[PATCH 4/5] pf: Improve documentation regarding stack.
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Aug 8 14:32:59 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 libbsd.txt | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/libbsd.txt b/libbsd.txt
index 60a1b55..5d8c174 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -1347,8 +1347,10 @@ The following is necessary to use PF on RTEMS:
 - Create a rule file (normally +/etc/pf.conf+). See the FreeBSD manual for the
   syntax.
-- Load the rule file using the pfctl command and enable pf. An example
-  initialisation can look like follows:
+- Load the rule file using the pfctl command and enable pf. Please note that the
+  pfctl command needs a lot of stack. You should use at least
+  RTEMS_MINIMUM_STACK_SIZE + 8192 Bytes of stack. An example initialisation can
+  look like follows:
 	int exit_code;
2.9.2
