[PATCH] build-system: Always enable C++ if the compiler is present.
Chris Johns
chrisj at rtems.org
Wed Aug 10 03:10:53 UTC 2016
We always build a C++ compiler and building with C++ does not effect
RTEMS or the runtime. This patch always enabled the support. There is
no need to manually enable it any more.
You can disable C++ with '--disable-cxx'.
If an architecture does not have a C++ compiler support is automatically
disabled.
aclocal/enable-cxx.m4 | 4 ++--
c/src/aclocal/enable-cxx.m4 | 5 +++--
c/src/aclocal/prog-cxx.m4 | 37 +++++++++++++++++++++----------------
c/src/configure.ac | 2 ++
cpukit/configure.ac | 6 ++++--
testsuites/aclocal/enable-cxx.m4 | 5 +++--
testsuites/aclocal/prog-cxx.m4 | 39 ++++++++++++++++++++++-----------------
testsuites/configure.ac | 6 +++++-
8 files changed, 62 insertions(+), 42 deletions(-)
diff --git a/aclocal/enable-cxx.m4 b/aclocal/enable-cxx.m4
index ddd37dc..952f015 100644
--- a/aclocal/enable-cxx.m4
+++ b/aclocal/enable-cxx.m4
@@ -2,10 +2,10 @@ AC_DEFUN([RTEMS_ENABLE_CXX],
AC_ARG_ENABLE(cxx,
[AS_HELP_STRING([--enable-cxx],
-[enable C++ support and build the rtems++ library])],
+[enable C++ support])],
[case "${enable_cxx}" in
yes) RTEMS_HAS_CPLUSPLUS=yes ;;
no) RTEMS_HAS_CPLUSPLUS=no ;;
*) AC_MSG_ERROR(bad value ${enableval} for enable-cxx option) ;;
-esac], [RTEMS_HAS_CPLUSPLUS=no])
+esac], [RTEMS_HAS_CPLUSPLUS=yes])
diff --git a/c/src/aclocal/enable-cxx.m4 b/c/src/aclocal/enable-cxx.m4
index 759d81b..952f015 100644
--- a/c/src/aclocal/enable-cxx.m4
+++ b/c/src/aclocal/enable-cxx.m4
@@ -1,10 +1,11 @@
AC_ARG_ENABLE(cxx,
-[AS_HELP_STRING(--enable-cxx,enable C++ support and build the rtems++ library)],
+[AS_HELP_STRING([--enable-cxx],
diff --git a/c/src/aclocal/prog-cxx.m4 b/c/src/aclocal/prog-cxx.m4
index 957a595..66c986c 100644
--- a/c/src/aclocal/prog-cxx.m4
+++ b/c/src/aclocal/prog-cxx.m4
@@ -1,6 +1,6 @@
-dnl
+dnl
dnl Check for target g++
-dnl
+dnl
AC_DEFUN([RTEMS_PROG_CXX_FOR_TARGET],
@@ -18,21 +18,26 @@ fi
RTEMS_CHECK_TOOL(CXX,g++)
if test "$RTEMS_HAS_CPLUSPLUS" = "yes";
then
-dnl Only accept g++
-dnl NOTE: This might be too restrictive
-test -z "$CXX" \
- && AC_MSG_ERROR([no acceptable c++ found in \$PATH])
-AC_PROG_CXX
-AC_PROG_CXXCPP
- if test "$ac_cv_prog_cc_cross" != "$ac_cv_prog_cxx_cross"; then
- AC_MSG_ERROR([***]
- [Inconsistency in compiler configuration:]
- [Target C compiler and target C++ compiler]
- [must both either be cross compilers or native compilers])
+ dnl Only accept g++
+ dnl NOTE: This might be too restrictive
+ if test -z "$CXX";
+ then
+ RTEMS_HAS_CPLUSPLUS=no
+ HAS_CPLUSPLUS=no
