[PATCH v2 6/6] SD card : Added basic test suite
Mudit Jain muditjain18011995 at gmail.com
Mon Aug 22 04:04:18 UTC 2016
 libbsd.py                                    |   1 +
 libbsd_waf.py                                |  10 +++
 testsuite/sdhci01/demo-shell-block-devices.h |  32 +++++++++
 testsuite/sdhci01/demo-shell-minimal.h       |  37 ++++++++++
 testsuite/sdhci01/demo-shell.h               |  44 ++++++++++++
 testsuite/sdhci01/test_main.c                | 104 +++++++++++++++++++++++++++
 6 files changed, 228 insertions(+)
 create mode 100644 testsuite/sdhci01/demo-shell-block-devices.h
 create mode 100644 testsuite/sdhci01/demo-shell-minimal.h
 create mode 100644 testsuite/sdhci01/demo-shell.h
 create mode 100644 testsuite/sdhci01/test_main.c
diff --git a/libbsd.py b/libbsd.py
index 5927b7c..6e44f32 100755
--- a/libbsd.py
+++ b/libbsd.py
@@ -2544,6 +2544,7 @@ def tests(mm):
     mod.addTest(mm.generator['test']('timeout01', ['init', 'timeout_test']))
     mod.addTest(mm.generator['test']('init01', ['test_main']))
     mod.addTest(mm.generator['test']('thread01', ['test_main']))
+    mod.addTest(mm.generator['test']('sdhci01', ['test_main']))
     mod.addTest(mm.generator['test']('mutex01', ['test_main']))
     mod.addTest(mm.generator['test']('condvar01', ['test_main']))
     mod.addTest(mm.generator['test']('ppp01', ['test_main'], runTest = False))
diff --git a/libbsd_waf.py b/libbsd_waf.py
index f96f402..043a01b 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -1402,6 +1402,16 @@ def build(bld):
                 lib = ["m", "z"],
                 install_path = None)
+    test_sdhci01 = ['testsuite/sdhci01/test_main.c']
+    bld.program(target = "sdhci01.exe",
+                features = "cprogram",
+                cflags = cflags,
+                includes = includes,
+                source = test_sdhci01,
+                use = ["bsd"],
+                lib = ["m", "z"],
+                install_path = None)
     test_selectpollkqueue01 = ['testsuite/selectpollkqueue01/test_main.c']
     bld.program(target = "selectpollkqueue01.exe",
diff --git a/testsuite/sdhci01/demo-shell-block-devices.h b/testsuite/sdhci01/demo-shell-block-devices.h
new file mode 100644
index 0000000..a8f1411
--- /dev/null
+++ b/testsuite/sdhci01/demo-shell-block-devices.h
@@ -0,0 +1,32 @@
+ * @file
+ * @ingroup demo
+ * @brief Shell configuration.
+ * Copyright (c) 2010 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifndef DEMO_SHELL_BLOCK_DEVICES_H
+#define DEMO_SHELL_BLOCK_DEVICES_H
+#include "demo-shell-minimal.h"
+#define CONFIGURE_SHELL_COMMAND_FDISK
+#define CONFIGURE_SHELL_COMMAND_BLKSYNC
+#define CONFIGURE_SHELL_COMMAND_MSDOSFMT
+#endif /* DEMO_SHELL_BLOCK_DEVICES_H */
\ No newline at end of file
diff --git a/testsuite/sdhci01/demo-shell-minimal.h b/testsuite/sdhci01/demo-shell-minimal.h
index 0000000..3398629
--- /dev/null
+++ b/testsuite/sdhci01/demo-shell-minimal.h
@@ -0,0 +1,37 @@
+ * @file
+ * @ingroup demo
+ *  82178 Puchheim
+ *  Germany
+#ifndef DEMO_SHELL_MINIMAL_H
+#define DEMO_SHELL_MINIMAL_H
+#define CONFIGURE_SHELL_COMMAND_CPUUSE
+#define CONFIGURE_SHELL_COMMAND_PERIODUSE
+#define CONFIGURE_SHELL_COMMAND_STACKUSE
