[PATCH 1/4] libdl: Add trace output when reading section headers.
Fri Aug 12 09:21:00 UTC 2016
 cpukit/libdl/rtl-elf.c | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/cpukit/libdl/rtl-elf.c b/cpukit/libdl/rtl-elf.c
index 48d81df..b686a48 100644
--- a/cpukit/libdl/rtl-elf.c
+++ b/cpukit/libdl/rtl-elf.c
@@ -644,6 +644,9 @@ rtems_rtl_elf_parse_sections (rtems_rtl_obj_t* obj, int fd, Elf_Ehdr* ehdr)
     off = obj->ooffset + ehdr->e_shoff + (((uint32_t) section) * ehdr->e_shentsize);
+    if (rtems_rtl_trace (RTEMS_RTL_TRACE_DETAIL))
+      printf ("rtl: section header: %2d: offset=%d\n", section, (int) off);
     if (!rtems_rtl_obj_cache_read_byval (sects, fd, off, &shdr, sizeof (shdr)))
       return false;
2.4.6
