[PATCH 2/2] RTEMS changes for lpc32xx VFP support
Kirspel, Kevin
Kevin-Kirspel at idexx.com
Mon Aug 22 15:24:59 UTC 2016
diff --git a/c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc b/c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc
old mode 100644
new mode 100755
index f184741..441976d
--- a/c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc
+++ b/c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc
@@ -6,7 +6,8 @@ include $(RTEMS_ROOT)/make/custom/default.cfg
RTEMS_CPU = arm
-CPU_CFLAGS = -mcpu=arm926ej-s -mthumb
+#CPU_CFLAGS = -mcpu=arm926ej-s -mthumb
+CPU_CFLAGS = -mcpu=arm926ej-s -mfpu=vfp -mfloat-abi=hard
CFLAGS_OPTIMIZE_V ?= -O2 -g
CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
old mode 100644
new mode 100755
index 30501be..f95a9d3
--- a/c/src/lib/libbsp/arm/shared/start/start.S
+++ b/c/src/lib/libbsp/arm/shared/start/start.S
@@ -19,9 +19,9 @@
#include <rtems/asm.h>
-#include <rtems/system.h>
+#include <rtems/system.h>
#include <rtems/score/cpu.h>
#include <bspopts.h>
#include <bsp/irq.h>
#include <bsp/linker-symbols.h>
@@ -265,6 +265,7 @@ bsp_start_skip_hyp_svc_switch:
/* Stay in SVC mode */
#ifdef ARM_MULTILIB_VFP
+#ifdef ARM_MULTILIB_HAS_CPACR
/* Read CPACR */
mrc p15, 0, r0, c1, c0, 2
@@ -280,11 +281,18 @@ bsp_start_skip_hyp_svc_switch:
/* Write CPACR */
mcr p15, 0, r0, c1, c0, 2
isb
+#endif
/* Enable FPU */
mov r0, #(1 << 30)
vmsr FPEXC, r0
+#ifdef __FAST_MATH__
+ /* Enable Fast FPU options */
+ mov r0, #(3 << 24)
+ vmsr FPSCR, r0
+#endif
#ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
bl bsp_start_init_registers_vfp
#endif
@@ -399,6 +407,7 @@ _start:
#endif
* Enable CP10 and CP11 coprocessors for privileged and user mode in
* CPACR (bits 20-23). Ensure that write to register completes.
@@ -409,6 +418,7 @@ _start:
str r1, [r0]
dsb
isb
+#endif
diff --git a/cpukit/score/cpu/arm/rtems/score/arm.h b/cpukit/score/cpu/arm/rtems/score/arm.h
old mode 100644
new mode 100755
index 666ee54..7e511ac
--- a/cpukit/score/cpu/arm/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/rtems/score/arm.h
@@ -57,6 +57,13 @@ extern "C" {
#if defined(__ARM_ARCH_7A__)
#define ARM_MULTILIB_CACHE_LINE_MAX_64
#endif
+#if defined(__ARM_ARCH_7A__) \
+ || defined(__ARM_ARCH_7M__) \
+ || defined(__ARM_ARCH_7EM__)
+ #define ARM_MULTILIB_HAS_CPACR
+#endif
#if !defined(__SOFTFP__)
#if defined(__ARM_NEON__)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160822/bbf2d3ab/attachment.html>
