[PATCH] arm/xilinx_zynq: Disable the MMU and the data and instruction cache on boot.
Sun Aug 14 23:40:05 UTC 2016
Hi Pavel,
Thank you for taking the time to provide a really great explanation.
On 14/08/2016 20:44, Pavel Pisa wrote:
> So I have kept the code in bsp_start_hook_0 for RaspberryPi
> https://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c#n39
I added the code from the RPi hook_0 into arm_a9mpcore_start_hook_0 and
it works. I am wondering if this should be moved to the cp15-start
header as a function so we can share it.
