[PATCH 5/5] pf: Add configuration via rc.conf.
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Aug 8 14:33:00 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 libbsd.py                                          |   1 +
 libbsd_waf.py                                      |   1 +
 rtemsbsd/include/machine/rtems-bsd-config.h        |   4 +
 .../include/machine/rtems-bsd-rc-conf-services.h   |   1 +
 rtemsbsd/rtems/rtems-bsd-rc-conf-pf.c              | 261 +++++++++++++++++++++
 testsuite/rcconf02/test_main.c                     |  43 +++-
 6 files changed, 310 insertions(+), 1 deletion(-)
 create mode 100644 rtemsbsd/rtems/rtems-bsd-rc-conf-pf.c
diff --git a/libbsd.py b/libbsd.py
index d466ac6..73f5a67 100755
--- a/libbsd.py
+++ b/libbsd.py
@@ -65,6 +65,7 @@ def rtems(mm):
             'rtems/rtems-bsd-get-task-priority.c',
             'rtems/rtems-bsd-get-task-stack-size.c',
             'rtems/rtems-bsd-rc-conf-net.c',
+            'rtems/rtems-bsd-rc-conf-pf.c',
             'rtems/rtems-bsd-rc-conf.c',
             'rtems/rtems-bsd-shell.c',
             'rtems/rtems-bsd-shell-netcmds.c',
diff --git a/libbsd_waf.py b/libbsd_waf.py
index 5ae6ae1..524b8bc 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -1079,6 +1079,7 @@ def build(bld):
               'rtemsbsd/rtems/rtems-bsd-get-task-priority.c',
               'rtemsbsd/rtems/rtems-bsd-get-task-stack-size.c',
               'rtemsbsd/rtems/rtems-bsd-rc-conf-net.c',
+              'rtemsbsd/rtems/rtems-bsd-rc-conf-pf.c',
               'rtemsbsd/rtems/rtems-bsd-rc-conf.c',
               'rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c',
               'rtemsbsd/rtems/rtems-bsd-shell-netcmds.c',
diff --git a/rtemsbsd/include/machine/rtems-bsd-config.h b/rtemsbsd/include/machine/rtems-bsd-config.h
index 84562bf..ed2a97e 100644
--- a/rtemsbsd/include/machine/rtems-bsd-config.h
+++ b/rtemsbsd/include/machine/rtems-bsd-config.h
@@ -123,8 +123,11 @@ extern "C" {
 #if defined(RTEMS_BSD_CONFIG_FIREWALL_PF)
   #define RTEMS_BSD_CFGDECL_FIREWALL_PF SYSINIT_NEED_FIREWALL_PF
+  #define RTEMS_BSD_CFGDECL_FIREWALL_PF_SERVICE \
+      RTEMS_BSD_RC_CONF_SYSINT(rc_conf_firewall_pf)
 #else
 #endif /* RTEMS_BSD_CONFIG_FIREWALL_PF */
 #if defined(RTEMS_BSD_CONFIG_FIREWALL_PFLOG)
@@ -192,6 +195,7 @@ extern "C" {
    * Create the firewall
   RTEMS_BSD_CFGDECL_FIREWALL_PF;
+  RTEMS_BSD_CFGDECL_FIREWALL_PF_SERVICE;
   RTEMS_BSD_CFGDECL_FIREWALL_PFLOG;
   RTEMS_BSD_CFGDECL_FIREWALL_PFSYNC;
diff --git a/rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h b/rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h
index 34a8a8b..1d14187 100644
--- a/rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h
+++ b/rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h
@@ -155,6 +155,7 @@ extern void rtems_bsd_rc_conf_print_cmd(rtems_bsd_rc_conf* rc_conf,
  * Decls for the handlers.
 void rc_conf_net_init(void* arg);           /* Installed by default. */
+void rc_conf_firewall_pf_init(void* arg);   /* pf_enabled="YES" */
 void rc_conf_telnetd_init(void* arg);       /* telnetd_enabled="YES" */
 void rc_conf_ftpd_init(void* arg);          /* ftpd_enabled="YES" */
diff --git a/rtemsbsd/rtems/rtems-bsd-rc-conf-pf.c b/rtemsbsd/rtems/rtems-bsd-rc-conf-pf.c
new file mode 100644
index 0000000..550bffb
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-bsd-rc-conf-pf.c
@@ -0,0 +1,261 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * Handle the PF firewall directives found in rc.conf.
+ * - pf_enable
+ * - pf_rules
+ * - pf_flags
+ * Note: RTEMS ignores the
+ * - pf_program
+ * directive.