+ ## Work-around to a bug in automake
+ AM_CONDITIONAL([am__fastdepCXX],[false])
+ else
+ AC_PROG_CXX
+ AC_PROG_CXXCPP
+ if test "$ac_cv_prog_cc_cross" != "$ac_cv_prog_cxx_cross"; then
+ AC_MSG_ERROR([***]
+ [Inconsistency in compiler configuration:]
+ [Target C compiler and target C++ compiler]
+ [must both either be cross compilers or native compilers])
+ fi
fi
else
-## Work-around to a bug in automake
-AM_CONDITIONAL([am__fastdepCXX],[false])
fi
diff --git a/c/src/configure.ac b/c/src/configure.ac
index f0d482c..6b34eb5 100644
--- a/c/src/configure.ac
+++ b/c/src/configure.ac
@@ -16,6 +16,7 @@ AM_MAINTAINER_MODE
RTEMS_ENABLE_MULTILIB
RTEMS_ENABLE_MULTIPROCESSING
+RTEMS_ENABLE_CXX
RTEMS_ENV_RTEMSBSP
RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP)
@@ -93,6 +94,7 @@ rtems_cv_CFLAGS_set="${CFLAGS+set}"
CFLAGS="${CFLAGS-${CPU_CFLAGS} ${CFLAGS_OPTIMIZE_V}}"
RTEMS_PROG_CC_FOR_TARGET
+RTEMS_PROG_CXX_FOR_TARGET
AM_PROG_CC_C_O
RTEMS_PROG_CCAS
RTEMS_CANONICALIZE_TOOLS
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 054e60e..136630b 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -13,6 +13,7 @@ AM_MAINTAINER_MODE
RTEMS_ENABLE_POSIX
+RTEMS_ENABLE_CXX
RTEMS_ENABLE_RTEMS_DEBUG
RTEMS_ENABLE_NETWORKING
RTEMS_ENABLE_PARAVIRT
@@ -31,9 +32,10 @@ else
fi
-RTEMS_PROG_CCAS
-RTEMS_CANONICALIZE_TOOLS
AM_PROG_CC_C_O
+RTEMS_CANONICALIZE_TOOLS
+RTEMS_PROG_CCAS
AC_PROG_RANLIB
RTEMS_CHECK_NEWLIB
diff --git a/testsuites/aclocal/enable-cxx.m4 b/testsuites/aclocal/enable-cxx.m4
--- a/testsuites/aclocal/enable-cxx.m4
+++ b/testsuites/aclocal/enable-cxx.m4
@@ -1,10 +1,11 @@
AC_ARG_ENABLE(cxx,
diff --git a/testsuites/aclocal/prog-cxx.m4 b/testsuites/aclocal/prog-cxx.m4
index c71bac9..91f2b7f 100644
--- a/testsuites/aclocal/prog-cxx.m4
+++ b/testsuites/aclocal/prog-cxx.m4
@@ -1,6 +1,6 @@
-dnl
+dnl
-dnl
+dnl
@@ -9,7 +9,7 @@ AC_REQUIRE([RTEMS_ENABLE_CXX])
RTEMS_CHECK_CPUOPTS([RTEMS_SMP])
# If CXXFLAGS is not set, default to CFLAGS
-if test x"$rtems_cv_RTEMS_SMP" = x"yes" ; then
+if test x"$rtems_cv_HAS_SMP" = x"yes" ; then
CXXFLAGS=${CXXFLAGS-${CFLAGS} -std=gnu++11}
else
CXXFLAGS=${CXXFLAGS-${CFLAGS}}
then
-test -z "$CXX" \
-AC_PROG_CXX
-AC_PROG_CXXCPP
+ then
+ HAS_CPLUSPLUS=no
+ else
+ AC_PROG_CXX
+ AC_PROG_CXXCPP
+ fi
fi
else
fi
diff --git a/testsuites/configure.ac b/testsuites/configure.ac
index 963e05b..086f636 100644
--- a/testsuites/configure.ac
+++ b/testsuites/configure.ac
@@ -17,8 +17,12 @@ RTEMS_ENV_RTEMSBSP
RTEMS_PROJECT_ROOT
+RTEMS_PROG_CC_FOR_TARGET
+AM_PROG_CC_C_O
-RTEMS_PROG_CC
RTEMS_CHECK_CPUOPTS([RTEMS_POSIX_API])
RTEMS_CHECK_CPUOPTS([RTEMS_MULTIPROCESSING])
2.4.6
