[PATCH] DMA : Added DMA API for Raspberrypi
Mudit Jain
muditjain18011995 at gmail.com
Sat Aug 20 15:33:18 UTC 2016
Brief API Description
rpi_dma_init -> Initializes the channel structure
and its members for that particular channel, gets
the physical address of the control block structure
and installs the interrupt handler.
rpi_dma_allocate -> Allocates the channel if it is
not busy
rpi_dma_setup_dst & rpi_dma_setup_src -> These setup
src and dst parameters like dreq, width. Basically they
configure the info section of the control block structure
of that particular channel.
rpi_dma_setup_intr -> These will assign the handler
function for channel interrupt. This basically again
updates the channel structure with that function.
Note : rpi_dma_intr is the callback function for the
interrupt controller and calls this function internally.
rpi_dma_start -> Here you provide the virtual address,
the channel to be used and the width. Internally, it
converts the address to physical address and configures
the control block for that channel.
It flushes and invalidates the cache and writes the physical
address of the control block to a particular register
corresponding to the channel.
rpi_dma_free -> Frees the channel
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 4 +
c/src/lib/libbsp/arm/raspberrypi/include/dma.h | 200 ++++++++
c/src/lib/libbsp/arm/raspberrypi/misc/dma.c | 618 +++++++++++++++++++++++++
3 files changed, 822 insertions(+)
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/include/dma.h
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/misc/dma.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 4b111ad..5b0e92e 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -51,6 +51,7 @@ include_bsp_HEADERS += include/rpi-gpio.h
include_bsp_HEADERS += include/i2c.h
include_bsp_HEADERS += include/spi.h
include_bsp_HEADERS += include/mailbox.h
+include_bsp_HEADERS += include/dma.h
include_bsp_HEADERS += include/vc.h
include_bsp_HEADERS += include/rpi-fb.h
include_bsp_HEADERS += console/fbcons.h
@@ -124,6 +125,9 @@ libbsp_a_SOURCES += console/fb.c
libbsp_a_SOURCES += console/fbcons.c
libbsp_a_SOURCES += console/outch.c
+# DMA
+libbsp_a_SOURCES += misc/dma.c
# Mailbox
libbsp_a_SOURCES += misc/mailbox.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/dma.h b/c/src/lib/libbsp/arm/raspberrypi/include/dma.h
new file mode 100644
index 0000000..c49a575
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/dma.h
@@ -0,0 +1,200 @@
+ * @file
+ * @ingroup raspberrypi_dma
+ * @brief Direct memory access (DMA) support.
+#ifndef LIBBSP_ARM_RASPBERRYPI_DMA_H
+#define LIBBSP_ARM_RASPBERRYPI_DMA_H
+#define BCM_DMA_BLOCK_SIZE 512
+/* DMA0-DMA15 but DMA15 is special */
+#define BCM_DMA_CH_MAX 12
+/* request CH for any nubmer */
+#define BCM_DMA_CH_INVALID ( -1 )
+#define BCM_DMA_CH_ANY ( -1 )
+/* Peripheral DREQ Signals (4.2.1.3) */
+#define BCM_DMA_DREQ_NONE 0
+#define BCM_DMA_DREQ_EMMC 11
+#define BCM_DMA_DREQ_SDHOST 13
+#define BCM_DMA_SAME_ADDR 0
+#define BCM_DMA_INC_ADDR 1
+#define BCM_DMA_32BIT 0
+#define BCM_DMA_128BIT 1
+ * Defines for converting physical address to VideoCore bus address and back
+#define BCM2835_VCBUS_SDRAM_CACHED 0x40000000
+#define BCM2835_VCBUS_IO_BASE 0x7E000000
+#define BCM2835_VCBUS_SDRAM_UNCACHED 0xC0000000
+#ifdef SOC_BCM2836
+#define BCM2835_VCBUS_SDRAM_BASE BCM2835_VCBUS_SDRAM_UNCACHED
+#else
+#define BCM2835_VCBUS_SDRAM_BASE BCM2835_VCBUS_SDRAM_CACHED
+#endif
+#define BCM2835_ARM_IO_SIZE 0x01000000
+ * Convert physical address to VC bus address. Should be used
+ * when submitting address over mailbox interface
+#define PHYS_TO_VCBUS( pa ) ( ( pa ) + BCM2835_VCBUS_SDRAM_BASE )
+/* Check whether pa bellong top IO window */
+#define BCM2835_ARM_IS_IO( pa ) ( ( ( pa ) >= RPI_PERIPHERAL_BASE ) && \
+ ( ( pa ) < RPI_PERIPHERAL_BASE + \
+ BCM2835_ARM_IO_SIZE ) )
+ * Convert physical address in IO space to VC bus address.
