[PATCH] psxtests: Adjust sporadic server tests
Wed Aug 17 07:14:51 UTC 2016
According to POSIX priority value returned from pthread_getschedparam()
shall be the value specified by the most recent pthread_setschedparam(),
pthread_setschedprio(), or pthread_create() call affecting the target
thread.  Read this as though a temporary lower priority due to the
sporadic server policy shall not be visible through
pthread_getschedparam().  Thus, use rtems_task_set_priority() to get the
current priority of the threads.
Use a priority ceiling mutex to prevent sporadic server priority
adjustments.
 testsuites/psxtests/psx09/init.c    | 120 ++++++++++++------------------------
 testsuites/psxtests/psx09/psx09.scn |  18 +++---
 testsuites/psxtests/psx12/init.c    |  25 +++++---
 3 files changed, 64 insertions(+), 99 deletions(-)
diff --git a/testsuites/psxtests/psx09/init.c b/testsuites/psxtests/psx09/init.c
index 64bb4af..d9226c9 100644
--- a/testsuites/psxtests/psx09/init.c
+++ b/testsuites/psxtests/psx09/init.c
@@ -20,33 +20,22 @@
 const char rtems_test_name[] = "PSX 9";
-void print_schedparam(
-  char               *prefix,
-  struct sched_param *schedparam
-int HIGH_PRIORITY;
-int MEDIUM_PRIORITY;
-int LOW_PRIORITY;
-  char               *prefix,
+static int CEILING_PRIORITY;
+static int HIGH_PRIORITY;
+static int LOW_PRIORITY;
+static int get_current_prio( pthread_t thread )
-  printf( "%ssched priority      = %d\n", prefix, schedparam->sched_priority );
-#if defined(_POSIX_SPORADIC_SERVER)
-  printf( "%ssched_ss_low_priority     = %d\n",
-      prefix, schedparam->sched_ss_low_priority );
-  printf( "%ssched_ss_repl_period = (%" PRIdtime_t ", %ld)\n", prefix,
-     schedparam->sched_ss_repl_period.tv_sec,
-     schedparam->sched_ss_repl_period.tv_nsec );
-  printf( "%ssched_ss_init_budget = (%" PRIdtime_t ", %ld)\n", prefix,
-     schedparam->sched_ss_init_budget.tv_sec,
-     schedparam->sched_ss_init_budget.tv_nsec );
-#else
-  printf( "%s_POSIX_SPORADIC_SERVER is not defined\n", prefix );
-#endif
+  rtems_status_code sc;
+  rtems_task_priority prio;
+  int max;
+  sc = rtems_task_set_priority( thread, RTEMS_CURRENT_PRIORITY, &prio );
+  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
+  max = sched_get_priority_max( SCHED_FIFO );
+  return max + 1 - (int) prio;
 static void *mutex_lock_task(void *arg)
@@ -109,6 +98,10 @@ void *POSIX_Init(
   TEST_BEGIN();
+  CEILING_PRIORITY = sched_get_priority_max( SCHED_SPORADIC );
+  HIGH_PRIORITY = sched_get_priority_max( SCHED_SPORADIC ) - 1;
+  LOW_PRIORITY = sched_get_priority_max( SCHED_SPORADIC ) - 2;
   test_destroy_locked_mutex();
   /* set the time of day, and print our buffer in multiple ways */
@@ -135,28 +128,25 @@ void *POSIX_Init(
   schedparam.sched_ss_init_budget.tv_sec = 0;
   schedparam.sched_ss_init_budget.tv_nsec = 250000000;    /* 1/4 second */
-  schedparam.sched_priority = sched_get_priority_max(SCHED_SPORADIC);
-  schedparam.sched_ss_low_priority = sched_get_priority_max(SCHED_SPORADIC) - 2;
+  schedparam.sched_priority = HIGH_PRIORITY;
+  schedparam.sched_ss_low_priority = LOW_PRIORITY;
   puts( "Init: pthread_setschedparam - SUCCESSFUL (sporadic server)" );
   status = pthread_setschedparam( pthread_self(), SCHED_SPORADIC, &schedparam );
   rtems_test_assert( !status );
-  status = pthread_getschedparam( pthread_self(), &schedpolicy, &schedparam );
-  rtems_test_assert( !status );
-  priority = schedparam.sched_priority;
-  sprintf( buffer, " - new priority = %d", priority );
+  sprintf( buffer, " - new priority = %d", get_current_prio( pthread_self() ) );