+#if defined(BSP_HAS_IRQ_INFO)
+#include <bsp/irq-info.h>
+#define CONFIGURE_SHELL_USER_COMMANDS \
+  &bsp_interrupt_shell_command
+#endif
+#endif /* DEMO_SHELL_MINIMAL_H */
diff --git a/testsuite/sdhci01/demo-shell.h b/testsuite/sdhci01/demo-shell.h
index 0000000..06b6863
--- /dev/null
+++ b/testsuite/sdhci01/demo-shell.h
@@ -0,0 +1,44 @@
+ * @file
+ * @ingroup demo
+ *  82178 Puchheim
+ *  Germany
+#ifndef DEMO_SHELL_H
+#define DEMO_SHELL_H
+#define CONFIGURE_SHELL_COMMAND_PWD
+#define CONFIGURE_SHELL_COMMAND_LS
+#define CONFIGURE_SHELL_COMMAND_CHDIR
+#define CONFIGURE_SHELL_COMMAND_CD
+#define CONFIGURE_SHELL_COMMAND_MKDIR
+#define CONFIGURE_SHELL_COMMAND_RMDIR
+#define CONFIGURE_SHELL_COMMAND_CAT
+#define CONFIGURE_SHELL_COMMAND_MV
+#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
+#define CONFIGURE_SHELL_COMMAND_WKSPACE_INFO
+#define CONFIGURE_SHELL_COMMAND_RTC
+#endif /* DEMO_SHELL_H */
diff --git a/testsuite/sdhci01/test_main.c b/testsuite/sdhci01/test_main.c
index 0000000..a8f80bf
--- /dev/null
+++ b/testsuite/sdhci01/test_main.c
@@ -0,0 +1,104 @@
+ *  This is the body of the test. It does not do much except ensure
+ *  that the target is alive after initializing the TCP/IP stack.
+#include <assert.h>
+#include <inttypes.h>
+#include <pthread.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <unistd.h>
+//#include <bsp/nexus-devices.h>
+#include <rtems.h>
+#include <rtems/media.h>
+#include <rtems/chain.h>
+#include <rtems/libio_.h>
+#include <rtems/shell.h>
+#include <rtems/console.h>
+#include <rtems/diskdevs.h>
+#include <rtems/bsd/bsd.h>
+#define TEST_NAME "LIBBSD SDHCI 01"
+#define ASSERT_SC(sc) assert((sc) == RTEMS_SUCCESSFUL)
+static void test_main(void)
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  sc = rtems_disk_io_initialize();
+  ASSERT_SC(sc);
+  sc = rtems_shell_init(
+    "SHLL",
+    16 * 1024,
+    10,
+    CONSOLE_DEVICE_NAME,
+    false,
+    true,
+    NULL
+  ASSERT_SC(sc);
+  exit( 0 );
+/* for old configuration structure */
+#include <rtems/rtems_bsdnet.h>
+ * Network configuration
+struct rtems_bsdnet_config rtems_bsdnet_config = {
+    NULL,                   /* Network interface */
+    NULL,                   /* Use fixed network configuration */
+    0,                      /* Default network task priority */
+    0,                      /* Default mbuf capacity */
+    0,                      /* Default mbuf cluster capacity */
+    "testSystem",           /* Host name */
+    "nowhere.com",          /* Domain name */
+    "127.0.0.1",            /* Gateway */
+    "127.0.0.1",            /* Log host */
+    {"127.0.0.1" },         /* Name server(s) */
+    {"127.0.0.1" },         /* NTP server(s) */
+    0,
+    0,
+    0,
+    0,
+    0
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_FILESYSTEM_IMFS
+#define CONFIGURE_FILESYSTEM_DOSFS
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#define CONFIGURE_STACK_CHECKER_ENABLED
+#include <rtems/confdefs.h>
+#define CONFIGURE_SHELL_COMMANDS_INIT
+#include "demo-shell.h"
+#include "demo-shell-block-devices.h"
+#include <rtems/shellconfig.h>
+#include <rtems/bsd/test/default-init.h>
1.9.1