+#define IO_TO_VCBUS( pa ) ( ( ( pa ) - RPI_PERIPHERAL_BASE ) + \
+ BCM2835_VCBUS_IO_BASE )
+ * Convert address from VC bus space to physical. Should be used
+ * when address is returned by VC over mailbox interface. e.g.
+ * framebuffer base
+#define VCBUS_TO_PHYS( vca ) ( ( vca ) & ~( BCM2835_VCBUS_SDRAM_BASE ) )
+struct bus_dmamap {
+ void *buffer_begin;
+ uint32_t buffer_size;
+typedef struct bus_dmamap *bus_dmamap_t;
+ * bus_dma_segment_t
+ * Describes a single contiguous DMA transaction. Values
+ * are suitable for programming into DMA registers.
+typedef struct bus_dma_segment {
+ unsigned int ds_addr; /* DMA address */
+ unsigned int ds_len; /* length of transfer */
+} bus_dma_segment_t;
+/* DMA Control Block - 256bit aligned (p.40) */
+struct bcm_dma_cb {
+ uint32_t info; /* Transfer Information */
+ uint32_t src; /* Source Address */
+ uint32_t dst; /* Destination Address */
+ uint32_t len; /* Transfer Length */
+ uint32_t stride; /* 2D Mode Stride */
+ uint32_t next; /* Next Control Block Address */
+ uint32_t rsvd1; /* Reserved */
+ uint32_t rsvd2; /* Reserved */
+/* DMA Channel Structure */
+struct bcm_dma_ch {
+ int ch;
+ uint32_t flags;
+ struct bcm_dma_cb *cb;
+ uint32_t vc_cb;
+ bus_dmamap_t dma_map;
+ void ( *intr_func )(
+ int,
+ void *
+ void *intr_arg;
+ Atomic_Flag dma_lock;
+/* API */
+ * Allocate DMA channel for further use.
+rtems_status_code rpi_dma_allocate( int req_ch );
+ * Frees allocated channel.
+rtems_status_code rpi_dma_free( int ch );
+ * Assign handler function for channel interrupt
+rtems_status_code rpi_dma_setup_intr( int ch, void ( *func )(
+ int,
+ void *
+ ), void *arg );
+ * Setup DMA source parameters
+ * ch - channel number
+ * dreq - hardware DREQ # or BCM_DMA_DREQ_NONE if
+ * source is physical memory
+ * inc_addr - BCM_DMA_INC_ADDR if source address
+ * should be increased after each access or
+ * BCM_DMA_SAME_ADDR if address should remain
+ * the same
+ * width - size of read operation, BCM_DMA_32BIT
+ * for 32bit bursts, BCM_DMA_128BIT for 128 bits
+rtems_status_code rpi_dma_setup_src(
+ int ch,
+ int dreq,
+ int inc_addr,
+ int width
+ * Setup DMA destination parameters
+ * destination is physical memory
+ * the same
+ * width - size of write operation, BCM_DMA_32BIT
+rtems_status_code rpi_dma_setup_dst(
+ int ch,
+ int dreq,
+ int inc_addr,
+ int width
+ * Start DMA transaction
+ * src, dst - source and destination address in
+ * ARM physical memory address space.