+#include <errno.h>
+#include <stdint.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <strings.h>
+#include <machine/rtems-bsd-commands.h>
+#include <machine/rtems-bsd-rc-conf-services.h>
+static char firewall_pf_rules_default[] = "/etc/pf.conf";
+static int
+firewall_pf_enable(rtems_bsd_rc_conf* rc_conf)
+  char *args[] = {
+    "pfctl",
+    "-q",
+    "-e",
+    NULL
+  rtems_bsd_rc_conf_print_cmd(rc_conf, "pfctl", RTEMS_BSD_ARGC(args),
+      (const char **) args);
+  return rtems_bsd_command_pfctl(RTEMS_BSD_ARGC(args), args);
+static int
+firewall_pf_flush(
+    rtems_bsd_rc_conf* rc_conf,
+    char what[])
+  char *flush[] = {
+    "pfctl",
+    "-q",
+    "-F",
+    what,
+    NULL
+  rtems_bsd_rc_conf_print_cmd(rc_conf, "pfctl", RTEMS_BSD_ARGC(flush),
+      (const char **) flush);
+  return rtems_bsd_command_pfctl(RTEMS_BSD_ARGC(flush), flush);
+ * Executes something like the following command line:
+ *   pfctl -f <rules> [<argv[1]> [<argv[2]> [..]]]
+static int
+firewall_pf_load_rules_with_extra_args(
+    char *rules,
+    int argc,
+    const char **argv)
+  char** args;
+  const int fixed_args = 2; /* "-f" and filename */
+  int arg;
+  int r = -1;
+  bool prepare_failed = false;
+   * argc/argv contains something like the following:
+   *   argc = 3
+   *   argv = {"pf_flags", "-i", "lo0"}
+   * Alternatively it might be
+   *   argc = 0
+   *   argv = NULL
+  /* The code below assumes an argc >= 1. Fake it if there are no additional
+   * arguments. */
+  if(argc == 0) {
+    argc = 1;
+  args = calloc(argc + fixed_args + 1, sizeof(char*));
+  if (args == NULL) {
+    return -1;
+  args[0] = "pfctl";
+  args[1] = "-f";
+  args[2] = rules;
+  args[argc + fixed_args] = NULL;
+  for (arg = 1; arg < argc; ++arg) {
+    args[arg + fixed_args] = strdup(argv[arg]);
+    if (args[arg + fixed_args] == NULL) {
+      prepare_failed = true;
+      break;
+  if (prepare_failed == false) {
+    rtems_bsd_rc_conf_print_cmd(rc_conf, "pfctl", argc + fixed_args,
+    r = rtems_bsd_command_pfctl(argc + fixed_args, args);
+  } else {
+    r = EXIT_FAILURE;
+    free(args[arg + fixed_args]);
+  free(args);
+  return r;
+static int
+firewall_pf_service(rtems_bsd_rc_conf* rc_conf)
+  rtems_bsd_rc_conf_argc_argv* aa;
+  int r;
+  int erroroccured = 0;
+  aa = rtems_bsd_rc_conf_argc_argv_create();
+  if (aa == NULL)
+    return -1;
+  r = rtems_bsd_rc_conf_find(rc_conf, "pf_enable", aa);
+  if (r == 0) {
+    if (aa->argc == 2 && strcasecmp("YES", aa->argv[1]) == 0) {
+      char* rules = firewall_pf_rules_default;
+      int argc = 0;
+      const char** argv = NULL;
+      if (erroroccured == 0) {
+        r = rtems_bsd_rc_conf_find(rc_conf, "pf_rules", aa);
+        if (r == 0) {
+          if (aa->argc == 2) {
+            rules = strdup(aa->argv[1]);
+            if (rules == NULL) {
+              fprintf(stderr,
+                  "error: pf: Could not create rule file string: %s\n",
+                  strerror(errno));
+              erroroccured = -1;
+          } else {
+            fprintf(stderr,
+                "error: pf: Syntax error in pf_rules directive.\n");
+        r = rtems_bsd_rc_conf_find(rc_conf, "pf_flags", aa);
+        if (r == 0) {
+          argc = aa->argc;
+          argv = aa->argv;
+       * FreeBSD does the following on pf_start() in /etc/rc.d/pf:
+       *    check_startmsgs && echo -n 'Enabling pf'
+       *    $pf_program -F all > /dev/null 2>&1
+       *    $pf_program -f "$pf_rules" $pf_flags
+       *    if ! $pf_program -s info | grep -q "Enabled" ; then
+       *        $pf_program -eq
+       *    fi
+       *    check_startmsgs && echo '.'