   print_current_time( "Init: ", buffer );
   /* go into a loop consuming CPU time to watch our priority change */
   for ( passes=0 ; passes <= 3 ; ) {
+    int current_priority;
-    if ( priority != schedparam.sched_priority ) {
+    current_priority = get_current_prio( pthread_self() );
+    if ( priority != current_priority ) {
+      priority = current_priority;
       passes++;
@@ -175,10 +165,6 @@ void *POSIX_Init(
-  HIGH_PRIORITY = sched_get_priority_max( SCHED_SPORADIC );
-  MEDIUM_PRIORITY = sched_get_priority_max( SCHED_SPORADIC ) - 2;
-  LOW_PRIORITY = sched_get_priority_max( SCHED_SPORADIC ) - 4;
@@ -190,7 +176,10 @@ void *POSIX_Init(
   status = pthread_mutexattr_init( &attr );
-  status = pthread_mutexattr_setprotocol( &attr, PTHREAD_PRIO_INHERIT );
+  status = pthread_mutexattr_setprotocol( &attr, PTHREAD_PRIO_PROTECT );
+  rtems_test_assert( !status );
+  status = pthread_mutexattr_setprioceiling( &attr, CEILING_PRIORITY );
   puts( "Init: Creating a mutex" );
@@ -199,11 +188,7 @@ void *POSIX_Init(
     printf( "status = %d\n", status );
   /* go into a loop consuming CPU time to watch our priority NOT lower */
@@ -216,32 +201,16 @@ void *POSIX_Init(
     printf( "status = %d %s\n", status, strerror(status) );
-  for ( ; ; ) {
+  do {
+    priority = get_current_prio( pthread_self() );
-    if ( schedparam.sched_priority == LOW_PRIORITY ) {
+    if ( priority != CEILING_PRIORITY ) {
       puts( "ERROR - Init's priority lowered while holding mutex" );
       rtems_test_exit(0);
     now = time( &now );
-    if ( now - start > 3 )
-      break;
-    print_current_time( "Init: ", buffer );
-    break;
+  } while ( now - start < 3 );
   /* with this unlock we should be able to go to low priority */
@@ -251,26 +220,15 @@ void *POSIX_Init(
   for ( ; ; ) {
+    if ( get_current_prio( pthread_self() ) == LOW_PRIORITY )
       break;
   TEST_END();
diff --git a/testsuites/psxtests/psx09/psx09.scn b/testsuites/psxtests/psx09/psx09.scn
index c3e6dad..766fd0f 100644
--- a/testsuites/psxtests/psx09/psx09.scn
+++ b/testsuites/psxtests/psx09/psx09.scn
@@ -1,22 +1,20 @@
-*** POSIX TEST 9 ***
+*** BEGIN OF TEST PSX 9 ***
 Init's ID is 0x0b010001
 Init: pthread_getschedparam - SUCCESSFUL
 Init: Fri May 24 11:05:00 1996 - current priority = 2
-Init: Fri May 24 11:05:00 1996 - new priority = 254
 Init: Fri May 24 11:05:00 1996 - new priority = 252
-Init: Fri May 24 11:05:01 1996 - new priority = 254
+Init: Fri May 24 11:05:00 1996 - new priority = 253
+Init: Fri May 24 11:05:00 1996 - new priority = 252
 Init: Initializing mutex attributes for priority ceiling
 Init: pthread_mutex_lock acquire the lock
 Init: unlock mutex
-Init: Fri May 24 11:05:01 1996 - new priority = 250
-*** END OF POSIX TEST 9 ***
+Init: Fri May 24 11:05:03 1996 - new priority = 253
+Init: Fri May 24 11:05:03 1996 - new priority = 252
+*** END OF TEST PSX 9 **
diff --git a/testsuites/psxtests/psx12/init.c b/testsuites/psxtests/psx12/init.c
index d721893..46fb016 100644
--- a/testsuites/psxtests/psx12/init.c
+++ b/testsuites/psxtests/psx12/init.c
@@ -44,16 +44,25 @@ typedef struct {
 static test_context test_instance;
+  int max;
 static void wait_for_prio( int prio )
-  int                status;
-  int                policy;
-  struct sched_param param;
-  do {
-    status = pthread_getschedparam( pthread_self(), &policy, &param );
-    rtems_test_assert( status == 0 );
-  } while ( prio != param.sched_priority );
+  while ( prio != get_current_prio( pthread_self() ) ) {
+    /* Wait */
 static uint64_t timeval_to_us( const struct timeval *tv )
1.8.4.5
