[PATCH] arm/cortex-a: Fix cache flush/invalidate after u-boot.
Tue Aug 16 05:54:35 UTC 2016
On 16/08/16 07:40, Chris Johns wrote:
> On 16/08/2016 15:36, Sebastian Huber wrote:
>> On 16/08/16 07:35, Chris Johns wrote:
>>> On 16/08/2016 15:32, Sebastian Huber wrote:
>>>> https://docs.rtems.org/doc-current/share/rtems/html/c_user/Interrupt-Manager-INTERRUPT_005fLOCAL_005fDISABLE-_002d-Disable-Interrupts-on-Current-Processor.html#Interrupt-Manager-INTERRUPT_005fLOCAL_005fDISABLE-_002d-Disable-Interrupts-on-Current-Processor
>>> Thank you. I will send a patch in for this.
>> Is a local interrupt disable sufficient on SMP configurations?
> I do not know. I am only fixing the code because it does not build on
> SMP.
It is intentional that this code doesn't build on SMP. This change to
rtems_interrupt_local_disable()
flags places which need some attention to correctly work on SMP or need
to be disabled.
See also:
https://lists.rtems.org/pipermail/devel/2015-June/011535.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
