[PATCH v2 5/6] SD card : Changes for SD card driver
Mudit Jain muditjain18011995 at gmail.com
Mon Aug 22 04:04:17 UTC 2016
 freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c | 21 +++++++++++++++++++++
 freebsd/sys/dev/mmc/mmc.c                        |  2 +-
 freebsd/sys/dev/sdhci/sdhci.c                    |  6 ++++++
 freebsd/sys/dev/sdhci/sdhci.h                    |  2 +-
 rtemsbsd/include/bsp/nexus-devices.h             | 20 +++++++++++++++++++-
 5 files changed, 48 insertions(+), 3 deletions(-)
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c
index 4844f19..9ba83f3 100644
--- a/freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c
@@ -43,9 +43,11 @@ __FBSDID("$FreeBSD$");
 #include <machine/bus.h>
+#ifndef __rtems__
 #include <dev/fdt/fdt_common.h>
 #include <dev/ofw/ofw_bus.h>
 #include <dev/ofw/ofw_bus_subr.h>
+#endif /* __rtems__ */
 #include <dev/mmc/bridge.h>
 #include <dev/mmc/mmcreg.h>
@@ -55,9 +57,15 @@ __FBSDID("$FreeBSD$");
 #include <rtems/bsd/local/sdhci_if.h>
 #include "bcm2835_dma.h"
+#ifndef __rtems__
 #include <arm/broadcom/bcm2835/bcm2835_mbox_prop.h>
 #include "bcm2835_vcbus.h"
+#ifdef __rtems__
+#define BUS_SPACE_PHYSADDR(res, offs) ((u_int)(rman_get_start(res)+(offs)))
 #define	BCM2835_DEFAULT_SDHCI_FREQ	50
 #define	BCM_SDHCI_BUFFER_SIZE		512
@@ -125,11 +133,13 @@ static int
 bcm_sdhci_probe(device_t dev)
+#ifndef __rtems__
 	if (!ofw_bus_status_okay(dev))
 		return (ENXIO);
 	if (!ofw_bus_is_compatible(dev, "broadcom,bcm2835-sdhci"))
 		return (ENXIO);
 	device_set_desc(dev, "Broadcom 2708 SDHCI controller");
 	return (BUS_PROBE_DEFAULT);
@@ -140,13 +150,16 @@ bcm_sdhci_attach(device_t dev)
 	struct bcm_sdhci_softc *sc = device_get_softc(dev);
 	int rid, err;
+#ifndef __rtems__
 	phandle_t node;
 	pcell_t cell;
 	u_int default_freq;
 	sc->sc_dev = dev;
 	sc->sc_req = NULL;
+#ifndef __rtems__
 	err = bcm2835_mbox_set_power_state(BCM2835_MBOX_POWER_ID_EMMC,
 	    TRUE);
 	if (err != 0) {
@@ -168,6 +181,7 @@ bcm_sdhci_attach(device_t dev)
 		    sizeof(cell))) > 0)
 			default_freq = cell / 1000000;
 	if (default_freq == 0)
 		default_freq = BCM2835_DEFAULT_SDHCI_FREQ;
@@ -216,6 +230,7 @@ bcm_sdhci_attach(device_t dev)
 	sdhci_init_slot(dev, &sc->sc_slot, 0);
+#ifndef __rtems__
 	sc->sc_dma_ch = bcm_dma_allocate(BCM_DMA_CH_ANY);
 	if (sc->sc_dma_ch == BCM_DMA_CH_INVALID)
 		goto fail;
@@ -243,6 +258,7 @@ bcm_sdhci_attach(device_t dev)
 	sc->sc_sdhci_buffer_phys = BUS_SPACE_PHYSADDR(sc->sc_mem_res,
 	    SDHCI_BUFFER);
 	bus_generic_probe(dev);
 	bus_generic_attach(dev);
@@ -671,7 +687,12 @@ static driver_t bcm_sdhci_driver = {
 	sizeof(struct bcm_sdhci_softc),
+#ifndef __rtems__
 DRIVER_MODULE(sdhci_bcm, simplebus, bcm_sdhci_driver, bcm_sdhci_devclass, 0, 0);
 MODULE_DEPEND(sdhci_bcm, sdhci, 1, 1, 1);
 DRIVER_MODULE(mmc, sdhci_bcm, mmc_driver, mmc_devclass, NULL, NULL);
 MODULE_DEPEND(sdhci_bcm, mmc, 1, 1, 1);
+#else /* __rtems__ */
+DRIVER_MODULE(sdhci_bcm, nexus, bcm_sdhci_driver, bcm_sdhci_devclass, 0, 0);