+ * len - amount of bytes to be transferred
+rtems_status_code rpi_dma_start(
+ int ch,
+ vm_paddr_t src,
+ vm_paddr_t dst,
+ int len
+ * Initializes the DMA
+int rpi_dma_init( int ch );
+ * Get length requested for DMA transaction
+uint32_t rpi_dma_length( int ch );
+static void rpi_dma_intr( void *arg );
+#endif /* LIBBSP_ARM_RASPBERRYPI_DMA_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/dma.c b/c/src/lib/libbsp/arm/raspberrypi/misc/dma.c
index 0000000..4fbf73b
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/misc/dma.c
@@ -0,0 +1,618 @@
+ * @file
+ * @ingroup rpi_dma
+#include <bsp.h>
+#include <bsp/raspberrypi.h>
+#include <bsp/dma.h>
+#include <bsp/irq.h>
+#include <stdlib.h>
+#include <errno.h>
+/* private flags */
+#define BCM_DMA_CH_USED 0x00000001
+#define BCM_DMA_CH_FREE 0x40000000
+#define BCM_DMA_CH_UNMAP 0x80000000
+/* Register Map (4.2.1.2) */
+#define BCM_DMA_CS( n ) ( 0x100 * ( n ) + 0x00 )
+/* Different States */
+#define CS_ACTIVE ( 1 << 0 )
+#define CS_END ( 1 << 1 )
+#define CS_INT ( 1 << 2 )
+#define CS_DREQ ( 1 << 3 )
+#define CS_ISPAUSED ( 1 << 4 )
+#define CS_ISHELD ( 1 << 5 )
+#define CS_ISWAIT ( 1 << 6 )
+#define CS_ERR ( 1 << 8 )
+#define CS_WAITWRT ( 1 << 28 )
+#define CS_DISDBG ( 1 << 29 )
+#define CS_ABORT ( 1 << 30 )
+#define CS_RESET ( 1U << 31 )
+#define BCM_DMA_CBADDR( n ) ( 0x100 * ( n ) + 0x04 )
+#define BCM_DMA_INFO( n ) ( 0x100 * ( n ) + 0x08 )
+#define INFO_INT_EN ( 1 << 0 )
+#define INFO_TDMODE ( 1 << 1 )
+#define INFO_WAIT_RESP ( 1 << 3 )
+#define INFO_D_INC ( 1 << 4 )
+#define INFO_D_WIDTH ( 1 << 5 )
+#define INFO_D_DREQ ( 1 << 6 )
+#define INFO_S_INC ( 1 << 8 )
+#define INFO_S_WIDTH ( 1 << 9 )
+#define INFO_S_DREQ ( 1 << 10 )
+#define INFO_WAITS_SHIFT ( 21 )
+#define INFO_PERMAP_SHIFT ( 16 )
+#define INFO_PERMAP_MASK ( 0x1f << INFO_PERMAP_SHIFT )
+#define BCM_DMA_SRC( n ) ( 0x100 * ( n ) + 0x0C )
+#define BCM_DMA_DST( n ) ( 0x100 * ( n ) + 0x10 )
+#define BCM_DMA_LEN( n ) ( 0x100 * ( n ) + 0x14 )
+#define BCM_DMA_STRIDE( n ) ( 0x100 * ( n ) + 0x18 )
+#define BCM_DMA_CBNEXT( n ) ( 0x100 * ( n ) + 0x1C )
+#define BCM_DMA_DEBUG( n ) ( 0x100 * ( n ) + 0x20 )
+#define DEBUG_ERROR_MASK ( 7 )
+#define BCM_DMA_INT_STATUS 0xfe0
+#define BCM_DMA_ENABLE 0xff0
+#define BCM_PAGE_SIZE 4096
+#define BCM_PAGE_MASK ( BCM_PAGE_SIZE - 1 )
+ * @brief Table that indicates if a channel is currently occupied.
