is required to build RTEMS with classic
"--enable-networking"
> > > and link applications/tests which reference RTEMS_BSP_NETWORK_DRIVER_
> > > ATTACH.
> > > c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c | 10 +---------
> > > c/src/libchip/network/dec21140.c | 7 +------
> > > c/src/libchip/network/elnk.c | 12 +-----------
> > > c/src/libchip/network/if_dc.c | 9 +--------
> > > c/src/libchip/network/if_fxp.c | 7 +------
> > > 5 files changed, 5 insertions(+), 40 deletions(-)
> > > Discussion: I have stumbled over problem to build some external tests
> > > for i386 because original integrated Ethernet drivers cannot be
linked
> > > into application. Even that libbsd is a future goal it worth to
correct
> > > this at least for testing. It seems that original i8259s concept
> > > handling is finally overcome by generic approach.
> > > I hope that field isOn is no longer referenced by any architecture
> > > or if referenced, that NULL is valid option.
> > > I am leaving for next week so I would not push this change probably.
> > > In the longer perspective, I think that even for these deprecated
> > > drivers rtems_interrupt_handler_install generic concept could/should
be
> > > used. If it is agreed that it is right change then I can prepare patch
> > > for that in future.
> > > But I think that correction of the builds in meantime worth
> > > to be pushed.
> > > diff --git a/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> > > b/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> > > index 5a13b29..d757e27 100644
> > > --- a/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> > > +++ b/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> > > @@ -428,14 +428,6 @@ ne_interrupt_off (const rtems_irq_connect_data
*irq)
> > > outport_byte (sc->port + IMR, 0);
> > > -/* Return whether NE2000 interrupts are on. */
> > > -static int
> > > -ne_interrupt_is_on (const rtems_irq_connect_data *irq)
> > > - return BSP_irq_enabled_at_i8259s (irq->name);
> > > /* Initialize the NE2000 hardware. */
> > > static void
> > > @@ -526,7 +518,7 @@ ne_init_irq_handler(int irno)
> > > irq.handle = (rtems_irq_hdl) irno;
> > > irq.on = ne_interrupt_on;
> > > irq.off = ne_interrupt_off;
> > > - irq.isOn = ne_interrupt_is_on;
> > > + irq.isOn = NULL;
> > > if (!BSP_install_rtems_irq_handler (&irq))
> > > rtems_panic ("Can't attach NE interrupt handler for irq %d\n",
> > > irno); diff --git a/c/src/libchip/network/dec21140.c
> > > b/c/src/libchip/network/ dec21140.c
> > > index aa6be29..3bfc91d 100644
> > > --- a/c/src/libchip/network/dec21140.c
> > > +++ b/c/src/libchip/network/dec21140.c
> > > @@ -345,11 +345,6 @@ static void no_op(const rtems_irq_connect_data*
irq)
> > > return;
> > > -static int dec21140IsOn(const rtems_irq_connect_data* irq)
> > > * DEC21140 interrupt handler
> > > @@ -539,7 +534,7 @@ dec21140Enet_initialize_hardware (struct
> > > dec21140_softc *sc)
> > > sc->irqInfo.hdl = (rtems_irq_hdl)dec21140Enet_
> > > interrupt_handler_entry;
> > > sc->irqInfo.on = no_op;
> > > sc->irqInfo.off = no_op;
> > > - sc->irqInfo.isOn = dec21140IsOn;
> > > + sc->irqInfo.isOn = NULL;
> > > #ifdef DEC_DEBUG
> > > printk( "dec2114x: Installing IRQ %d\n", sc->irqInfo.name );
> > > diff --git a/c/src/libchip/network/elnk.c
b/c/src/libchip/network/elnk.c
> > > index 06ece5b..1c63e35 100644
> > > --- a/c/src/libchip/network/elnk.c
> > > +++ b/c/src/libchip/network/elnk.c
> > > @@ -1875,16 +1875,6 @@ static void no_op(const rtems_irq_connect_data*
> > > irq)
> > > -static int elnkIsOn(const rtems_irq_connect_data* irq)
> > > static void
> > > elnk_start_txchain( struct elnk_softc *sc, struct TXMD *chainhead )
> > > @@ -2214,7 +2204,7 @@ elnk_initialize_hardware (struct elnk_softc *sc)
> > > sc->irqInfo.hdl = (rtems_irq_hdl)elnk_interrupt_handler_entry;
> > > - sc->irqInfo.isOn = elnkIsOn;
> > > if( sc->irqInfo.name != 255 )
> > > diff --git a/c/src/libchip/network/if_dc.c
> > > b/c/src/libchip/network/if_dc.c index 1563be5..24f2fc1 100644
> > > --- a/c/src/libchip/network/if_dc.c
> > > +++ b/c/src/libchip/network/if_dc.c
> > > @@ -1893,13 +1893,6 @@ nop(const rtems_irq_connect_data* unused)
> > > -static int
> > > -decISON(const rtems_irq_connect_data* irq)
> > > - return (BSP_irq_enabled_at_i8259s(irq->name));
> > > * Attach the interface. Allocate softc structures, do ifmedia
> > > * setup and ethernet/BPF attach.
> > > @@ -2023,7 +2016,7 @@ rtems_dc_driver_attach(struct
> > > sc->irqInfo.handle = (void *)sc; /* new parameter */
> > > sc->irqInfo.on = nop;
> > > sc->irqInfo.off = nop;
> > > - sc->irqInfo.isOn = decISON;
> > > #ifdef BSP_SHARED_HANDLER_SUPPORT
> > > rc = BSP_install_rtems_shared_irq_handler( &sc->irqInfo );
> > > diff --git a/c/src/libchip/network/if_fxp.c
> > > fxp.c
> > > index ce59db1..35d7c07 100644
> > > --- a/c/src/libchip/network/if_fxp.c
> > > +++ b/c/src/libchip/network/if_fxp.c
> > > @@ -431,11 +431,6 @@ static void nopOn(const rtems_irq_connect_data*
> > > notUsed)
> > > -static int fxpIsOn(const rtems_irq_connect_data* irq)
> > > int
> > > @@ -1933,7 +1928,7 @@ rtems_task_wake_after(100);
> > > sc->irqInfo.hdl = (rtems_irq_hdl)fxp_intr;
> > > sc->irqInfo.on = nopOn;
> > > sc->irqInfo.off = nopOn;
> > > - sc->irqInfo.isOn = fxpIsOn;
> > > rv = BSP_install_rtems_irq_handler (&sc->irqInfo);
> > > if (rv != 1) {
> > > rtems_panic ("Can't attach fxp interrupt handler for
> > > irq %d\n",
> > > 1.9.1
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160804/e4deccb8/attachment-0001.html>
