[PATCH] arm/cortex-a: Fix cache flush/invalidate after u-boot.
Tue Aug 16 05:40:40 UTC 2016
On 16/08/2016 15:36, Sebastian Huber wrote:
> On 16/08/16 07:35, Chris Johns wrote:
>> On 16/08/2016 15:32, Sebastian Huber wrote:
>>> https://docs.rtems.org/doc-current/share/rtems/html/c_user/Interrupt-Manager-INTERRUPT_005fLOCAL_005fDISABLE-_002d-Disable-Interrupts-on-Current-Processor.html#Interrupt-Manager-INTERRUPT_005fLOCAL_005fDISABLE-_002d-Disable-Interrupts-on-Current-Processor
>> Thank you. I will send a patch in for this.
> Is a local interrupt disable sufficient on SMP configurations?
I do not know. I am only fixing the code because it does not build on SMP.
