[PATCH 01/02] USB driver bcm283x_dwcotg added.
Tue Aug 9 05:47:12 UTC 2016
On 08/08/16 20:16, Deval Shah wrote:
> I followed the same guidelines while adding the drivers. Could you
> point out the things I might have missed ?
Yes, sorry, the link below was incomplete. Use this one:
https://git.rtems.org/rtems-libbsd/tree/libbsd.txt#n736
In particular:
"|Immediately check in the imported files without the changes to
`libbsd_waf.py`. Do not touch the imported files yourself at this point."
> Thank you.
> Deval Shah
> On Mon, Aug 8, 2016 at 10:58 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello Deval,
>     please follow the rules for importing FreeBSD in libbsd:
>     <https://git.rtems.org/rtems-libbsd/tree/libbsd.txt#n7>
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
