[PATCH 2/5] testsuite/pf01: Remove pflog-module from test.
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Aug 8 14:32:57 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
This module is not tested inside the pf01 test. Therefore remove it. It
is still build in the interactive pf02 test.
 testsuite/pf01/test_main.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/testsuite/pf01/test_main.c b/testsuite/pf01/test_main.c
index 6d9f563..4f70316 100644
--- a/testsuite/pf01/test_main.c
+++ b/testsuite/pf01/test_main.c
@@ -492,6 +492,5 @@ test_main(void)
 #include <machine/rtems-bsd-sysinit.h>
 #define RTEMS_BSD_CONFIG_FIREWALL_PF
-#define RTEMS_BSD_CONFIG_FIREWALL_PFLOG
 #include <rtems/bsd/test/default-network-init.h>
2.9.2
