[PATCH 5/5] psxtests: new test psxshm02 using heap for shm objects
Wed Aug 17 20:02:41 UTC 2016
 testsuites/psxtests/psxshm02/Makefile.am  | 22 ++++++++
 testsuites/psxtests/psxshm02/init.c       | 91 +++++++++++++++++++++++++++++++
 testsuites/psxtests/psxshm02/psxshm02.scn |  0
 testsuites/psxtests/psxshm02/system.h     | 38 +++++++++++++
 4 files changed, 151 insertions(+)
 create mode 100644 testsuites/psxtests/psxshm02/Makefile.am
 create mode 100644 testsuites/psxtests/psxshm02/init.c
 create mode 100644 testsuites/psxtests/psxshm02/psxshm02.scn
 create mode 100644 testsuites/psxtests/psxshm02/system.h
diff --git a/testsuites/psxtests/psxshm02/Makefile.am b/testsuites/psxtests/psxshm02/Makefile.am
new file mode 100644
index 0000000..c174b0c
--- /dev/null
+++ b/testsuites/psxtests/psxshm02/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxshm02
+psxshm02_SOURCES = init.c system.h
+dist_rtems_tests_DATA = psxshm02.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/include
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxshm02_OBJECTS)
+LINK_LIBS = $(psxshm02_LDLIBS)
+psxshm02$(EXEEXT): $(psxshm02_OBJECTS) $(psxshm02_DEPENDENCIES)
+	@rm -f psxshm02$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxshm02/init.c b/testsuites/psxtests/psxshm02/init.c
index 0000000..29dea97
--- /dev/null
+++ b/testsuites/psxtests/psxshm02/init.c
@@ -0,0 +1,91 @@
+ * Copyright (c) 2016 Gedare Bloom.
+ * From http://pubs.opengroup.org/onlinepubs/9699919799/functions/shm_open.html
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+#include "pritime.h"
+#include <sys/mman.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <string.h>
+const char rtems_test_name[] = "PSX SHM02";
+#define MAX_LEN 10000
+struct region {        /* Defines "structure" of shared memory */
+  int len;
+  char buf[MAX_LEN];
+void *POSIX_Init(
+  void *argument
+  struct region *p;
+  int fd;
+  int err;
+  char *name = "/shm";
+  TEST_BEGIN();
+  puts( "Init: shm_open" );
+  fd = shm_open( name, O_CREAT | O_RDWR, S_IRUSR | S_IWUSR );
+  if ( fd == -1 ) {
+    printf ( "Error: %s\n", strerror(errno) );
+    rtems_test_assert( fd != -1 );
+  puts( "Init: ftruncate" );
+  err = ftruncate( fd, sizeof( struct region ) );
+  if ( err == -1 ) {
+    rtems_test_assert( err != -1 );
+  puts( "Init: mmap" );
+  p = mmap(
+    NULL,
+    sizeof( struct region ),
+    PROT_READ | PROT_WRITE, MAP_SHARED,
+    fd,
+    0
+  rtems_test_assert( p != MAP_FAILED );
+  puts( "Init: write to mapped region" );
+  p->len = MAX_LEN;
+  puts( "Init: munmap" );
+  err = munmap( p, sizeof( struct region ) );
+  puts( "Init: close" );
+  err = close( fd );
+  TEST_END();
+  rtems_test_exit(0);
+  return 0;
diff --git a/testsuites/psxtests/psxshm02/psxshm02.scn b/testsuites/psxtests/psxshm02/psxshm02.scn
index 0000000..e69de29
diff --git a/testsuites/psxtests/psxshm02/system.h b/testsuites/psxtests/psxshm02/system.h
index 0000000..8d11792
--- /dev/null
+++ b/testsuites/psxtests/psxshm02/system.h
@@ -0,0 +1,38 @@
+#include <pmacros.h>
+#include <unistd.h>
+#include <errno.h>
+void *POSIX_Init(
+  void *argument
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS     1
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
+#define CONFIGURE_MAXIMUM_POSIX_SHMS 1
+#define CONFIGURE_MEMORY_OVERHEAD 10
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/posix/shm.h>
+const POSIX_Shm_Object_operations _POSIX_Shm_Object_operations = {
+  _POSIX_Shm_Object_create_from_heap,
+  _POSIX_Shm_Object_resize_from_heap,
+  _POSIX_Shm_Object_delete_from_heap,
+  _POSIX_Shm_Object_mmap_from_heap
+#define CONFIGURE_HAS_OWN_POSIX_SHM_OBJECT_OPERATIONS
+#include <rtems/confdefs.h>
1.9.1
