[PATCH v2 1/2] arm/cortex-a: Fix cache flush/invalidate after u-boot.
Chris Johns
chrisj at rtems.org
Tue Aug 16 05:45:18 UTC 2016
This is a copy of the patch from Pavel to fix some strange behaviour with
data cache, instruction cache and MMU being enabled by u-boot on the
RaspberryPi.
Closes #2774.
.../libbsp/arm/shared/include/arm-a9mpcore-start.h | 38 ++++++++++++++++++++++
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 1 +
c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am | 4 +++
3 files changed, 43 insertions(+)
diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
index 7d6185b..2304650 100644
--- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
+++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
@@ -30,8 +30,10 @@
#include <bsp.h>
#include <bsp/start.h>
#include <bsp/arm-a9mpcore-regs.h>
+#include <bsp/arm-cache-l1.h>
#include <bsp/arm-errata.h>
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
@@ -129,8 +131,44 @@ BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_hook_0(void)
volatile a9mpcore_scu *scu =
(volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
uint32_t cpu_id = arm_cortex_a9_get_multiprocessor_cpu_id();
+ uint32_t sctlr_val;
+ sctlr_val = arm_cp15_get_control();
+ * Current U-boot loader seems to start kernel image
+ * with I and D caches on and MMU enabled.
+ * If RTEMS application image finds that cache is on
+ * during startup then disable caches.
+ if (sctlr_val & (ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M)) {
+ if (sctlr_val & (ARM_CP15_CTRL_C | ARM_CP15_CTRL_M)) {
+ * If the data cache is on then ensure that it is clean
+ * before switching off to be extra carefull.
+ if (cpu_id == 0) {
+ rtems_cache_flush_entire_data();
+ rtems_cache_invalidate_entire_data();
+ arm_cp15_flush_prefetch_buffer();
+ sctlr_val &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M | ARM_CP15_CTRL_A);
+ arm_cp15_set_control(sctlr_val);
+ rtems_cache_invalidate_entire_instruction();
+ } else {
+ arm_cache_l1_invalidate_entire_data();
+ arm_cache_l1_invalidate_entire_instruction();
arm_cp15_branch_predictor_invalidate_all();
+ arm_cp15_tlb_invalidate();
+ /* Clear Translation Table Base Control Register */
+ arm_cp15_set_translation_table_base_control_register(0);
if (cpu_id == 0) {
arm_a9mpcore_start_scu_enable(scu);
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index 8e6f8c3..1ccc33c 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -43,6 +43,7 @@ include_bsp_HEADERS += ../shared/include/arm-gic-irq.h
include_bsp_HEADERS += ../shared/include/arm-gic-regs.h
include_bsp_HEADERS += ../shared/include/arm-gic-tm27.h
include_bsp_HEADERS += ../shared/include/arm-release-id.h
+include_bsp_HEADERS += ../shared/include/arm-cache-l1.h
include_bsp_HEADERS += include/cadence-i2c.h
include_bsp_HEADERS += include/cadence-i2c-regs.h
include_bsp_HEADERS += include/i2c.h
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am b/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
index a75c344..f97a453 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
@@ -126,6 +126,10 @@ $(PROJECT_INCLUDE)/bsp/arm-release-id.h: ../shared/include/arm-release-id.h $(PR
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-release-id.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-release-id.h
+$(PROJECT_INCLUDE)/bsp/arm-cache-l1.h: ../shared/include/arm-cache-l1.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-cache-l1.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-cache-l1.h
$(PROJECT_INCLUDE)/bsp/cadence-i2c.h: include/cadence-i2c.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/cadence-i2c.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/cadence-i2c.h
2.4.6