+static struct bcm_dma_ch bcm_dma_ch[ BCM_DMA_CH_MAX ];
+rtems_status_code rpi_dma_reset( int ch );
+int bus_dmamap_load_buffer(
+ bus_dma_segment_t segs[],
+ void *buf,
+ unsigned int buflen,
+ int flags,
+ vm_offset_t *lastaddrp,
+ int *segp,
+ int first
+static void rpi_dmamap_cb(
+ void *arg,
+ bus_dma_segment_t *segs,
+ int nseg,
+ int err
+ unsigned int *addr;
+ if ( err )
+ return;
+ addr = (unsigned int *) arg;
+ *addr = PHYS_TO_VCBUS( segs[ 0 ].ds_addr );
+ uint32_t cs; /* Current State */
+ int count;
+ /* Check the channel number provided */
+ if ( ch < 0 || ch >= BCM_DMA_CH_MAX )
+ return ( RTEMS_INVALID_ID );
+ /* Current State of the channel */
+ cs = BCM2835_REG( BCM_DMA_CS( ch ) );
+ if ( cs & CS_ACTIVE ) {
+ /* Pause current task */
+ BCM2835_REG( BCM_DMA_CS( ch ) ) = 0;
+ /* Wait */
+ count = 1000;
+ do {
+ } while ( !( cs & CS_ISPAUSED ) && ( count-- > 0 ) );
+ if ( !( cs & CS_ISPAUSED ) ) {
+ return ( RTEMS_RESOURCE_IN_USE );
+ /* Clear the next control block address */
+ BCM2835_REG( BCM_DMA_CBNEXT( ch ) ) = 0;
+ /* Complete everything, clear interrupt */
+ BCM2835_REG( BCM_DMA_CS( ch ) ) = CS_ABORT | CS_INT | CS_END | CS_ACTIVE;
+ /* Clear control blocks */
+ BCM2835_REG( BCM_DMA_CBADDR( ch ) ) = 0;
+ /* Reset control block */
+ cb = bcm_dma_ch[ ch ].cb;
+ bzero( cb, sizeof( *cb ) );
+ cb->info = INFO_WAIT_RESP;
+ return RTEMS_SUCCESSFUL;
+ if ( req_ch >= BCM_DMA_CH_MAX )
+ if ( _Atomic_Flag_test_and_set( &bcm_dma_ch[ req_ch ].dma_lock,
+ ATOMIC_ORDER_ACQUIRE ) != 0 ) {
+ return RTEMS_RESOURCE_IN_USE;
+ /* Check whether a channel is in use or not and allocate accordingly */
+ if ( bcm_dma_ch[ req_ch ].flags & BCM_DMA_CH_FREE ) {
+ bcm_dma_ch[ req_ch ].flags &= ~BCM_DMA_CH_FREE;
+ bcm_dma_ch[ req_ch ].flags |= BCM_DMA_CH_USED;
+ } else {
+ _Atomic_Flag_clear( &bcm_dma_ch[ req_ch ].dma_lock, ATOMIC_ORDER_RELEASE );
+ return ( RTEMS_SUCCESSFUL );
+ * Frees allocated channel. Returns 0 on success, -1 otherwise
+ rtems_status_code status_code = RTEMS_SUCCESSFUL;
+ if ( _Atomic_Flag_test_and_set( &bcm_dma_ch[ ch ].dma_lock,
+ /* Check whether the channel is in use or not and free accordingly */
+ if ( bcm_dma_ch[ ch ].flags & BCM_DMA_CH_USED ) {
+ bcm_dma_ch[ ch ].flags |= BCM_DMA_CH_FREE;
+ bcm_dma_ch[ ch ].flags &= ~BCM_DMA_CH_USED;
+ bcm_dma_ch[ ch ].intr_func = NULL;
+ bcm_dma_ch[ ch ].intr_arg = NULL;
+ /* Reset DMA */
+ status_code = rpi_dma_reset( ch );
+ status_code = rtems_interrupt_handler_remove( BCM2835_IRQ_ID_DMA_CH0 + ch,
+ rpi_dma_intr,
+ NULL );
+ _Atomic_Flag_clear( &bcm_dma_ch[ ch ].dma_lock, ATOMIC_ORDER_RELEASE );
+ return ( status_code );
+ int ch,
+ void ( *func )(
+ int,
+ void *
+ void *arg
+ if ( ch < 0 || ch > -BCM_DMA_CH_MAX )
+ /* Check whether the channel is in use */
+ if ( !( bcm_dma_ch[ ch ].flags & BCM_DMA_CH_USED ) )