+       * We should do roughly the same
+        r = firewall_pf_flush(rc_conf, "all");
+        if(r != EXIT_SUCCESS) {
+          fprintf(stderr,
+              "error: pf: Could not flush.\n");
+        r = firewall_pf_load_rules_with_extra_args(rc_conf, rules, argc, argv);
+        if (r != EXIT_SUCCESS) {
+          fprintf(stderr,
+              "error: pf: Could not load rules.\n");
+        r = firewall_pf_enable(rc_conf);
+          fprintf(stderr,
+              "error: pf: Could not enable firewall.\n");
+      if (rules != firewall_pf_rules_default && rules != NULL) {
+        free(rules);
+  rtems_bsd_rc_conf_argc_argv_destroy(aa);
+  return erroroccured;
+void
+rc_conf_firewall_pf_init(void* arg)
+  int r;
+  r = rtems_bsd_rc_conf_service_add("pf",
+                                    "after:network;before:telnetd;",
+                                    firewall_pf_service);
+  if (r < 0)
+    fprintf(stderr,
+            "error: pf service add failed: %s\n", strerror(errno));
diff --git a/testsuite/rcconf02/test_main.c b/testsuite/rcconf02/test_main.c
index 735e555..498621f 100644
--- a/testsuite/rcconf02/test_main.c
+++ b/testsuite/rcconf02/test_main.c
@@ -53,6 +53,7 @@
 #include <assert.h>
 #include <ctype.h>
+#include <fcntl.h>
@@ -122,7 +123,39 @@ static const char* rc_conf_text =                          \
   "\n"                                                     \
   "ftpd_enable=\"YES\"\n"                                  \
   "ftpd_options=\"-v -p 21 -C 10 -P 150 -L -I 10 -R /\"\n" \
-  "n";
+  "\n"                                                     \
+  "pf_enable=\"YES\"\n"                                    \
+  "pf_rules=\"/etc/mypf.conf\"\n"                          \
+  "pf_flags=\"-q -z\"\n"                                   \
+  "\n";
+static const char* pf_conf_text = "pass all\n";
+static const char* pf_os_text = "# empty\n";
+static void
+prepare_files(void)
+  size_t len;
+  size_t written;
+  int fd;
+  int rv;
+  len = strlen(pf_conf_text);
+  fd = open("/etc/mypf.conf", O_WRONLY | O_CREAT, S_IRWXU | S_IRWXG | S_IRWXO);
+  assert(fd != -1);
+  written = write(fd, pf_conf_text, len);
+  assert(written == len);
+  rv = close(fd);
+  assert(rv == 0);
+  len = strlen(pf_os_text);
+  fd = open("/etc/pf.os", O_WRONLY | O_CREAT, S_IRWXU | S_IRWXG | S_IRWXO);
+  assert(fd != -1);
+  written = write(fd, pf_os_text, len);
+  rv = close(fd);
+  assert(rv == 0);
 static void
 test_rc_conf_script(void)
@@ -133,6 +166,9 @@ test_rc_conf_script(void)
   const char* netstat_args[] = {
     "netstat", "-rn", NULL
+  const char* pfctl_args[] = {
+    "pfctl", "-s", "rules", NULL
   printf("--------------- rc.conf -----------------\n");
   printf(rc_conf_text);
@@ -144,6 +180,8 @@ test_rc_conf_script(void)
   rtems_bsd_command_ifconfig(1, (char**) ifconfg_args);
   printf("-------------- NETSTAT ------------------\n");
   rtems_bsd_command_netstat(2, (char**) netstat_args);
+  printf("-------------- PFCTL --------------------\n");
+  rtems_bsd_command_pfctl(RTEMS_BSD_ARGC(pfctl_args), (char **) pfctl_args);
   printf("-----------------------------------------\n");
@@ -181,6 +219,7 @@ shell(void)
 static void
 test_main(void)
+  prepare_files();
   test_rc_conf_script();
   shell();
   exit(0);
@@ -201,6 +240,7 @@ test_main(void)
   &rtems_shell_NETSTAT_Command, \
   &rtems_shell_IFCONFIG_Command, \
   &rtems_shell_TCPDUMP_Command, \
+  &rtems_shell_PFCTL_Command, \
   &rtems_shell_SYSCTL_Command
 #define CONFIGURE_SHELL_COMMAND_CPUUSE
@@ -229,6 +269,7 @@ test_main(void)
 #define RTEMS_BSD_CONFIG_SERVICE_TELNETD
 #define RTEMS_BSD_CONFIG_TELNETD_STACK_SIZE (16 * 1024)
 #define RTEMS_BSD_CONFIG_SERVICE_FTPD
+#define RTEMS_BSD_CONFIG_FIREWALL_PF
 #define CONFIGURE_MAXIMUM_DRIVERS 32
2.9.2