+MODULE_DEPEND(sdhci_bcm, sdhci, 1, 1, 1);
\ No newline at end of file
diff --git a/freebsd/sys/dev/mmc/mmc.c b/freebsd/sys/dev/mmc/mmc.c
index 7a94dc4..ac3f1e0 100644
--- a/freebsd/sys/dev/mmc/mmc.c
+++ b/freebsd/sys/dev/mmc/mmc.c
@@ -1734,4 +1734,4 @@ static devclass_t mmc_devclass;
 DRIVER_MODULE(mmc, at91_mci, mmc_driver, mmc_devclass, NULL, NULL);
 DRIVER_MODULE(mmc, dw_mmc, mmc_driver, mmc_devclass, NULL, NULL);
-DRIVER_MODULE(mmc, sdhci, mmc_driver, mmc_devclass, NULL, NULL);
+DRIVER_MODULE(mmc, sdhci_bcm, mmc_driver, mmc_devclass, NULL, NULL);
diff --git a/freebsd/sys/dev/sdhci/sdhci.c b/freebsd/sys/dev/sdhci/sdhci.c
index 924f06d..91bcc83 100644
--- a/freebsd/sys/dev/sdhci/sdhci.c
+++ b/freebsd/sys/dev/sdhci/sdhci.c
@@ -682,7 +682,11 @@ int sdhci_init_slot(
     slot->quirks |= SDHCI_QUIRK_BROKEN_TIMEOUT_VAL;
+#ifndef __rtems__
   slot->host.f_min = SDHCI_MIN_FREQ( slot->bus, slot );
+#elif defined(LIBBSP_ARM_RASPBERRYPI_BSP_H)
+  slot->host.f_min = 400000;
+#endif
   slot->host.f_max = slot->max_clk;
   slot->host.host_ocr = 0;
@@ -739,10 +743,12 @@ int sdhci_init_slot(
   slot->timeout = 10;
+#ifndef __rtems__
   SYSCTL_ADD_INT( device_get_sysctl_ctx( slot->bus ),
     SYSCTL_CHILDREN( device_get_sysctl_tree( slot->bus ) ), OID_AUTO,
     "timeout", CTLFLAG_RW, &slot->timeout, 0,
     "Maximum timeout for SDHCI transfers (in secs)" );
   TASK_INIT( &slot->card_task, 0, sdhci_card_task, slot );
   callout_init( &slot->card_callout, 1 );
   callout_init_mtx( &slot->timeout_callout, &slot->mtx, 0 );
diff --git a/freebsd/sys/dev/sdhci/sdhci.h b/freebsd/sys/dev/sdhci/sdhci.h
index 91b8b76..d54c093 100644
--- a/freebsd/sys/dev/sdhci/sdhci.h
+++ b/freebsd/sys/dev/sdhci/sdhci.h
@@ -276,7 +276,7 @@ struct sdhci_slot {
   device_t dev;                         /* Slot device */
   u_char num;                           /* Slot number */
   u_char opt;                           /* Slot options */
-#define SDHCI_HAVE_DMA 1
+#define SDHCI_HAVE_DMA 0
 #define SDHCI_PLATFORM_TRANSFER 2
   u_char version;
   int timeout;                          /* Transfer timeout */
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index decd042..d2a2852 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -183,6 +183,24 @@ RTEMS_BSD_DEFINE_NEXUS_DEVICE(tsec, 0, RTEMS_ARRAY_SIZE(tsec0_res),
 #include <bsp/raspberrypi.h>
 #include <bsp/irq.h>
+static const rtems_bsd_device_resource rpi_emmc_res[] = {
+		.type = RTEMS_BSD_RES_MEMORY,
+		.start_request = 0,
+		.start_actual = BCM2835_EMMC_BASE
+		.type = RTEMS_BSD_RES_IRQ,
+		.start_actual = 62
+RTEMS_BSD_DEFINE_NEXUS_DEVICE(sdhci_bcm, 0, RTEMS_ARRAY_SIZE(rpi_emmc_res),
+    &rpi_emmc_res[0]);
+SYSINIT_DRIVER_REFERENCE(mmc, sdhci_bcm);
+SYSINIT_DRIVER_REFERENCE(mmcsd, mmc);
 static const rtems_bsd_device_resource rpi_dma_res[] = {
@@ -196,6 +214,6 @@ static const rtems_bsd_device_resource rpi_dma_res[] = {
 RTEMS_BSD_DEFINE_NEXUS_DEVICE(bcm_dma, 0, RTEMS_ARRAY_SIZE(rpi_dma_res),
-&rpi_dma_res[0]);
+    &rpi_dma_res[0]);
 #endif
1.9.1