+ /* Update the software context */
+ bcm_dma_ch[ ch ].intr_func = func;
+ bcm_dma_ch[ ch ].intr_arg = arg;
+ cb->info |= INFO_INT_EN;
+ * the same
+ int ch,
+ int dreq,
+ int inc_addr,
+ int width
+ uint32_t info;
+ /* Configure the info field */
+ info = bcm_dma_ch[ ch ].cb->info;
+ info &= ~INFO_PERMAP_MASK;
+ info |= ( dreq << INFO_PERMAP_SHIFT ) & INFO_PERMAP_MASK;
+ if ( dreq )
+ info |= INFO_S_DREQ;
+ else
+ info &= ~INFO_S_DREQ;
+ if ( width == BCM_DMA_128BIT )
+ info |= INFO_S_WIDTH;
+ else
+ info &= ~INFO_S_WIDTH;
+ if ( inc_addr == BCM_DMA_INC_ADDR )
+ info |= INFO_S_INC;
+ else
+ info &= ~INFO_S_INC;
+ /* Update the info field in the CB struture of the given channel */
+ bcm_dma_ch[ ch ].cb->info = info;
+ * the same
+ int ch,
+ int dreq,
+ int inc_addr,
+ int width
+ uint32_t info;
+ if ( dreq )
+ info |= INFO_D_DREQ;
+ else
+ info &= ~INFO_D_DREQ;
+ info |= INFO_D_WIDTH;
+ else
+ info &= ~INFO_D_WIDTH;
+ info |= INFO_D_INC;
+ else
+ info &= ~INFO_D_INC;
+ int ch,
+ vm_paddr_t src,
+ vm_paddr_t dst,
+ int len
+ return RTEMS_INVALID_ID;
+ * Checking whether the pointer address belongs to the
+ * top IO window. If it does converting physical address
+ * in IO space to VC bus address. If it does not then
+ * convert physical address to VC bus address.
+ if ( BCM2835_ARM_IS_IO( src ) )
+ cb->src = IO_TO_VCBUS( src );
+ else
+ /* While submitting address over mailbox interface */
+ cb->src = PHYS_TO_VCBUS( src );
+ if ( BCM2835_ARM_IS_IO( dst ) )
+ cb->dst = IO_TO_VCBUS( src );
+ else
+ cb->dst = PHYS_TO_VCBUS( dst );
+ cb->len = len;
+ /* Cache coherency */
+ rtems_cache_flush_multiple_data_lines(
+ (void *) bcm_dma_ch[ ch ].dma_map->buffer_begin,
+ bcm_dma_ch[ ch ].dma_map->buffer_size );
+ rtems_cache_invalidate_multiple_data_lines(
+ /* Write the physical address of the control block into the register */
+ BCM2835_REG( BCM_DMA_CBADDR( ch ) ) = bcm_dma_ch[ ch ].vc_cb;
+ /* Change the state of the channel */
+ BCM2835_REG( BCM_DMA_CS( ch ) ) = CS_ACTIVE;
+ * Returns size of transaction, 0 if channel is invalid
+ return ( cb->len );
+/* Utility function for rpi_dma_init */
+ void *buf,
+ int flags,
+ int *segp,
+ int first
+ unsigned int sgsize;
+ unsigned int curaddr, lastaddr, bmask;
+ vm_offset_t vaddr = (vm_offset_t) buf;
+ int seg;
+ lastaddr = *lastaddrp;
+ bmask = ~( -1 );
+ for ( seg = *segp; buflen > 0; ) {
+ * Get the physical address for this segment.
+ curaddr = vaddr;
+ * Compute the segment size, and adjust counts.
+ sgsize = BCM_PAGE_SIZE - ( (u_long) curaddr & BCM_PAGE_MASK );
+ if ( sgsize > sizeof( struct bcm_dma_cb ) )
+ sgsize = sizeof( struct bcm_dma_cb );
+ if ( buflen < sgsize )
+ sgsize = buflen;
+ * Insert chunk into a segment, coalescing with
+ * the previous segment if possible.
