VFP support for lpc32xx
Thu Aug 18 05:26:11 UTC 2016
Hello Kevin,
please send the GCC patches first to the GCC mailing list for upstream
integration.
Later we have to update the documentation:
https://docs.rtems.org/doc-current/share/rtems/html/cpu_supplement/ARM-Specific-Information-Multilibs.html#ARM-Specific-Information-Multilibs
Tthe documentation system moved to sphinx and updates for the RTEMS Git
master are currently stalled.
On 17/08/16 21:04, Kirspel, Kevin wrote:
> I have a patch for the RTEMS source builder as well as RTEMS itself to
> support the VFP on the lpc32xx.  I don’t have hardware the matches the
> lpc32xx BSP but I do have some custom hardware that I can run the test
> suite on.  Can you point me to some documentation that tells you how
> to automate the running of the test suite?
> Kevin Kirspel
> Electrical Engineer - Sr. Staff
> Opti Medical
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642
> Direct: (770)-688-1642
> Fax: (770)-510-4445
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
