[PATCH v2 2/2] libbsp/arm: Fix the local interrupt mask disable/enable calls.
Tue Aug 16 05:55:57 UTC 2016
On 16/08/16 07:45, Chris Johns wrote:
>   c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c | 4 ++--
>   1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c b/c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c
> index f650009..cfad45f 100644
> --- a/c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c
> +++ b/c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c
> @@ -88,10 +88,10 @@ uint32_t arm_cp15_set_translation_table_entries(
>     rtems_interrupt_level level;
>     uint32_t section_flags_of_first_entry;
> -  rtems_interrupt_disable(level);
> +  rtems_interrupt_local_disable(level);
>     section_flags_of_first_entry =
>       set_translation_table_entries(begin, end, section_flags);
> -  rtems_interrupt_enable(level);
> +  rtems_interrupt_local_enable(level);
>     return section_flags_of_first_entry;
We should only change this if this is known to work on SMP.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
