Error in initializing network parameters
Gedare Bloom
gedare at rtems.org
Wed Aug 10 14:09:25 UTC 2016
We discussed this on IRC and Deval will try to dig deeper to understand the
dhcpd example as an approach to event-based synchronization.
On Mon, Aug 8, 2016 at 2:13 PM, Deval Shah <deval.maker at gmail.com> wrote:
> I ran both the dhcpcd examples. The boot logs are below. I am seeing the
> same problem in these two examples too. Test program tries to get the
> network interfaces but it is not found since the USB initialization is
> still left.
> *** LIBBSD DHCPCD 1 TEST ***
> RTEMS Shell on /dev/console. Use 'help' to list commands.
> [/] # nexus0: <RTEMS Nexus device>
> bcm283x_dwcotg0: <DWC OTG 2.0 integrated USB controller (bcm283x)> on
> nexus0
> bcm283x_dwcotg0: failed to set power state, err=-2
> usbus0 on bcm283x_dwcotg0
> usbus0: 480Mbps High Speed USB v2.0
> uhub0: <DWCOTG OTG Root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
> info: version 6.2.1 starting
> err: no valid interfaces found
> warning: no interfaces have a carrier
> uhub0: 1 port with 1 removable, self powered
> uhub1: <vendor 0x0424 product 0x9514, class 9/0, rev 2.00/2.00, addr 2> on
> usbus0
> uhub1: MTT enabled
> uhub1: 5 ports with 4 removable, self powered
> smsc0: <vendor 0x0424 product 0xec00, rev 2.00/2.00, addr 3> on usbus0
> smsc0: chip 0xec00, rev. 0002
> miibus0: <MII bus> on smsc0
> ukphy0: <Generic IEEE 802.3u media interface> PHY 1 on miibus0
> ukphy0: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
> ue0: <USB Ethernet> on smsc0
> ue0: Ethernet address: 5a:ee:60:74:67:92
> *** LIBBSD DHCPCD 2 TEST ***
> nexus0
> usbus0
> uhub1: MTT enabled
> Any other way to solve this problem ? Any example of mentioned routing
> socket ?
> ᐧ
> On Tue, Aug 2, 2016 at 5:51 PM, Sebastian Huber <sebastian.huber at embedded-
> brains.de> wrote:
>> The USB enumeration runs after the BSD initialization in its own threads.
>> Thus, you have to wait a bit before you attempt to use this interface. You
>> could use a routing socket to do this event triggered, see dhcpcd for an
>> example.
>> On 02/08/16 14:17, Deval Shah wrote:
>>> Hello all,
>>> With the USB and Ethernet working, I started running other tests like
>>> ping01 on raspberry Pi.
>>> I am getting following error while running the PING test.
>>> *** LIBBSD PING 1 TEST ***
>>> nexus0
>>> ifconfig: interface ue0 does not exist
>>> assertion "exit_code == EX_OK" failed: file
>>> "/home/gadgetman/development/rtems/rtems-libbsd/testsuite/in
>>> clude/rtems/bsd/test/default-network-init.h", line 125, function:
>>> default_network_ifconfig_hwif0
>>> In general boot-log, like in init test, after detecting the "uhub0"
>>> device it detects "uhub1" device, which is the usb_ethernet controller. And
>>> after that the Ethernet interface "ue0" exists.
>>> *** LIBBSD INIT 1 TEST ***
>>> nexus0
>>> Sleeping to see what happens
>>> on usbus0
>>> uhub1: MTT enabled
>>> I believe the default-network-init.h tries to access the ethernet
>>> interface before it is created and the problem arises. I tried moving
>>> bsp/nexus-devices.h before rtems/bsd/test/default-network-init.h, but
>>> the problem remains the same. Any pointers ?
>>> Regards,
>>> Deval Shah
>>> ᐧ
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Deval Shah
> Graduate Student,
> B.E. (Hons.) Electrical and Electronics Engineering
> BITS Pilani Hyderabad Campus <http://www.bits-pilani.ac.in/hyderabad/>
> Github Profile <https://github.com/deval-maker>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160810/377b403f/attachment.html>