+ if ( first ) {
+ segs[ seg ].ds_addr = curaddr;
+ segs[ seg ].ds_len = sgsize;
+ first = 0;
+ } else {
+ if ( curaddr == lastaddr &&
+ ( segs[ seg ].ds_len + sgsize ) <= sizeof( struct bcm_dma_cb ) &&
+ ( segs[ seg ].ds_addr & bmask ) == ( curaddr & bmask ) )
+ segs[ seg ].ds_len += sgsize;
+ else {
+ if ( ++seg >= 1 )
+ break;
+ lastaddr = curaddr + sgsize;
+ vaddr += sgsize;
+ buflen -= sgsize;
+ *segp = seg;
+ *lastaddrp = lastaddr;
+ return ( buflen != 0 ? 27 : 0 );
+int rpi_dma_init( int channel )
+ struct bcm_dma_ch *ch;
+ void *cb_virt;
+ vm_paddr_t cb_phys = 0;
+ int error, nsegs;
+ vm_offset_t lastaddr;
+ bus_dma_segment_t dm_segments[ 1 ];
+ /* Setup Initial Setting */
+ if ( channel < 0 || channel >= BCM_DMA_CH_MAX )
+ if ( !( bcm_dma_ch[ channel ].flags & BCM_DMA_CH_USED ) )
+ ch = &bcm_dma_ch[ channel ];
+ bzero( ch, sizeof( struct bcm_dma_ch ) );
+ ch->ch = channel;
+ ch->flags = BCM_DMA_CH_UNMAP;
+ ch->dma_map = malloc( sizeof( struct bus_dmamap ) );
+ if ( ch->dma_map == NULL ) {
+ return ENOMEM;
+ /* Alignment = 1 , Boundary = 0 */
+ cb_virt = rtems_cache_aligned_malloc(
+ sizeof( struct bcm_dma_cb ) );
+ if ( cb_virt == NULL ) {
+ free( ch->dma_map );
+ return ENOMEM;
+ ch->dma_map->buffer_begin = cb_virt;
+ ch->dma_map->buffer_size = sizeof( struct bcm_dma_cb );
+ memset( cb_virt, 0, sizeof( struct bcm_dma_cb ) );
+ * Least alignment for busdma-allocated stuff is cache
+ * line size, so just make sure nothing stupid happened
+ * and we got properly aligned address
+ if ( (unsigned long int) cb_virt & 0x1f )
+ return RTEMS_UNSATISFIED;
+ lastaddr = (vm_offset_t) 0;
+ nsegs = 0;
+ error = bus_dmamap_load_buffer( dm_segments, cb_virt,
+ sizeof( struct bcm_dma_cb ), 0x00, &lastaddr, &nsegs, 1 );
+ if ( error == 0 )
+ rpi_dmamap_cb( &cb_phys, dm_segments, nsegs + 1, 0 );
+ else
+ rpi_dmamap_cb( &cb_phys, NULL, 0, error );
+ ch->cb = cb_virt;
+ ch->vc_cb = cb_phys;
+ ch->flags = BCM_DMA_CH_FREE;
+ ch->cb->info = INFO_WAIT_RESP;
+ rtems_interrupt_handler_install( BCM2835_IRQ_ID_DMA_CH0 + channel,
+ "DMA copy",
+ RTEMS_INTERRUPT_UNIQUE,
+ rpi_dma_intr,
+ NULL );
+ /* reset DMA */
+ BCM2835_REG( BCM_DMA_CS( channel ) ) = CS_RESET;
+ return 0;
+ struct bcm_dma_ch *ch = (struct bcm_dma_ch *) arg;
+ uint32_t cs, debug;
+ cs = BCM2835_REG( BCM_DMA_CS( ch->ch ) );
+ if ( !( cs & ( CS_INT | CS_ERR ) ) ) {
+ return;
+ if ( !( ch->flags & BCM_DMA_CH_USED ) ) {
+ return;
+ if ( cs & CS_ERR ) {
+ debug = BCM2835_REG( BCM_DMA_DEBUG( ch->ch ) );
+ BCM2835_REG( BCM_DMA_DEBUG( ch->ch ) ) = debug & DEBUG_ERROR_MASK;
+ rpi_dma_reset( ch->ch );
+ if ( cs & CS_INT ) {
+ /* acknowledge interrupt */
+ BCM2835_REG( BCM_DMA_CS( ch->ch ) ) = CS_INT | CS_END;
+ /* Note : BUS DMA sync : POST write so cache coherency not required. */
+ /* save callback function and argument */
+ if ( ch->intr_func )
+ ch->intr_func( ch->ch, ch->intr_arg );
1.9.1
